Question about Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw
Homelite 330 has no spark
My 330 did start this past summer and now I cant get it a spark,What is the first thing I should check,and help on taking it apart to fix it,
  • 211 Answers
Hi
First check if the plug wires is conected with the terminal from the rubber boot,pull the terminal out of the boot,crimp it with pliers and slide it back into the boot(has to fit snugly on the plug.Let me know
please.
regards savumihai71
Posted on Dec 10, 2008
Homelite xl-98c will not start
Changing a spark plug rarely fixes a no start problem. You need to troubleshoot the saw more. Do a search on youtube or google about how to check for spark and how to check to see that the carburetor is getting fuel.
Feb 24, 2014 | Homelite Xl-98a, Xl-98c, Xl98-d, Xl98-e...
Need to know; oil mixture spark plug setting for a homelite textron 330, ser.#3D2360270, Ut#10609
Hi gandp1993..
50 to One...oil to gas ratio 1 pint of 2 cycle oil to 6 gallons of gasoline.
Spark plug setting... .28 - .32
Please take time to rate me
Sep 22, 2011 | Garden
I would like to know where I can buy or order an inlet manifold boot for Homelite 330 Chainsaw. I am having difficulty finding this part.
hi photobil
pauly46 here
here is web site for parts
http://www.odref.com/homelite/chainsaw/ut-10540.pdf
go to page 9
part ref # 26 number 93838b boot connector
save a copy of this file
here is another web site
http://store.chainsawr.com/collections/homelite-1?page=11
he has had them but o/s at present but order 1 anyway
check out www.chainsawr.com , go to parts by brand homelite ,
cheers hope it helps
pauly46
May 29, 2011 | Homelite Zama Rb3 Carb Kit 330 Chainsaw...
No spark on homelite 330 chainsaw. wire on on\off switch broke. thought to be ground wire. attached to block, still no spark switch in either direction.
The switch grounds the coil and kills the spark. Make sure you dont have a rub through on the wire coming from the coil. Better yet disconnect the coil wire. If this works you will have spark but wont be able to shut it down. Verify good spark, then repair the wire.
Hope this helps, Matt
Dec 12, 2010 | Homelite Garden
Chain Saw Motor will not start.
Yes it is very important i would recommend also putting in a new spark plug. Thanks for asking and I hope it helps
Jul 20, 2010 | Homelite ZR10926 16 Chain Saw
Homelite 26 BV Gas Leaf Blower
sounds like you had fuel leak into the cylinder over the winter. The liquid in the cylinder is what made it so hard to pull that first time, as it won't compress like air. What you do, is take the spark plug out, pull the starting rope several times, dry off the spark plug, and let both sit(plug out of the cylinder.) for a couple of hours. Then put the plug back in, put the wire back on it, put it on full choke, and pull until it hits once. Then put it on half choke, and pull til it starts.
Mar 28, 2010 | Homelite Consumer Products 7 Amp...
Chainsaw will not run, there is no spark detected
Homelite 330 – no points
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/baf9791bfc773f1a88256c2600142688?OpenDocument
Please try this
Ignition Coil Test by SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You don’t have to bend up the electrode. HTH
Lou
Oct 27, 2009 | Remington Electric Chain Saw
Homelite runs wide open all the time
intake boot under carb is probably bad, mine did the same thing and this was the problem. about a 6 or 7 dollar fix
Nov 13, 2008 | Homelite Garden
Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw Logo
511 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
