Question about HP OfficeJet 6210 All-In-One InkJet Printer
Dark balck line down middle when copying, but not when printing
I know that the glass is clean
If this happens only when you feed the original through the top feeder and not when you lay it on the glass, then you have a small bit of dirt at the scanning location--since the paper moves, rather than the scanning bar, the section of glass that is involved is very small and one little bit of dirt will make a line down the whole page. You need to lift the automatic document feeder mechanism and clean the glass strip under it--that's where your (unseen) dirt is. (Page 108 of the manual, if you have one.)
Posted on Feb 18, 2009
    Guru:
  • 1,049 Answers
Sounds like the scanner bar that moves under the glass is dirty or more likely damaged.
Posted on Dec 10, 2008
Copier leaves a black line when printing through the top paper feeder. Ok coping from the flatbed
When copying from the feeder the page is fed across a fixed point at the head of the flatbed. Any dirt etc on the glass at this point can present as a dark line running vertically down the printed page. When copying from the flatbed, the scan head is moved down the page so any dirt on the glass will only appear as specs. Try cleaning the glass, especially at the head of the flatbed where the feeder is loading the page to be copied.
Jan 12, 2014 | Office Equipment & Supplies
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
Savin 9935DPE is printing one thick vertical balck line down the copy or print pages. About 2 of every 3 pages printed. What's wrong?
are you printing from Doc feeder or glas?? if from feeder then try to make a copy from the glass, does it still do it? yes problem is with drum.
No? problem is with the small scanning glass to the left, look carefully see if any spots or lines on the 1inch glas --- clean it
Sep 05, 2012 | Savin 9945dpe 9935dpe 2035dpe 2045dpe...
My HP Pro 7780 has recently started making copies (through the feeder) with 2 large blank streaks down the middle of the page (lengthwise). I am worried that this is also happening when I send a fax as...
Does this happen when you print, or only when you copy? If you print out a configuration or user settings page, or print a page from the computer, is it also missing two vertical lines of print or is it only when you are copying?
If it happens when you print, you may need a cleaning, or you may need to replace the toner or drum cartridge. If it's an inkjet machine, there's a possibility there is some ink or grease on the encoder strip (a small belt-like plastic strip that goes through the print-head carriage).
If it only happens when you copy, test both the flatbed and the document feeder. If it happens on both then you may have a bad scanner. If it only happens when using the document feeder, you likely have some whiteout (or something) on the glass. When you make a copy in the flatbed, the scanner moves across your document. When you make a copy using the document feeder, the document moves across the scanner. In this case, if there is anything on the scanner glass (like whiteout) your copies will be missing a vertical line of print data (it could be white if there is whiteout on the glass, or it could be dark if something dark is on the scanner glass).
Usually you can lift the flatbed cover and look at the glass to see if anything is on it (usually at the left side of the scanner). Clean the glass, first with alcohol to remove the obstruction, and then with a little windex to remove anything the alcohol may have left behind.
Sep 23, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
Leaving a dark strip down the middle of the copy
what your copir model? if your model IR3045 replase the drame unite.
Jan 05, 2010 | Canon Office Equipment & Supplies
HP Laserjet 3330 printed dark page especially around the middle
Does this happen both when copying and printing?
For printing solution, try another toner cartridge.
If lines continue to appear when copying (primarily through the automatic feeder) then lift the auto feeder, and clean the glass -mainly the narrow piece on the left side.
please rate solution :)
Apr 07, 2009 | HP LaserJet 3330 All-In-One Printer
I get a dark line in the middle of the pages
Dust in the scanner, clean the scanner line inside the refill  compartment
Mar 06, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
I have a dark line across copies
Whats the make and model of the copier?
One culprit might be the drum.  If you can take a look at the drum from your copier and you see black lines on it.  It could be scratches on the drum or it may need a new cleaning blade to clean the toner off the drum.
Nov 11, 2008 | Office Equipment & Supplies
Ricoh IS450DE Scanner
The scanner glass is dirty. Its usually caused by a very tiny spec on the glass.
Clean the glass and it will go away.
Jun 16, 2008 | Ricoh IS450DE Flatbed Scanner
HP OfficeJet 6210 All-In-One InkJet Printer Logo
126 people viewed this question
Ben Johnson
