Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Not making ice
I have a Frigidaire side by side.Model frs26hf5a and the ice stopped working.I noticed that the chute the water comes down had an ice block.I heated that up with a dryer and it melted and started making a little bit of ice.Now it has stopped after about a day.I havent changed the water filter for a coupla years.The water in the door comes out but not as fast as it once did.By not replacing the filter cause the ice maker to stop?Do you think its not getting enough water to the ice maker>
The filter does effect somewhat the flow of the water. For some people having problems with ice dispensing it may be as simple as lifting the metal shut off bar up and down. Then check the top of the ice tray to make sure no ice is stuck up there. When you move the metal bar up and down you should see the plastic dispenser that pushes the ice out turning or rotating. Hope this helps.
Posted on Jan 17, 2009
  • 333 Answers
You should change this filter first before you go crazy tryibng to figure the problem out. It may just be this.
Posted on Dec 10, 2008
When i close the door on the freezer side the water trickles down the front panel
This could be a leaking water valve. First thing I would suggest is to turn the water supply off under the sink or behind fridge wherever its located and see if the leaking stops.If so then you'll need to replace the water valve on fridge. If this doesn't work look up inside the ice chute on front of door and make sure the flapper is closing all the way when you get ice. Warm air coming up into freezer because the flapper is not sealing tight can cause water to run down front of fridge.If this is the case there is usually frost buildup on the ice chute on the inside of door.
Oct 25, 2013 | Refrigerators
The ice maker makes humming noise but is not making ice
Sounds to me like the water control solenoid has failed and is not opening to allow water to flow into the ice maker.
Jan 20, 2013 | Frigidaire GLRS267ZA Side by Side...
Frigidaire FRS26ZSH -ice & water dispenser panel lost power
I think you will need to unplug the pin plug under the cover at top or bottom hinge. Check the voltage and if OK leave unplugged until you can remove the dispenser and I will try to help you from the power source. Sounds like a short in the board and related to the light socket. The fuse only stopped the short from doing further damage, You may need to locate the short before replacing the fuse or board. I have looked over the wiring diagram. If you find the short without my help just be sure to replace the fuse with the correct size. The only things are the chute heater or something in that area of the board went to ground. Do you have a voltage meter? Contact me later when ready, Sea Breeze
Jan 20, 2010 | Frigidaire FRS3R5EMB Side by Side...
Will not release ice and makes crushed ice, even when on cubed.
I believe in your case the ice maker part number WR30X10093 being electronic with the control board in the front is the problem. I think the control board behind the front cover of the ice maker may have corrosion and causing the ice maker to malfunction. You can try disconnecting the set of wires to the coil on the water control valve and see if the water stops or turn off the ice maker first and try disconnecting the coil wires later. It has to be the control board or the water control valve part number WR57X10032
Oct 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
Not making ice
Hi: Change or just remove the water filter first. As your water dispensing slowed that is a clue. If the water filter is that clogged it will cause a problem with the ice maker. Plus the water you drink is not filtered anymore. City water is being run through 2 years of crud. If you don't replace it just remove it. I hope this helps, Jeff
Jun 03, 2009 | Frigidaire FRS3R5EMB Side by Side...
Ice maker stopped working???
water valve or icemaker or make sure freezer is freezing check see if you have frost build up
Apr 06, 2009 | Kenmore 57029 Side by Side Refrigerator
Ice maker not working - Frigidiare refridgerator Model number FRS26BH6CB4
take the line off of the solinoid valve and check to see if there's a screen in the valve. that could be plugged with debris.
Dec 20, 2008 | Frigidaire FRS26R4A Side by Side...
10 yr old Frigidaire ice maker stopped making ice
check to make sure the fill tube is not plugged with ice if it is not then i would guess the valve is shot
Oct 30, 2007 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
383 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
