Question about HP ProLiant ML310 G3
Converting to a pc
I have just got very cheap a working ml310 two sata drives etc. There are slots for cards and I would like to fit a sound card ( I have installed xp) the pci slots are the wrong way around for the sound cards I have can you help please?
    Problem Solver:
  • 8 Answers
This machine was never intended to be a PC. It does not have any standard PCI slots, only PCI-X slots. You can get PCI-X sound cards but these will be expensive if you are able to find then. You can try to search to buy PCI-X sound cards in google.
Posted on Mar 19, 2009
I have upgraded my hard drive from pata to sata using the ide to sata converter I don't no what went wrong but my diagnostic lights are reading A B C are solid green D is solid yellow and i am getting...
You may have to reboot a few times to update the bios with the new card. But there is probably an IRQ problem between the 2 cards. To fix this move the sata card over one slot and try booting again maybe 2 or three times.
Nov 28, 2013 | Dell Dimension 3000 PC Desktop
RUNNING A SATA HDD ON AN IDE ONLY MOTHERBOARD
If I am not completely mistaken you have to reinstall the OS on the SATA drive on IDE. That is because the first installation was configured for connection on a SATA /PCI then now on the SATA/IDE port converter.
Sep 25, 2008 | Adapters.com Serial ATA IDE Converter and...
I dont have a hard drive, can i use any hard drive
I looked up the specs on that device. See below. The specs call for IDE. You will only be able to use an IDE harddrive drive. You can pick IDE drives up pretty cheap from TigerDirect, Amazon, NewEgg or most local tech computer/tech stores.
http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/specs.htm
Oct 21, 2012 | Dell Dimension 2400 PC Desktop
Have an HP Pavilion ze4935wm laptop. Want to upgrade to higher GB and RPM. What is the highest I can go with this type of laptop?
This is an older laptop that uses a PATA (sometime called EIDE or ATA-100) drive.
The largest drives commonly available in PATA type for laptops are 320GB, at 5400 RPM.
There are bigger and faster laptop drives, but they will not work with that laptop since the bigger drives require a SATA interface.
PATA drives are more expensive than their SATA equivalents, it might be better to invest your upgrade dollars into a newer laptop.
Apr 17, 2011 | HP Pavilion ze4935wm PC Notebook
Is it compatible to use a sata hard drive
Not without a host card like this one: http://www.newegg.com/Product/Product.aspx?Item=N82E16816102065
You don't have any SATA ports on your motherboard. You can use a host card to add those ports in, if you have a free PCI slot.
Have fun and good luck.
Mar 01, 2011 | ASUS P4B533 Motherboard
I have a Dell Dimension 3100 N series-no audio
Yes you can get a card for this unit and any cheap old PCI slot card will work. UNless that is you want an expensive high quality sound car. Where this card will plug in is the back of the computer inside on the motherboard where most likely your video card it... There is only one type of slot it can fit in so just line them up and press it in. BE VERY CAREFUL not to shock your motherboard with static or it will be shot. To do this always have one hand grounded on the case AT ALL TIMES!!!! Now, once you have your sound card installed pop in the drive cd that comes with it install the software restart your conputer and you will have sound :)
Mar 31, 2010 | Dell Dimension 3100 PC Desktop
What is compatible with my emahcines w3050 in upgrading my video memory. What limits are on my machine?
HDMI? Oh, then you would be talking about a graphics card like this one,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5071689&CatId=318
HIS Radeon HD4670 IceQ
1) AGP 8X graphics card
2) Has a VGA, DVI, and HDMI port
3) 1GB of GDDR3 ram memory
4) 128bit interface
5) 320 Stream Processors
6) Core Clock is 750MHz at maximum capability
7) Memory Clock is 1746MHZ at maximum capability
It doesn't matter that your computer system ram memory is DDR Sdram. The GDDR3 graphics ram memory operates independent of the system ram memory.
Information about graphics, graphics cards, and graphics card terminology,
A) http://www.brighthub.com/video-games/pc/articles/984.aspx
B) http://computer.howstuffworks.com/graphics-card.htm
Mar 20, 2010 | E-Machines W3050 PC Desktop
Connect ide or sata drives to a dell poweredge 2600 for additional storage
Yes and No..
The standard machine only allows SCSI, (no IDE or SATA or SAS connectors...
However SCSI drives are not cheap.. so
To overcome the power issue (you will notice there are no 4 pin molex connectors, or sata power connectors). However there is a 4 pin molex socket on the SCSI backplane. You can use one of those molex adaptor cables (one connector to many) to get power, from the molex you can use a 4 pin to SATA power connector.
Next step is to decide the drive you want to use. I personally use SCSI, SATA, SAS and IDE in mine (overkill I know).
Cheapness says use IDE or SATA. You can get a pci IDE/SATA controller card on ebay dirt cheap (PCI cards are compatible with the large PCIX slots), they dont take the entire "socket" up but they work (be carefull here, there is one 5v pci socket on these machines, and 6 pcix sockets, the pcix sockets will accept 3.3v pci cards (look at the notches).
Next you have to mount them, with a bit of jiggery pokery you can feed the IDE/SATA cables past the SCSI backplane into the hot swap bay. (If you dont have any empty caddy's pick them up off ebay), just remember you cant just pull em out like you can with the SCSI's!) - or use one of the 5 1/2 media bays.
Plud the other ends into the appropriate controller card (as installed in the PCI bus).
Load up the OS, install drivers (if needed - these should come with the pci card(s), use the disk manager to initialise/first format the drives etc.
All done.
I have done this myself running a 2600, with 2X U320 72gb SCSI (on Raid) 1 x IDE CD/DVDRW in Media bay, DAT 27 SCSI (channel B) in the second media bay. 2x 146gb SAS on a DELL SAS pcix card (in 2 of the hot swap bays) and an old 160gb IDE HDD (Funilly enough theres a bit towards the back of the two fans on the SCSI backplane that if you press the 3 1/2 drive against seems to fit perfectly in this place and stay there! (I think thats fluke to be honest).
All done :)
Jan 04, 2010 | Dell PowerEdge 2600 Server
Is there a plug in on the board for a SATA input. So I can install another hard drive.
Do these specs sound right?
The Lenovo 3000 J115 series of computers does not come with a video card but with the NVIDIA GF 6100 Integrated Graphics which is plenty to run the Windows Vista operating system. You can also expand the graphics capabilities by adding a video card in the available PCI Express video card slot.
The motherboard, Lenovo Model L-NC51M, which comes with this series of computers, has two memory stick slots, one PCI express x1 slot, one PCI express x16 slot and two PCI slots. The 3000 J115 models come standard with Windows Vista Home Basic Operating System, 512 gigabytes memory, an 80 gigabyte serial ATA hard drive, Integrated Gigabit Ethernet and a 16X DVD optical drive.
If so, there should be more sata ports on the motherboard.
This what sata ports look like:
http://www.hardwarezone.com/img/data/articles/2007/2387/p6ngm_sata.jpg
You also need a sata power cord or Molex to Sata power adapter:
See pictures:
http://www.hardwarezone.com/img/data/articles/2004/1192/tutorial-sata_power_conn.jpg
http://www.qvs.com/images/sata-power.JPG
Hope this helps you some.
Jul 07, 2009 | Lenovo 3000 J Series 1.80G VBE PC Desktop
Swap Dell 4700C Motherboard into New Case
As long as the form factors are the same ie ATX then it should be fine - also ensure that cooling will be fine and that hardware wise it will all fit in then it should be fine if either of them are under warranty then I would check with Dell.
what things do you need to plug in as a network card only takes up one PCI slot, a dvd rw drive replacement is cheap and can either be IDE or SATA so dont see how that would take up extra space in terms of slots ?
If you need more IDE or SATA slots you can get another PCI card to support that / them.
Apr 17, 2009 | Dell Dimension 4700C PC Desktop
HP ProLiant ML310 G3 Logo
97 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
