Question about Uniden Lands Phones
No dial tone line good talk keeps flashing
Phone uniden 2.4ghz
I have the same issue .... found anything
Posted on Nov 04, 2009
How to get a dial tone on your uniden 6.0 cordless phone
If you have a phone line that is active, lift the handset from the cradle, enter the number and press TALK. Or just press TALK if you want to verify that you have a tone signal.
Aug 27, 2011 | Uniden DECT 6.0 Cordless Telephone...
I have 2 problems. 1. The orange message light will not stop flashing no matter what I do. 2. Some how the system was switched from touch tone to dial tone. I can't seem to that switched either.
Resetting the voice message waiting indicator
When you receive a new voice mail message, the new message LED on the top of the handset flashes. In the event your message waiting light gets out of sync with your phone company's
voice messaging system, you can manually reset it back to the "No messages waiting" state.
1. Press and hold FiND on the base for five seconds.
Note: The handsets connected to the base will start to beep, however, keep pressing for five seconds.
2. A beep sounds and the message alert tone is reset.
Changing the dial mode
Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most base networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you will need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, please follow the steps below to modify your phone's settings:
1. Press MENU/SELECT.
2. Select the Global Setup menu, and then the Dial Mode submenu.
3. Scroll to highlight Pulse.
4. Press MENU/SELECT. You will hear a confirmation tone.
If you ever need to change the dial mode back to tone dialing, follow the same procedure, but select Tone in step 3.
Finally for future ease of use, here is a link to the user manual were I copied the above information from:
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1580-3om.pdf
Jul 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
Has new battery, but no dial-tone,
Replacing the battery reset the phone to the factory defaults, which means you'll have to restore the connection to the base in Menu-Setup
***Don't forget to VOTE for the guys who take an interest in helping!
Apr 19, 2010 | Uniden Cordless Phone
Can receive calls but cannot dial out on Verizon landline phone
Try punching in the number to call first THEN hit talk.. It should dial and call at that point..
Just like when making a call from your cell phn - dial the # first..
good luck ;o)
Sep 17, 2009 | Uniden DECT 6.0 Cordless Telephone...
No dial tone on uniden 5.8GHz digital phone
there is no dial tone on my land line uniden 5.8 ghz.
Jan 24, 2009 | Uniden Cordless Phone
How to set up Speed Dial on a Uniden phone?
My Mom had this same problem.   I found these instructions on Uniden's website (uniden.com) under the "Owner Manuel" section.
Here you go - good luck!
Using the Speed Dial Memory
Storing Numbers in Speed Dial Memory
Your cordless phone can store up to ten numbers (up to 20 digits each) in the speed dial
memory. To store number in memory:
1) When the phone is in standby, press [memory]. The talk/batt low LED flashes.
2) Use the keypad to enter the phone number.
 (To enter a 2-second pause between numbers, press [redial/
pause]. Each pause counts as a digit. )
3) Press [memory] again.
4) Select the speed dial location where you would like to store the
number ( [0] to [9] ). You will hear a confirmation tone indicating
that the number has been stored.
NOTE:
• Storing a number to a speed dial location will
overwrite the any previously stored number without
warning.
• When storing numbers into memory and the handset is idle (i.e., no key is
pressed) for more than 0 seconds, it will beep rapidly, and then the phone
will return to standby.
Dialing a Stored Number
1) When the phone is in standby, press [talk], and listen for a dial tone.
2) Press [memory] and enter the speed dial entry ([0] – [9]) that has the stored number
you want to dial. (If you enter a digit that does not contain a stored number, the
handset will beep rapidly, and the phone will not dial.)
Chain Dialing
The speed dial memory is not limited to phone numbers. You can store any number (up
to 20 digits) that you need to enter once your call connects. This is referred to as Chain
Dialing. An example is a frequently refilled prescription number. Store your pharmacy
phone number in one speed dial and your most frequently refilled prescription number
as another speed dial. To use, once you ring your pharmacy's automated prescription
line, simply press [memory] and the speed dial number where you stored your account
number.
Erasing a Stored Number from Memory
1) With the phone in standby, press [memory] twice.
2) Press the number of the speed dial entry. A tone indicates that the stored number is
erased from memory.
Jan 11, 2009 | Uniden Cordless Phone
Uniden cordless phone. No dial tone.
Hi peddler65, did you plug your phone into another area to see if there is a dial tone. Then if not call the phone company or find the D-mark (where your dial tone ) comes into your home and put a jack on that and plug a phone in with all phones in the house unplugged.
Thanks.
Nov 14, 2008 | Uniden Cordless Phone
UNIDEN POWER MAX 2.4 GHZ
Do you have the manual on line for the Uniden PowerMax 2.4 GHZ
Apr 01, 2008 | Uniden Cordless Phone
Lands Phones Logo
79 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
