Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
Coleman Evcon..... Inducer Adjustment
Mr Drumbanger..
I talked to my furnace person and told him that you had mentioned the inducer may need adjusted...... He did not know how you would adjust the inducer other than perhaps adjusting the fan to make sure it wasnt rubbing....... Can you be so kind as to enlighten me on how you would go about adjusting the inducer...... Thank You So Much
Coleman Evcon (DGAT070BDD) Michael ONeill
  • 8 more comments
  • bumperooo Dec 17, 2008
    muttandjeff,
    muttandjeff,
    I was told by drumbanger I may need to adjust the inducer.... I told my furnace man and he said he had never knew of any such adjustment... unless you could adjust the fan but other than that he didnt know of any adjustment.... My furnace will run fine and then I'll get three blinks from it but at times it will still kick on with the light blinking.... go figure.....At times it will go below at the temp its set on and then kick on.... I have a psycho furnace and no one seems to know whats up with it.... Furnace man wanted to put in an inducer but its running as I type........Coleman puts out some mysterious furnaces......
  • bumperooo Dec 25, 2008
    Well I came up with solution..... There is a gasket that sits on top of the inducer....... I find out threw Coleman, that if any part of the impeller is touching that gasket it will cause you problems when it comes to kicking on furnace..... Coleman said that gasket touching the impeller can cause the furnace to be very tempermental....The furnace would kick on at times with the light blinking...... that really caused us to scratch out heads....I guess with drumbanger said adjust the inducer he had to be thinking of that account theres no other way to adjust anything......
  • bumperooo Jan 23, 2009
    My solution to my furnace problem..... was to take off the inducer and make sure that no part of the gasket between the inducer and impeller were touching the impeller..... My furnace man worked on gasket and made sure it wasnt touching the impeller and its worked wonderfully ever sense....
    A coleman person out of Wichita, Kansas...whom I contacted enlightened my furnace man on what to do.... Said take that inducer off and make sure that the gasket isn't touching any part of the impeller....as the coleman evcons can be very tempermental if any part of that impeller is touching the gasket...... Thank god for technicians.... I was about to have a baby.......and I'm a guy......
  • Lou Barta May 11, 2010
    There is NO adjustment on an induced draft motor other than the positioning of the fan wheel.....
    What is the furnace doing? Are you having a problem?
  • Scott Magill May 11, 2010
    i have never hear of any adjustment or seen any adjustment. sounds like you have it fixed. I haven't seen gasket a problem before either.
    what is going on with your heater? how old is heater? have you checked combustion air?
  • Allen Neal
    Allen Neal May 11, 2010
    thanks for fix muttandjeff
  • Allen Neal
    don't know but ,if you get this answer i would like to know also never heard of such adjustment
  • 221 Answers
Just wanted to make sure you knew this model is on a recall list:
http://www.dgatprogram.com/
Posted on Jan 02, 2010
    Scholar:
  • 91 Answers
There are certain ways to strengthen air flow to activate the vacuum switch. It may be that something is obstructing the flue pipe, or the unit was installed too far from the outside where it exhausts. Or there may be some debris in the small tube to the vacuum switch....or,,,or a dozen other things. ?///good luck
Posted on Jul 10, 2009
Need to find a replacement part
Here you go Angela
1149097 Draft Inducer Assembly - AllParts Heating
www.allpartsheating.com/1149097.html
  1. Cached
  2. Similar
Draft Inducer. 1149097 draft inducer for Heil, Tempstar, Arcoaire, Whirlpool & Comfortmaker brand model furnaces. This part replaces old part number 1008416.
Arcoaire Furnace Motor Parts: Fast Shipping RepairClinic.com
www.repairclinic.com/Shop-For-Parts/a36b389c53/Arcoaire-Furnace-Motor-Parts
  1. Cached
  2. Similar
Furnace draft inducer assembly. The draft inducer motor draws air into the burner and exhausts it out the flue. If the draft inducer motor is defective, the furnace ...
Arcoaire Furnace Parts: Fast Shipping RepairClinic.com
https://www.repairclinic.com/Shop-For-Parts/a36b389/Arcoaire-Furnace-Parts
  1. Cached
Direct Factory Replacement Inducer Blower Motor Used in 90 ...
www.americanhvacparts.com > ... > Oem Direct Replacement Models > Arco Aire
  1. Cached
  2. Similar
Direct Factory Replacement Inducer Blower Motor Used in 90% Furnaces. ... Comfortmaker, Intercity Products Snyder-General, Heil, Tempstar, Arcoaire Draft Inducer Blower Motor. ... Used in ICP Equipment Models: ... GUH125A016CIN
1149097 - Arcoaire Furnace Draft Inducer / Exhaust Vent Venter Motor ...
https://www.amazon.com/1149097-Arcoaire-Furnace-Inducer.../dp/B00FFBQRGA
  1. Cached
1149097 - Arcoaire Furnace Draft Inducer / Exhaust Vent Venter Motor - Fasco Replacement: Replacement Household Furnace Motors: Amazon.com: Industrial ... Draft inducer motor for arcoaire model guh125a016cin Google Search
Nov 27, 2016 | Heating & Cooling
Furnace wont work
Have to know the model and serial of the furnace.
locate code list usually inside or on the back of a door.
Operation sequence= call for heat--inducer blower motor--makes pressure switch--signals board to bring on hsi--after a set time gas valve opens and you have ignition--main blower motor comes on after a set time
Feb 14, 2014 | Coleman 7990-319p Evcon Gas Furnace...
Coleman Evcon model DLAS075ADC, glow plug lights, fire starts, then the blower comes on,..after ten minutes the whole system shuts down and will not re light, what is causing this?
Check to see if the pressure switch is sticking...it wont restart the furnace if it is already pulled in before the inducer motor is called to kick on.
Dec 17, 2013 | Heating & Cooling
Model m1mc 090a bw furnace pressure switch open. inducer motor is pulling .45 w.c . the intake pipe above inducer is only pulling .1 w.c. . checked for venting and intake blockages found non. removed...
did you check the hose from the inducer to the pressure switch? HAVE you unplugged the unit from the wall outlet to reset the board? DO you have a voltmeter? If you do you can run voltage across the switch and if you get 24 volts you are open.
Oct 23, 2013 | Coleman Intertherm Nordyne Miller Furnace...
How do you replace a pressure switch on a coleman evcon furnace
The pressure switch is mounted with 1/4" or 5/16" self tapping screws and has 2 wires and a rubber tube that attaches to the induced drafts assembly.
Jan 25, 2013 | Coleman 7990-319p Evcon Gas Furnace...
The internal fan in front of the filter is blowing air into the panel where the wiring is and heating everything up and melting the wiring and limit switch
Think your talking about the inducer motor. If this is the case, make sure the exhaust pipe is attached correctly, and that there is nothing blocking the flue pipe.
Dec 14, 2012 | Coleman 7990-319p Evcon Gas Furnace...
I have a Coleman evcon gas furnace. The inducer motors activates when the thermostat is engaged,but shuts off before the heater kicks on. There is also a blinking red light.
Hello, it sounds like the pressure switch is not closing on your furnace and remaining open, reasons for this could be a blocked flue pipe, the tubing going from the inducer motor to pressure switch could be blocked, loose, or have condensation in it, or the switch itself is bad. U can check the tubing by taking it off blowing some air through it and making sure no condensation is in the tubing, then reinstall it. If everything checks out good then the pressure switch is bad and must be replaced.
Feb 20, 2011 | Coleman Heating & Cooling
I have a coleman evcon furnace and it wont work it gives me a flash code of 1 what does it mean
One flash mean ignition failure. The sequence is: T-Stats calls for heat, inducer motor comes on, igniter glows orange (look through glass), then gas comes on and burner lights, approximately 1 minute later the indoor blower comes on. If you don't see the glow, most likely the igniter is bad. If you see the glow but no flame, it's a gas problem, supply or defective valve.
Dec 26, 2009 | Tools & Hardware - Others
Have a coleman evcon furnace model DGATO56BDD. blink code flashes 3 times with no diagram to know what the problem is. the furnace blows cool are instead of warm.
Your centrifical swith is stuck open on your blend motor. I found that removing the blend motor housing and spinning the stuck motor (from setting over the summer) will get you out of a bind ,.but you may end up needing this centrifical switch (locatedon the bottom of the blend/fresh air intake) motor replaced.
Oct 02, 2008 | Heating & Cooling
Heating & Cooling Logo
588 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
