Question about Office Depot Ativa DQ60M Shredder
Can I purchase parts for my Ativa DQ60M shredder? I needa a few of the cutters and plastic spacers.
  • 58 Answers
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Posted on Mar 27, 2009
Shredder won't stop running
THERE MAY BE SOME PAPER SHREDS BLOCKING THE LASER LIGHT.
UNPLUG SHEDDER AND CLEAN CUTTER HEADS.
Sep 30, 2011 | Office Depot Ativa DQ60M Shredder
I have an Ativa MD 460 shredder, it is misaligned with paper. Can you help?
ativa md460 misaligned Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Find solutions to your ativa md460 misaligned question. Get free help, tips ... I have an Ativa MD 460c paper shredder that reads misalignment. What do I do?
Just purchased ativa MD 460C and it will not work. misaligned
www.fixya.com/support/t9496803-just_purchased_ativa_md_460c
Jun 16, 2011 - Look for a curve in the lip on the back of the shredder and align it with the ... I have an Ativa MD 460c paper shredder that reads misalignment.
Ativa MD460 paper shredder: misalignment light is on - Fixya
www.fixya.com/.../t7580117-ativa_md460_paper_shredder_misalignme...
Jan 1, 2011 - I have a Ativa MD 1000 that I just bought. It ran for a few minutes the first time I used it an then stopped. I turned it off and unplugged it in case it had ...
Office Depot Ativa DQ60M Shredder Misaligned - Questions ...
www.fixya.com > ... > Office Depot Ativa DQ60M Shredder
just purchased ativa MD 460C and it will not work. misaligned is highlighted. can u help... I have an Ativa MD 460c paper shredder that reads misalignment.
Jun 07, 2011 | Office Depot Office Equipment & Supplies
I have a Ativa DQ60M Paper Shredder and it is very clogged with paper and it looks like some of the blades are slightly bent. Can it be sent in for repair or warranty?
Take away info: 3-year warranty on cutter.
Office Depot item #405935: Ativa DQ83M Diamond-Cut Shredder (mine show model ...Mn. It has a 1-year warranty for product, BUT ALSO a 3-year warranty for the "cutting cylinders". Call 1-877-777-HELP; www.ativaproducts.com .
I called 12-29-2010. Rep had difficulty finding product, put me on hold, found it. Said prod only has 1-yr w (per Office Depot online, this is all that is given as to info); but I said, no, 3-yr on cutter. I held again, rep researched and agreed. I took a case number and tried rep's troubleshooting suggestion: I put 3-in-1 oil (veg oil suggested by rep too) on the jammed shredded paper (machine still would go in reverse BTW); I let it soak 5 mins, removed paper, tried shredding, and paper jammed again. No replacement parts are avl. I called again, gave case number. Rep suggested I oil the cutter now that paper was removed. I said cutters are oiled from removing paper. I was put on hold, only a short while.
Good outcome thus far: I was given fax number and instructions to receive gift card in 6-8 weeks upon their receipt of my fax (to 1-888-561-0785) of case number, name (first and last), mailing address, and copy of the receipt.
What I learned: Do the maintenance oiling monthly or more if needed! Try to buy a shredder that is beyond my shred needs, e.g., a 10-sheet cutter but use it only up to 8 pages. Try to buy a shredder that has replacement parts.
The price of the Ativa in 2008 was $40 ($30 instant savings taken at the register), and it didn't get daily or regular use.
Good product support on this Ativa product. Glad I saved my manual and receipt!!
Dec 22, 2010 | Office Depot Ativa DQ60M Shredder
Where can I find gears for the ativa Model DQ120Dn?
they don't make replacement parts. was designed to operate thru the warranty period then you buy another one. Fellows makes a better shredder.
Oct 29, 2009 | Office Depot Ativa DQ60M Shredder
Won't turn off
The optical switch may be clogged. UNPLUG the machine and remove all shreddings from under the cutters. Look down from the top and in the middle to be sure that there is nothing blocking the "electric eye" located there. Shredding labels or self stick envelopes can leave pieces stuck to the eye.
Jul 07, 2009 | Office Depot Ativa DQ60M Shredder
Need Ativa X1800 Shredder Parts
Hey check out this link they service all types of shredders hopefully they should be able to service yours.
http://www.factory-express.com/blog/2005/10/paper-shredder-parts.html
Jul 03, 2009 | Office Depot Ativa DQ60M Shredder
When I insert pages it start making a loud noise like if the blades are rubbing aginst the plastic. Has anyone have a solution?
Chances are with this model, you have overloaded the infeed and broke the plastic drive gears.
Good luck on finding service and parts because on these cheeper products, the parts are almost as expensive as replacing the machine.
Feb 19, 2009 | Office Depot Ativa DQ60M Shredder
My Ativa DQ60M shredder has damaged cutters in one spot. The paper packs in these cutter wheels and on occassion causes it to run continuously. Can I replace the cutter rolls?
Hi, I have checked into this with my shredders. There are plastic "cleaners" that break very easily and when they do, the cutters jam up. No way to get just the cleaners (that I have found). Very poor design. Only thing to do is to clean the rollers from time to time.
All of these types are shredders are mainly junk. I have one that is blowing the fuse. I am an electrical engineer and am trying to see what the fix is.
Jan 04, 2009 | Office Depot Ativa DQ60M Shredder
Main drive gear is damaged on and Ativa shedder
If you main gear drive is broken you probably had a paper jam, so your shredder blade gear will break soon. By the time you purchase the part and pay for the shipping it would cost just about the same as gettin a new one. Then you will not have to wotty about anything esle breaking after you get this part because of the stress you put on the motor and other gears. I hope this helps you.
Nov 25, 2008 | Office Depot Ativa DQ60M Shredder
Office Depot Ativa  DQ60M Shredder Logo
561 people viewed this question
Top Office Depot Office Equipment & Supplies Experts
Jim Keysor
Anthony Karuku
quennie732
Are you an Office Depot Office Equipment and Supply Expert? Answer questions, earn points and help others
