Question about Sony DVP-NS67P DVD Player
DivX certified player cannot read DivX files on DVD+R
I converted XviD ".avi" files to ".divx" files using the DivX converter and burned them onto a Maxell DVD+R disc. The properties of each DivX file seem to be consistent with those specified in the manual. However, the DVD player cannot read the disc.
Thanks in advance for any help!
(Sony DVP-NS67P DVD)
  • kirstenmacd Dec 10, 2008
    Wow, that was fast!
    There is a DivX logo on the player and the manual says it is capable of reading DVD+Rs. I did not try the "with menu" option -- according to the manual, the player should read the disc in data format -- but I'll try that next. If that doesn't work, I'll pick up some DVD-Rs, just in case.
    Thanks for your help! I'll let you know how discs with menus or, if it's necessary, -Rs work out.
    Thanks again!
  • 395 Answers
This site list what media it will play also
http://www.videohelp.com/dvdplayers/sony-dvp-ns67p/8666
Posted on Dec 10, 2008
  • Sony Master
  • 2,794 Answers
Is there a Divx logo on the player? Does this particular DVD player capable of reading DVD+R disks?
If you used the Divx converter program, there is a way to create a DVD in Divx format with menus. Did you use that particular program? If you didn't, you may have the DVD in a data format and the player can't read it that way.
  • Tim Babcock
    Tim Babcock Dec 10, 2008
    Goto www.divx.com and make sure you have the current version as well. They update that software on a monthly basis.
Panasonic DVD S48 - DVD player how to play movies over usb
Yes, I know Panasonic DVD S48, if your movie file is right divx avi movie file, you can directly transfer the divx avi movie file to your usb disk and play on your Panasonic DVD S48, but if your movie files isn\'t divx avi movie file, you have to use a right software to convert your movies to right divx avi movies, then transfer to your usb disk, convert any movies to divx avi movies.
Dec 06, 2013 | Panasonic DVD-S48 DVD Player
Tip
How to convert XVID VBR MP3 and DIVX CBR MP3 using ConvertXtoDVD
Most Philips DVD players with DivX will play Stage 6 or VOD MP4 Video files if the FOURCC is set to DX50 or DIVX and the MP3 or AC3 audio is at a constant bitrate CBR of at least 192kbps, this is also the DVD Video audio standard in AC3, DTS or LPCM.
However with either DivX OR XviD video with VBR MP3 audio you will experience audio lag on playback the trick is to get the audio track in to a constant bitrate CBR and if possible with the audio frames Aligned on the interleaves as opposed to Split across interleaves.
If you plan on keeping the video in MP4 AVI v2.0 format then you MUST convert the audio to a CBR in either MP3 or AC3 format using one of the methods shown HERE.
If you plan on converting the MP4 video into DVD format you can first try to use the excellent ConvertXtoDVD this will attempt to convert the audio track into 192kbps CBR dolby digital AC3 audio whatever the source AVI audio.
If this fails to give you DVD Video without audio sync problems then you must convert the MP4 to a CBR audio and a FOURCC of DX50 to ensure Home Theatre compatibility.
on Feb 11, 2010 | Philips DivX DVD Player
Hello there, Something I cant understand, my
Your DVD player will accept only Divx disc ( AVI files ) So use an encoder to convert your files into AVI before you write them.
The standard DVD is a format called MPEG 2 and don't confuse it with MPEG4.
Download the program for free from the link given below for your conversion.
http://www.ojosoft.com/how-to-convert/mp4-to-divx-converter.html.
Apr 03, 2011 | H&B DX-3220 DVD Player
Cant open demuxer
If the "Cannot open demuxer" error appears it means the Avi encoders on your system are either missing or corrupt. Please use the following links below to download and install Divx and Xvid encoders. A good way of telling if your Avi encoders are installed properly is if the AVi file being used can play in Windows Media Player correctly.
You would simply need to download the appropriate codec you are attempting to convert to, and also the Windows Media Encoder.
DIVX
www.divx.com
XVID
www.xvid.com
www.microsoft.com/windows/windowsmedia/forpros/encoder/default.mspx
Jan 30, 2010 | Bling Software 123 Copy DVD Gold 09
I have a portable Kawasaki DVD player. It does not play AVI videos. Tellme what to do please.
This normally depends on what FOURCC the AVI has encoded inside the file.
Look here at my DivX Rox!! facebook group for the correct DivX FOURCC that will normally work on most standalone players on AVI with FOURCC =DIVX or DX50
Most DVD players that have DivX support require these two FOURCC tags, DIV3,DIV4,DIV5 and DIV6 wont always work but sometimes you can change this without re-encoding using a batch FOURCC changer.
As a general rule of thumb even when you change the FOURCC of the AVI you may experience audio lag on the file it is best to convert all AVI's to DivX using the DivX Convertor that is available with the DivX Professional codec costs $19.99 (£13.99) and is well work the money.
I have had some success with Xvid AVI's with FOURCC XVID but with audio lag and video jerks.
Jan 06, 2010 | Philips DivX DVD Player
My Samsung DVD-P390 player doesn't see downloaded avi files on my USB memory stick. Any thoughts?
I have the same player and also had teh same problem hooking up an external drive to it (Iomega 320 prestige) This player will only recognize the FAT32 file system.Have your USB formatted for Fat32.I know, I worked for hours with my buddy trying to get his external drive working with his ps3..same thing.
Nov 14, 2009 | Televison & Video
I just bought and set up the vhs to dvd program but when i coppied the video onto the disc and tried to play ti in the dvd player it said disc error.i made sure i followed the hook up directions.help!
You have either used a disc that is not compatible with your dvd player, or used the wrong file system for the dvd and/or format, have not finalized the dvd recording.
If you use a dvd-r for recording, the disc has to be finalized, regions use different formats of video(UK=PAL, USA=NTSC)
The easiest way to use your disc would be to convert the video to avi format(xvid divx mp4/3) and burn to a disc as data format.
Download ANY VIDEO CONVERTER FREE,
and ASHAMPOO BURNING STUDIO6 FREE .
Use the converter to change the video to avi, use the studio to burn the video as a data disc, you can get up to 14hours per standard dvd(28 hrs on a dual layer). Put the disc in and it will play as a DivX dvd.
Aug 14, 2009 | Computers & Internet
Does not play divx/mpeg4 files on dvd disk!!
The player plays strictly DIVX files, but not variants like XVID (which today is more common since divx became not free).
Divx is actually the same than XVID. After spending days converting my files from xvid to divx, realized that changing only the FOURCC code of the files works.
Look for a program named videoinspector. It allows to edit the fourcc for a video file. for all xvid and variants change the fourcc of the files to DIVX. The change takes a second instead hours of conversion, and movies in xvid that used not to play on this device, now will be played without problems.
Apr 08, 2009 | Philips DCP851 Portable DVD Player
DVD movie onto a CD-RW
first off, your not going to get dvd quality on cd, if ur talking about a standard dvd that u wish to put on cd, dont even bother.
4GB(DVD) to 700MB(CD) ? re-encoding it to that size will look like crap.
enjoy
Feb 28, 2008 | Televison & Video
Sony DVP-NS67P DVD Player Logo
565 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
