Question about Philips Magnavox 20MC4304 20 in. TV/VCR/DVD Combo
Dvd won't come out
The dvd drawer only comes out about a fourth of an inch and when i push the button for it to go back in it only moves just a little bit. what can i do to fix this?
  • chanel kansier Mar 02, 2007
    the dvd will not play once it is in either.
HOW DO I REMOVE DVD DISK FROM TV
Press the little button on the DVD drawer. If it is jammed and you can see a small hole in the drawer, open up a paper clip and make it nice and straight with pliers. Insert this into the hole and push firmly and the drawer will pop open.
Also look on the remote for an EJECT command.
The blurb is here, but no manual for download.
19 Class LED Widescreen HDTV with DVD Player
Sep 12, 2015 | Supersonic 19 Inch SC-1912 12 Volt AC/DC...
Dvd door will not open or close when eject/open button is pushed. I can open door and slide tray out by hand, howevery when disc is inserted in tray and pushed back in, system does not read disc as being...
The low humming sound is the motor that opens and closes the drawer. It is moving, but the movement is not being transferred to the door by a pulley, a belt or a gear, When you open the drawer completely, it should stop. When the drawer is closed completely it continues to run until the disc is in the proper position to play. As long as that motor is running the DVD will not work because the disc is not in the proper position,
Feb 03, 2018 | Panasonic PV-D734S DVD Player/VCR
I can't open the cd drawer
If pressing the button on the CD/DVD drive does not open the drawer you can look for a small hole on the face of the drive, usually just below the drawer and about 1/3 of the way in from one side. Straighten out a paperclip and insert it into the hole. It should go in about a half inch then stop. Push a little harder and it will travel farther in and release the drawer.
Nov 02, 2013 | Computers & Internet
Samsung Optical Drive SE-208 tray rattling won't eject
if you look on the drawer you will see a little hole.push a pin in the hole and the drawer will open.
Nov 15, 2012 | Samsung Optical Drive SE-208AB/TSBS...
MY BUTTON IS STUCK ON THE DVD-ROM TRAY. WHAT DO I DO?
if you look on the drawer for your dvd drive, you will see a little hole.If you push a pin in the hole the drawer will open.
Aug 20, 2012 | Computers & Internet
Dvd drawer won't open
stick tip of pencil in tiny hole just under the drawer
Dec 30, 2011 | Sony RDR-VX560 DVD Recorder/VCR
The top dish drawer turns on but won't go. It comes up with a little clock and counts up to about 11 or 12 then goes off. It continunally beeps and won't actually start up.
Somehow your drawer was put into a showroom mode. In this model, with the power off, push ECO and Power button for 5 seconds. (ECO first then Power and hold for 5 seconds) this should clear this out.
If you still have issues seen me another message and I will respond as quick as possible. Taking my daughter out to a party tonight.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 27, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
My dvd won't eject after playing.
What exactly do you mean? A DVD or CD will not automatically eject. You must tell it to.
If, however, you mean that when you press the eject button it doesn't come out, then the drive has a problem. You can push a paper clip in the little hole in the front and the drawer should come out. If you can eject it manually but not with the button, then your drive is bad--perhaps something broken in the button.
You can also go to "computer" or "my computer" and right-click on the CD/DVD drive and choose "eject" to see if it works by using software.
Jul 19, 2010 | HP Pavilion dv7-1130us laptop
DVD drawer does not open when you push button to open DVD drawer
The most likely cause is damage, which should be seen with the eye. It could be a belt, broken cogs/teeth in the sledge mechansim, or a micro leaf switch bent out of place.
Apr 05, 2010 | HP dc4000
Dvd player not working
the disc may be jammed. try using a paper clip straightened a bit and insert into the little hole in the front of the dvd door. that should release the dvd drawer. if the drawer can not be pulled out because of a disc jam, you can try to close the drawer again and gently shake the dvd player side to side, front to back to jostle the disc back into the tray/drawer. then try the eject button again. failing that, you can try to remove the outer case and that ought to give you access to the disc, and allow you to see where it is relative to the tray.
try that and let me know how you are progressing with this problem
good luck
mark
Dec 29, 2007 | Televison & Video
Philips Magnavox 20MC4304 20 in. TV/VCR/DVD Combo Logo
44 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
