Question about Pride Mobility Products New Pride Mobility Jet 3 Ultra Power Wheel Chair
I need a charger for chair its a jet model 2904jt-24. can you tell my how to order
  • 151 Answers
You can find a charger here.
Posted on Dec 28, 2008
Need manual for model 2904jt-24
Could it be the Pride Mobility Mobility Jazzy J3 2904JT-24 model?
If so,click on the link below for the manual downloads.
Hope it helps.Thanks!
Jan 05, 2012 | Dishwashers
Have a jet 3 power chair will not take a charge, can't tell that iy is charging
Cathey when you plug in the charger look at the rear of the chair at the meter if the chair is charging then the meter will indicate some amperage reading when it is fully charged the meter will read zero. Also turn on the chair and if the lights are scrolling or flashing it shows that the charger is plugged in. Now if after the meter reads zero (if it ever does) the lights on the joystick should all be lit indicating a full charge. If you aren't getting all the lights and the meter indicated the charger was working then you need to replace the batteries Hope this helps
Mar 24, 2011 | Jet 3 Ultra Power Chair
I have a JET Mobility Model 2904JT-24 Battery Charger that I would like to use to charge a 24-V project I'm working on. It's from a Pride Jet 2 HD. Trouble is, I only have the charger (no wheelchair) and...
Blue Positive Brown negative, Yellow with green stripe is additional ground. many people are trying to use the 2904JT charger for a 24 volt charger for other things. I am using mine on an e bike that has 4 12 volt batteries. I charge them 2 at a time and it works well. It only shows voltage when the batteries are partially charged. Some kind of safety feature to keep you from charging a shorted battery. No schematics available, I took my chances and verified the Blue wire is positive. lol Good luck with you project or re wire. : )
Jan 24, 2011 | Pride New Mobility Victory XL 4 Wheel...
I want to know how to find out the exact model of my chair in order to buy a battery and a charger
sagitarious you will need 2 U1 batteries and should purchase a 4 amp off-board charger with a cooling fan and on-off switch. MK batteries makes an excellent charger and you can check their web-site to see if you can order from them. Of course there are other good chargers out there. You could check with your local provider and ask if they could order one for you. MK makes excellent batteries and will last 3-4 years if taken care of and charged correctly. Hope this helps you
Sep 19, 2010 | Jet 3 Ultra Power Chair
Need a battery charger for jet model 2904jt-24 3stage
Check around the neighborhood for others who have chairs. Any 4 amp charger for a wheel chair will work for you. You can try E-bay also. Your provider will wanna charge you a good bit for a new charger so check in the neighborhood first to borrow one until you can get one Hope this helps
Aug 22, 2010 | Jet 3 Ultra Power Chair
Have 110 ac going in nothing coming out where can i get a charger model 2904JT-24 Automatic 3 stage Battery Charger 4APK@24VDC 60A.HR. Sealed L>A>
Contact a service provider in your area that sells power chairs they shouldn't rape ya for a charger but you should be able to get one for $125.00 or so. You could also find a neighbor that has a chair and borrow their charger it'll work too Hope this helps
Jul 22, 2010 | Jet 3 Ultra Power Chair
You didn't state what model of power chair or scooter you had but you can use any charger which outputs the same AMP's and has the same connection. Also try South West medical they will sale to the public. Click the link below and you will see the charger you are talking about.
Hope this helps. If my solution worked for you please rate the solution as to help others who may have the same question.
Thanks for using and have a great day.
Feb 05, 2010 | Pride Mobility Products New Pride Mobility...
My chair wont charge in either of the charging ports
It's either a dead charger or dead battery(ies). You will need a voltage tester meter to check. First check the charger by setting your meter to a setting over 24 volts (your chair is a 24 volt system). Test the voltage at the charging port by placing the two probes into the two outside ports (there's three ports in a triangle...test the two opposite ports.) You should get a reading in excess of 24 volts but less than 26. Now plug the charger into one of the ports and check the voltage again. If the voltage is now higher than the first reading, your charger is working and you will need to replace the batteries, if it is the same, your charger is bad.
Aug 06, 2009 | Pride Mobility Products New Pride Mobility...
Pride Mobility Products New Pride Mobility Jet 3 Ultra Power Wheel Chair Logo
340 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
