Question about ASUS P5RD2-VM Motherboard
P5RD2-VM mobo will not post at boot
I have removed all add-on cards, and am booting with only CPU, memory, and PCI diagnostic post card.
This board has AMI BIOS. My boot diagnostic card returns audible alarm 1 long beep followed by 2 short beeps, which is supposed to mean "An error was encountered in the video BIOS ROM, or a horizontal retrace failure has been encountered."
What would my next course of action be?
  • ontheteam Dec 11, 2008
    3 beeps were in fact cured by re-seating the memory.(Pretty picky apparently)
    I am still stuck. I get the ASUS green light, CPU fan powers up, but system still fails to POST.
    My POST card only logs one event before the system hangs. On most occasions I get "A0" code and others I've gotten "80".
    I have removed and re-installed the CPU and heat sink more than once. Still no joy.
    I did clear CMOS by removing the battery and capping the appropriate jumper. All that did was change the initial POST code.
    I am get absolutely NO video from the onboard VGA.
  • 341 Answers
Three beeps for that bios is a memory error.Are you sure it's not a memory issue? Did you clear the CMOS and try to boot up again?
Posted on Dec 10, 2008
Added 1G memory, for a total of 2GB. the system still only sees 1G
If you installed total 4GB memory, the system will detect less than 4GB of total memory because of address space allocation for other critical functions, such as:
- System BIOS (including motherboard, add-on cards, etc..)
- Motherboards resources
- Memory mapped I/O
- configuration for AGP/PCI-Ex/PCI
- Other memory allocations for PCI devices
Different onboard devices and different add-on cards (devices) will result of different total memory size.
e.g. more PCI cards installed will require more memory resources, resulting of less memory free for other uses.
On a SLI system, since PCI-Ex graphic cards will occupy around 256MB, another 256MB will be occupied after you install a 2nd PCI-Ex graphic card. Hence, 2.75GB memory left only if two SLI cards installed on A8N-SLI Premium while 3.0GB memory left with one graphic card without other add-on devices.
This limitation applies to most chipsets & Microsoft Windows 32-bit version operating systems.
If you install Windows 32-bit version operating system, we recommend that you install less than 3GB of total memory. If more than 3GB memory is required for your system, then below two conditions must be met: 1. The memory controller which supports memory swap functionality is used. Chipsets later than Intel 975X, 955X, Nvidia NF4 SLI Intel Edition, Nvidia NF4 SLI X16, and AMD K8 CPU architecture support memory swap function. 2. Windows 64-bit OS which can address more than 4GB memory. You can check below URLs for reference:
http://dlsvr.asus.com/pub/ASUS/mb/4GB_Rev1.pdf
hope this helps
Apr 18, 2011 | ASUS P5RD2-VM Motherboard
Is nvidia 9600gt graphic card compatible with asus p5rd2vm motherboard
Yes.
1) The Asus P5RD2-VM motherboard has a PCI Express x16 slot.
The Nvidia 9600GT uses a PCI Express x16 slot.
2) The PCI Express version used on the Nvidia 9600GT is PCI Express 2.0
The PCI Express technology used on the Asus P5RD2-VM motherboard is PCI Express 1.1
The motherboard chipset used on the Asus P5RD2-VM shows us this.
The motherboard chipset is an ATI RD480. (Before AMD bought ATI out)
The ATI RD480 chipset came out September 27, 2005.
http://en.wikipedia.org/wiki/Comparison_of_ATI_chipsets#Comparison_of_Northbridges
Scroll down until you come to > RD480 in the left column, then read across.
The PCI Express technology started under another name, then was changed to PCI Express.
The first version was PCI Express 1.0
Then PCI Express 1.1
In 2007 (January 15) the PCI Express 2.0 technology was brought out.
The PCI Express 2.0 technology is Backward Compatible with the PCI Express 1.1 technology.
(With PCI Express 1.0 also, but it depends on the graphics card being used)
In otherwords, a graphics card that has been based upon the PCI Express 2.0 technology, will work on a motherboard based on the PCI Express 1.1 technology.
You won't get the full capability of the PCI Express 2.0 graphics card.
Will you notice?
NO.
[ If I had my choice I would run an Nvidia 9800GT instead.
Depends on the price, and availability of the 9600GT I would assume, though.
You may also need a more powerful Power supply.
Example, not advertising,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6391081&CatId=3670 ]
Nov 03, 2010 | ASUS P5RD2-VM Motherboard
Have Comp. w/Asrock MOBO.It's been sitting
For that open cpu cabinet
Reattach the RAM memory.
Open processor fan and processor reattach both.
Make sure motherboard circuit could not ground with cabinet.
Pull cmos cell from motherboard for 10 minutes .
Remove pci cards from motherboard if any.
Reattach VGA card if installed.
Then check.
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 13, 2010 | Computers & Internet
Packard Bell IMedia 5055: GA-8SIML will not post or boot. Removed all PCI cards,RAM,Hard drive, optical drives etc. Only CPU and mobo but no post/BIOS screen. CPU fan runs and front panel LEDs work. Do get...
Put just the ram back into the motherboard, the pc will not boot without processor, ram and graphics pluged into the board, check this, if it will still not boot and you still get 3 beeps its a memory(ram) problem, and you will need to replace the memory stick.
Feb 04, 2010 | Gigabyte GA-8SIML Motherboard
Firstly you check your RAM by use another RAM and then check it is working or not, after that if display is not coming then check your processor it is fitted properly or not if it have fitted and display is not coming then *********** board's winbond chip have been damaged.
Repair it from a techinician.
Regards
Ashly
Expand graphic card
Hi!
First of all i want to sugest you to make sure that you have maximum of memory, you gona need it if you want to edit videos.
If you want to do video editing the most inportant component is the CPU, then comes the memory, after the memory come the HDD, and after that the GPU
Now the GPU, you have a pci-e 16x port on that MB, so i will give you 3 diffirent sugestions, from a not that expensive to a more expensive to the third that is expensive but not the most expensive GPU there is, all of the very goos for vidoe editing.
1) SAPPHIRE RADEON HD4670 512MB GDDR3 PCI-E VGA/DVI/HDMI
2) SAPPHIRE RADEON HD4870 512MB GDDR5 PCI-E DVI
3) ASUS RADEON HD4870 DARK KNIGHT COOLER 1GB PCI-E DVI
There u have 3 very good GPU:s, but as i told you the most important is the CPU and the memory!
Good luck
Nic
Apr 02, 2009 | ASUS P5RD2-VM Motherboard
D845SVR mobo - no boot
Before trying anything, try another monitor. Or try you're monitor on another system. Swap the video cable with another. (This is a must try). The reason it’s a must try is because you hear the drive run, the fan's are running & the LED's are flashing. Once you are sure both are good than reset the bios.
(You typed, D845SVR as you're board). There is no such Intel MB. I think you meant to type, D845GVSR.
Unplug the power cord from the PC, open you’re case & touch any bare metal on the inside of the case surface before touching the mother board.
Please go to page 10 in you're manual. Make sure letter "D", the 12 V power connector is secure. Remove & re-seat it. Go to page 37 for instructions if you need a little help resetting the bios jumper. Move the jumper to pins 2 & 3 for 15 seconds. Than move back to default, pins 1 & 2. The link listed below is Intel's main web site for the MB D845SVR.
http://support.intel.com/support/motherboards/desktop/D845GVSR/
If you no longer have you're manual, you can download it at the link above. By resetting the bios, you are manually changing the bios to its default settings. Plug the power cord back in.
Try booting the system. You should get display. If you do not, than you're onboard (Integrated graphics), is most likely bad. A work around would be to add a PCI video card. The only other option left that I can think of is, it is possible that the CPU thermal grease between the CPU & heat-sink has dried. This will & can cause you're CPU to heat up. It may have overheated the CPU. PC repair is trial & error. Cleaning & replacing the thermal grease may allow you're system to function.
Here are a few PCI graphics cards you could try if you wish to buy.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=319&name=PCI-Video-Cards
Once a PCI video card has been added, the bios will use the PCI card without you needing to make a change in the bios.
Good Luck!
Mike
Jun 22, 2008 | Intel Motherboard
No beeps on boot up with asrock mobo? help plz
While booting BOIS goes for POST check for detecting the all the hardware .
Disconnect all the connection to DVD, HDD, FDD from MOBO.
Rmove all RAM and start the ssytem from testing RAM Serviceability. If you listened a long intermittent beep place a single pices of RAM in MOBO ( repeat test with other RAM also).
Other wise your video card is unserviceable, if you have any addon plugins like NVIDA graphics card you can check
Jun 10, 2008 | Asrock K7S8X-R3 Motherboard
Asus p5rd1-vm motherboard problem of graphics card
Hi shuter. Your Asus P5RD1-VM has an integrated video adapter ATI® Radeon 9600 GPU. You need to enter your bios & change the video start up order. Pg.2-22 in your manual.
Configuration options: [IGD] [PEG/IGD] [PCI/IGD]
Boot Graphics Adapter Priority [PEG/IGD]
Save & exit. Check system at boot up for correct memory count.
Thanks for using FixYa & if you need more help just re-post here. Have a good one!
please vote...
Feb 29, 2008 | ASUS P5RD1-VM Motherboard
ASUS P5RD2-VM Motherboard Logo
351 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
