Question about Pioneer PRO-100 TV
Television will not turn on as well
I'm having the exact same problem as the gent previous but I'm looking to fix it myself if possible. Is there a particular manual that describes what I'll need to do with the high voltage area? Since I've never fixed a television before is this a very difficult fix? Anyhow I'm psyched that you provide assistance and appreciate any help. Thanks.
  • Anonymous Jan 14, 2009
    i have a pioneer elite pro 151fd and two red lights show
Hello pro-100/200 owners..My Pro-200 would shut-off at times, also no picture, remote didn't work...Found all vertical standing
boards had come loose from main board connectors on left side
of main circut board..(as viewed from rear)..I removed main board
w/power unplugged, marked connectors, removed vertical boards
fastening screws from frame..Then reseated all boards..also checked for broken soder-joints on bottom of main horizontal board.Reassembled ++ w/several long cable ties put together, secured all vertical boards to horizontal chassis..All problems
disappeared.. Hope this helps w/ your "Fix"(note: I'm a former TV
tech, so be careful if you are unsure of This repair.)
Posted on May 19, 2008
The only thing you can do is to check the blow fuse and change and other -deep-trouble ONLY THE KNOW HOW TECH.CAN DO,THE THING YOU CAN DO IS WATCH WHAT CAN DO TO YOUR TV
Posted on Mar 02, 2007
    Sergeant:
  • 310 Answers
Hi, afraid Tvs aint somthing i fix but i found this service manual thought it might help. http://www.tradebit.com/filesharing.php/1/132 All the best John
Green power light comes on then 20 seconds later the red stand by light flashes 6 times & keeps trying to turn on, can hear it clicking but nothing comes on screen only red light flashing. can prob fix...
These flashes are called blinking codes, and are fault indications. If you wish to get more details to these blinking codes, check the site linked here. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Oct 02, 2013 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Tv won"t turn on, previously it would ramdonl turn
Sound like a fuse inside. Look for a glass fuse about one inch long and with a steel cap at each end and it is about 1/2" round.
Oct 31, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
When I turn it on, immediately there is a red lamp lighting and the printer stops to work. It happened this evening for the first time. If you can not help me, then I wish to find a shop to fix my...
Check the smart panel program for the exact cause of the printer fault. My guess would be the waste toner tank needs to be clean/replaced. Hope this helps you.
Oct 22, 2010 | Samsung CLP 300 Laser Printer
The television will not turn on, its as if the switch that turns on the tube is broken. i can hear the switch turn on but the picture or television doesn't turn on. the nearest tv repair shop that can fix...
take back off and check if fuse has blown. replace fuse with exactly same type and size. if fuse blows again it is unlikely to be the on-off switch.you may be lucky and fuse doesn't blow. tv will start up.
Jan 24, 2010 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
42PD6600A and EXT-6
I have the same problem with my 42PD6600. Spoke to the gents at Hitachi who tell me there is no automatic way to do this so you have to scroll manually to the correct source via the remote.
Mar 05, 2009 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
Pop fuse when pluged in
yes it may very well be the horizontal output transistor or the voltage regulator ic or a shorted rectifier diode on the power supply or the b+ capacitor on the powersupply good luck
Jan 20, 2009 | Televison & Video
Crossed electrical circuit fried my Hitachi 42" proj tv...
depends on exactly you fried quite possibly you just need to file it on you homeowners and say lightning hit it
Jan 02, 2009 | Panasonic PT-47WX49 47" Rear Projection...
I have a 52 inch sony rear projection tv, model number kp61s75 with a convergence problem, can i fix it myself or do i need a tv repair man to fix it?
you can go into the menu and manually adjust the convergence it will look better most likely but a television should always be converged by a professional when first bought any way because they can do things we at home cant. i have mine done by a professional once a year and do it myself once a month to maintain the best possible picture. good luck
Sep 22, 2008 | Televison & Video
How do I replace the Power/scan board on my Dishnetwork HD34-300 Monitor
please respond to this same post with your model number and I will assist you with your problem.
Sep 19, 2008 | Televison & Video
Pioneer PRO-100 TV Logo
262 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
