Question about Philips TV Tuner Video Capture PCI Card - Phillips Digital (652101138177)
Menu screen stays on. philips model# 32PF7320A/37
Menu screen stays on. If you get it to go away comes back in a couple of minutes. At times it won't let you move around in menu you choices. Flips back to one command
    President:
  • 2,992 Answers
If you are talking about a continuing display of features and menus, press the Volume Up and Volume Down buttons at the same time to shut off that display.
If the problem is that the set acts like you are pressing the front panel button and random things happen, there may be bad switches. Sometimes if Windex or other cleaners have been sprayed on to clean the picture tube, they can drip down onto the board and cause corrosion which makes the switches funky. They need to be replaced and the board cleaned of any residue.
Posted on Dec 11, 2008
I have philips tv model # 32PF7320A/37. I do not have sound however the sound comes out about 20 to 30 later the tv is on. Can you help?
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Jun 17, 2016 | Philips Televison & Video
My tv information at the top left of the screen will not go away i have pressed every button on the remote and still won't go away
Look in tv menu for:
SETTINGS / SETUP
MENU PREFERENCES
Set OSD to MINIMUM.
See page 15 of user manual at following link:
http://download.p4c.philips.com/files/3/32pf7320a_37b/32pf7320a_37b_dfu_eng.pdf
Good luck and let us know if it works.
Jan 21, 2011 | Philips 32PF7320A 32 in. LCD Television
My Phillips Plasma tv MENU pops up unasked and obscures screen.
there is a soft ware upgrade for that problem on there web site you can down load it to a thumb drive and upgrade your set
Oct 31, 2009 | Philips 32PF7320A 32 in. LCD Television
My tv keeps reverting to the Philips TV Menu
If that TV has a 'menu' button on the front of the set, make sure nothing like coca-cola has spilled into where that switch is located. I would try a different remote in case the remote is getting flaky....
Oct 21, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
No data is sent to the screen
When the screen goes completely black, shine a very bright flashlight closely at the screen. If you can see the image, then the most likely problem is that the backlight inverter has failed.
The inverter is a circuit board that works like a flourescent light ballast. If the inverter fails, there is no backlight, and the screen is black.
Since the invertor is a high-voltage component, I would also listen for any unusual sounds associated with the failure: e.g. buzzing, whistling, popping.
To rule out some sort of connection failure, see if you can recreate the failure mode when using the TVs internal setup menu. The setup menu does not rely on any external inputs....of course neither does the volume control or channel indicator on the screen.
Oct 07, 2009 | Philips 32PF7320A 32 in. LCD Television
My Philips flat screen tv model 37PFL5332D/37 will not come on...what should I do to reset my tv
The only way to reset it is to leave it unplugged for 24 hours. If resetting it doesn't help let it turn on, you may have to replace the power supply
Jul 09, 2009 | Philips 32PF7320A 32 in. LCD Television
Menu on a Philips-32PF7320A-37B
try leaving the TV unplugged overnight (at least 8 hours). this should reset televison to origional defaut settings. If you are using a remote, you should use new batteries or put it in another room and use menu buttons on the tv itself it is equiped.
Mar 31, 2009 | Philips 32PF5320 32 in. HD-Ready LCD...
32 Philips hd flat screen #32pf7320a/37b on for a time,then black
check the capacitors in the power supply that is the first thing to do, just check if anyone is swallen or pregnant jajajaja that's how some people call it
Dec 15, 2008 | Philips 32PF5320 32 in. HD-Ready LCD...
Philips 17PF9936/37 17'' Flat HDTV slow to start working
mi tv turns on but only in color blue,next tv turn off red light apear one time and second time flash twice,whit mi remote control power on tv turs on ,then whit mi remote control send change chanes or any other funcion the tv turns off,letme now if you solve yor problem ,and i apreciate if you have some tips for me,thank.
Jan 09, 2008 | Philips Epic 17PF9936-37 17" Flat Panel...
Philips 32PF7320A black screen
If the power lamp is flashing 5 times when it does this, you may need a new power supply. Otherwise, I would suspect a bad (solder) connection in the power supply.
Jan 14, 2007 | Philips 32PF7320A 32 in. LCD Television
Televison & Video Logo
195 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
