Question about Canon PIXMA iP90 Mobile Printer
Ink absorber is full and printer won't print
Ink absorber is full and the printer will not print.
    Guru:
  • Canon Expert
  • 183 Answers
Dear caucoin,
This message appears when waste ink absorber capacity rise to about more than 95 %. To fix this problem you need reset waste ink counter and it strongly recommended that you replace waste ink absorber (integrated in print base unit). Due to complicated disassembly process i suggest you to take the printer to nearest service center. For emergency reason you may perform below procedure to reset waste ink counter:
  • Plug in power cable
  • Press POWER button while holding down RESUME/CANCEL button then release RESUME/CANCEL button (do not release POWER button)
  • Press RESUME/CANCEL button two times while holding down POWER button then release all button (printer entering service mode and light stand by in green).
  • In stand by condition, press RESUME/CANCEL button 4 times (light will flash alternately in orange & green each time the button pressed).
  • Turn off printer and turn on again.
Now your printer back to normal condition. Hope this will be useful for you and don't forget to rate me.
Regards,
Source:
Canon Inkjet Forum
Posted on Dec 13, 2008
It is saying that the ink absorber is almost full how can we change this
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible. Press the button to cancel the error. You will still be able to print for a short period. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. There are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk. I will not advise you as it is not a permanent solution.
Sep 21, 2011 | Canon PIXMA MX850 Multifunction Printer
Printer won't print. Says to contact service
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Press the <RESUME/CANCEL> button to clear the error (1700)
Waste ink absorber error 1700
The printer has a built-in waste ink absorber to hold the ink used during print head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the <RESUME/CANCEL> button on the printer to clear the error, so you can continue the print job. The printer will need to be serviced as soon as possible.
Dec 10, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Ink absorber full
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible by pressing the <Resume> button on the printer. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk.
Nov 28, 2009 | Canon PIXMA iP1600 Printer
Waste Ink near full shows on screen. Won't print!
Hi ...
Cannon Pixma MP780 have an absorber and this error is related to this absorber.
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible. Press the <Stop/Reset> button to cancel the error. You will still be able to print for a short period. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset.
I would suggest that you take your printer to the nearest cannon service centre and get it repaired.
Don't forget to vote if this helps ... Cheers :)
Jul 17, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Absorber is full
Hi ....
Please vote if this helps .... Cheers :)
Jul 15, 2009 | Canon Pixma iP4500 InkJet Printer
Ink absorbers almost full in Canon Pixma iP 1500 how can I fix it yourself
Hi ...
Please vote if this helps ... Cheers :)
Jun 26, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Canon ip1800 ink absorber is full, cannot remove Cartridge
Hi ...
Jun 03, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Waste ink absorber almost full. What do I do?
Hi ...
May 04, 2009 | Canon I960 InkJet Photo Printer
My canon ip4500 says that the ink absorber is full contact the service centre
Hi ....
Do vote if this helps ... Cheers :)
Apr 29, 2009 | Canon Pixma iP4500 InkJet Printer
Ink tank absorber full
Hi ....
Jan 26, 2008 | Canon I990 InkJet Photo Printer
Canon PIXMA iP90 Mobile Printer Logo
372 people viewed this question
old marine
old marine
