Question about Dayton E52 Utility Heater
150K Dayton Heater, no spark
It worked one day, then the next, no spark. Any Ideas where to start?
  • 232 Answers
Check to be sure the Ignition Device (transformer) is grounded, first, then see if power is going in to the Ignition control. If power is going in, but there is no spark from the coil wire, then the transformer is bad (replacement part number 102482-01).
There are other parts the can create a no-fire situation, such as a defective Safety Control (reset), Therefore you must troubleshoot to find the exact problem in order to avoid throwing parts at the unit.
Posted on Dec 11, 2008
Car wouldn't run, now it won't start
Check the whole air intake could be clogged, also check to see if spark is getting to plugs.
Feb 13, 2014 | 2002 Subaru Outback
I have a husqvarna 261 chainsaw. it will start half the time....the other chance.i changed the spark plug.and im getting very good spark. took the carb apart and cleaned it. checked the plug when...
Hi, from what you have written I believe you have a faulty cdi unit. Carbys don't generally run perfectly intermittently. To test the cdi theory, close the sparkplug gap to approximately half normal gap. If the saw runs fine you have a faulty cdi, shorting ht lead or stop wire. Regards Phil.
Apr 26, 2011 | Husqvarna Garden
I am having a problem with my 170K BTU unit. The bearing went out and I replaced it. At the same time the unit is spraying fuel but won't light/ignite. We are in the middle of an artic front and I need...
Remove the top and turn the heater on. Look for the igniter and make sure it is working. I don't know which type you have, but it could be the spark plug type or may be a HSI (hot surface igniter which will just glow until the heater starts). If the igniter isn't working, you may need to clean the sparkplug and set the gap. You can also check the transformer for the igniter. If it is the HSI type make sure it isn't broken off. Also check the flame sensor.
Jan 11, 2011 | Dayton (3VE49) Oil Filled Liquid Fuel...
We have a Hydrotherm gas fired Furnace in our home
Sounds like a loose wire somewhere...
That can be a bugger to find...
if you wiggle the wires in the dark can you see any sparking...
also see if you can narrow down which wire exactly needs to be wiggled...then check the connections or look for corrosion at the ends of that wire...
Jul 31, 2010 | Dayton Gas Furnace Heater
Sym Mask 50 won't start
"Any ideas what could be going wrong?" Using WD40 as starting fluid.
Jul 20, 2017 | 2006 Daelim History
Have a dayton hanging garage heater when trys to start acts like gas valve not opening heaters brand new.what should i look for
I have never seen a dayton gas heater but I will try. If this is an LP Gas
System are you using a 30lb. Cylinder, 100 lb cylinder or a whole house
Next are you sure you got the right gas unit for the right gas system?
If using LP gas did you put an external pressure regulator before the unit?
Next is the a hot surface glow coil or a spark system ignition system?
If you have to hold the controller down and press a button similar to a outdoor gas grille is it sparking?
If it is sparking,did you bleed all of the air out? This could take several
tries on a new unit. Does this have a wall mounted thermostat that
controls the heater? Finally check to make sure that the gas valve
is switched on if it has that option.
Good Luck
Jan 14, 2010 | Heating & Cooling
Dayton E52 Utility Heater Logo
307 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
