Question about Microsoft Xbox 360 Console
Monitor will no longer display my 360
My Xbox 360 is connected to a monitor and has been working fine for awhile with the VGA HD cable. But last night while playing the sound was replaced by a high pitched interference noise that got increasingly louder. I tried to exit but it froze up so i switched it completely off then on again and now the monitor doesn't detect the xbox and says no signal. All the leads are connected properly and i can still hear all the sound fine. I even loaded up a game without the screen and could hear the noises. I also replaced my VGA cable with a brand new one but nothing changed. My concern now is it might be a fault with the xbox that i cannot fix so i would need yet another one. Any help would be greatly appreciated.
  • Jonathan Rayburn
    Jonathan Rayburn May 11, 2010
    Have you tried hooking it back up to a regular TV to see if the 360 will work on it?
    Sergeant:
    Champion:
  • 452 Answers
Problem caused by the GPU. I just fixed on the other day. you can fix them like the way you fix the 3 red light issue. you can get the repair kit for like $10. I got my from the site below.
Xbox360 Repair kit
Posted on Dec 10, 2008
No input signal VGA/Xbox
You are doing nothing wrong. The best thing to do, which you are doing, is to eliminate possible problems. Try a different cable, monitor etc until you narrow the problem down to a single component.
Aug 05, 2012 | Microsoft Xbox 360 Console
HP W2007 + Xbox 360 = Constant Sleep Mode
the monitor is bad
if it will not power on,
or show NOSIG< with XBOX on then turned off the monitor must show NOSIG>
why not test the monitor on any pc made even laptops VGA jacks works, so that works, its not the monitor.
and bad xbox video caused. but is not it. as you said.
the menu needs sync lines active. to pops the OSD button menu.
so the monitor is bad.
or the cable.
what is w2007, lets see.?
its old. at 1680 x 1050 @ 60 Hz
this old monitor runs CCFL lamps.]
im shocked it glows at all up to now.
ever do flash light trick test?
see got data, but no back light, CFFL is dead.
HP W2007
users guide last page.
This HP product contains mercury in the fluorescent lamp
in the display LCD that might
require special handling at
end-of-life:
that means CCFL died, also all do, soon.
(as short as 2 years, full time , they die. 20k hours)
out of your service manual it shows.
ccfl-wcj1avqu0msqxnqr1cdquwfl-1-0.jpg what any running pc connected the OSD menu most work
not in sleep mode.
if there is sinc, H/V pins active
that OSD must work or the blacklamp is dead
use flashlight see, there is data there, see?
Sep 09, 2017 | HP W2007 LCD Monitor
I hv an old style xbox 360 n i bought a vga hd cable.is it automatic 1080p
It depends on your monitor or tv's native resolution,
if your tv/ monitor is 1080p then you should be able to get 1080p in the xbox settings from the dashboard.
Also, any xbox 360 should display 1080p.
Hope it helped.
Aug 17, 2010 | Video Game Consoles & Games
How to fix a xbox360 to a hd tv
game shop hd cable set plug in play hope this helps
Jul 14, 2010 | Microsoft Xbox 360 Console
Can you use an xbox arcade on flatron LG L1810T? If so which setting does it have to be on as the tv is not recognising the xbox at all
HI,
Your LG LCD monitor has a white DVI connector for connecting the signal cable.
You would reqire either an HDMI to DVI(male connector cable for the xbox) so that you can hook the hdmi cable to the xbox and other end to your monitor.
The cable would look something like this
http://hardware.teamxbox.com/reviews/xbox-360/40/Xbox-360-VGA-HD-AV-Cable/p1/
Thanks
proton
Jun 06, 2010 | LG Flatron L1810T 18.1" LCD Monitor
I have an HPa6700y I purchased about three months ago.  At the time of purchase I installed a high-end graphics card myself (ASUS EAH4870 DK/1G Radeon HD) and it had been running beautifully until...
usually there are 2 problems: 1. a vga card overheat when running 3 games the vga card heats up. try using an case fan or adn a vga fan. 2. the game uses a high refresh rate in this case tri to set a default refresh rate from the vga driver. hope this helps
Jun 14, 2009 | Computers & Internet
360 won't let me use HD display settings
Have you set the actual monitor settings to 1080? sometimes you have to do that first. If it's not set first the Xbox will only recognize it's current settings.
Nov 07, 2008 | Microsoft Xbox 360 Console
Conncting a projector to xbox 360
you can get a VGA cable for your xbox
Oct 22, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
