Question about Cyberhome CH-DVD 300 DVD Player
Vido can't be seen only audio can heard we press the setup button and click the option vido and then selected yar.... option and pressed the enter button of remote and the vido picture disappear and only audio can be heard . please help to solve the problem.
  • 80 Answers
Dear friends,
Press and hold STOP button on front panel of the player more than 5 sec. The player reset after 5 sec.
Posted on Mar 25, 2009
Why do the headlights. Come on when any door is opened on my 2008 trailblazer
The Headlamps On at Exit and Perimeter Lighting modes can be adjusted using the steering wheel controls to select the wanted function as displayed in the driver information center. The Headlamps On at Exit selection will allow the driver to customize the period of time that the headlamps remain illuminated upon exiting the vehicle. This period can be adjusted from 0 seconds to 180 seconds. The Perimeter Lighting feature allows the driver to select if they want the headlamps and backup lamps to illuminate when the door UNLOCK button on the key fob is activated. This feature can be turned ON or OFF by using the driver information center steering wheel control buttons.
programming Features with the Driver Information Center (DIC)
To enter programming with the driver information center (DIC), perform the following actions:
Turn the ignition to RUN.
Place the vehicle in PARK.
Press the Personalization button on the steering wheel to enter personalization programming.
Automatic Door Locks
Continue with the following steps in order to personalize the automatic door locks:
Press the Select button in order to enter the menu. The first choice seen is the current setting.
Press the Select button in order to scroll through the following options:
• LOCK DOORS: IN GEAR
• LOCK DOORS: WITH SPEED
Press the Personalization button in order to advance to the next option.
• UNLOCK DRIVER: IN PARK
• UNLOCK DOORS: IN PARK
• UNLOCK DOORS: AT KEY OUT
• UNLOCK DOORS: MANUALLY
Remote Activation Verification
Continue with the following steps in order to personalize the remote activation verification feature:
• LOCK FEEDBACK: BOTH
• LOCK FEEDBACK: OFF
• LOCK FEEDBACK: HORN
• LOCK FEEDBACK: LAMPS
• UNLOCK FEEDBACK: BOTH
• UNLOCK FEEDBACK: OFF
• UNLOCK FEEDBACK: HORN
• UNLOCK FEEDBACK: LAMPS
Delayed Lighting
Continue with the following steps in order to personalize the delayed lighting feature:
• HEADLAMP DELAY: 10 SEC
• HEADLAMP DELAY: 20 SEC
• HEADLAMP DELAY: 40 SEC
• HEADLAMP DELAY: 1 MIN
• HEADLAMP DELAY: 2 MIN
• HEADLAMP DELAY: 3 MIN
• HEADLAMP DELAY: OFF
Perimeter Lighting
Continue with the following steps in order to personalize the perimeter lighting:
• PERIMETER LIGHTS: OFF
• PERIMETER LIGHTS: ON
Mar 13, 2017 | 2008 Chevrolet Trailblazer
NEC NDT-40 DVD/VCR has "child lock" engaged
Try this:
If you forget your password If you forget your password, you can clear it using the following steps: 1. Press SETUP to display the Setup menu. 2. Input the 6-digit number "210499" and press ENTER/OK. The password is cleared.
OR
1. Press DVD on the remote control.
2. Press SETUP. The Setup menu appears. 3. Use v / V to select the desired option then press B to move to the second level.
LOCK (Parental Control)
Rating Blocks playback of rated DVDs based on their content. Not all discs are rated. 1. Select "Rating" on the LOCK menu then press B. 2. To access the LOCK options, you must input the password you have created. If you have not yet entered password, you are prompted to do so. Input a password and press ENTER/OK. Enter it again and press ENTER/OK to verify. If you make a mistake before pressing ENTER/OK, press CLEAR. 3. Select a rating from 1 to 8 using the v / V buttons. Rating 1-8: Rating one (1) has the most restrictions and rating eight (8) is the least restrictive. Unlock: If you select unlock, parental control is not active and the disc plays in full. 4. Press ENTER/OK to confirm your rating selection, then press SETUP to exit the menu
Unlock New DG AU Move Select
Sep 18, 2016 | NEC Televison & Video
Fix volume control
1. Go into the Set Menu.
2. Press the AMP button on the remote.
3. Press the Menu/Set Menu button.
4. Use the Arrow Up Down button to select Manual Setup.
5. Press the Enter button to enter Manual Setup.
6. Use the Arrow Down button to select the number 3 Option Menu.
7. Press the Enter button to enter the Option Menu
8. Use the Arrow Down button to select D Multi Zone Set.
9. Press the Enter button to enter D Multi Zone Set.
10. Press the Arrow Down button to get to Zone 2 Amp
11. Press the Arrow button to the right to set the Zone 2 Amplifier to INT.
12. Press the Menu/Set Menu button repeatedly to exit the Set Menu.
Aug 09, 2014 | Yamaha RX-V757 Receiver
Samsung 4521f print fax received in memory
Changing the Fax Setup options:
1 Press Menu until "Fax Setup" appears on the top line of
the display.
The first available menu item, "Default-Change", displays
on the bottom line.
2 Press the scroll button ( or ) until you see the desired
menu item on the bottom line and press Enter.
If you select "Default-Change", you will see "Resolution".
Press Enter again.
3 Use the scroll button ( or ) to find the desired status or
use the number keypad to enter the value for the option
you have selected.
4 Press Enter to make your selection. The next Fax Setup
option appears.
5 If necessary, repeat steps 2 through 4.
6 To return to Standby mode, press Stop/Clear.
Read More..FAQs Mono Multi function Receive fax for SCX 4521F
and Tech Support Printer
Jun 27, 2014 | HP Office Equipment & Supplies
I need to set internet to my ks360 how do i doit
    1. Press Menu (left soft key)
    2. Select Connectivity
    3. Select Network
    4. Select Access points
    5. Press Options (left soft key)
    6. Select New access point
      Note Slide the handset open to access the keypad
    7. For the Name enter #Profile
    8. For the APN enter #InternetAPN
    9. For the User name enter #Username
    10. For the Password enter #Password
    11. Ignore Primary sever and Secondary server these are preset at 000.000.000.000
    12. Press Save (the OK key)
    To setup the Internet profile
    2. Select the Browser
    3. Select Settings
    4. Select Network Profiles
    5. Press Options (left soft key).
    6. Select New profile
      Note Slide the handset open to access the keypad.
    8. For the Homepage enter #Homepage
    9. Set Proxy to #Proxy (to change press the Navigation buttons left or right).
    10. For the IP address enter #InternetProxy
    11. For the Port number enter #InternetPort
    12. Scroll to Access point and set it to #Profile (to change press the Navi buttons left or right).
    13. Press Save (the OK key).
    14. Scroll to #Profile and press Activate (the OK key).
    15. The Internet is now setup
Aug 20, 2011 | LG Cell Phones
The store demo mode is stuck on my insignia tv. the user guide says go to menu and then setup and select plug & play. however the plug and play option is grey and it wont let me select it.
Are you using an HDMI cable? Go to input and select TV. Then you should be able to access the Plug & Play option and be able to turn off the Demo Mode.
Jan 03, 2011 | Insignia 42" Flat-Panel Plasma HDTV
How do I turn on the closed captions
hi,
u can switch on the closed caption option for ur tv by the following setup.
1.Press the MENU button. Press the up or down button to select "Setup", then press the ENTER button.
2.Press the up or down button to select "Closed Caption", then press the ENTER button
3.Press the ENTER button to select "Closed Caption". Press the up or down button to select "On", then press the ENTER button.
4.Press the up or down button to select "Caption Mode", then press the ENTER button
5.Press the up or down button to select caption mode you want, then press the ENTER button. Press the EXIT button to exit the menu.
ok
Dec 22, 2010 | Samsung HLN437W 43" Rear Projection HDTV
The voice and sound on my laptop is not working dell d10
Step 1 .Reset the default BIOS settings:
You can try resetting the sound default in the BIOS. Here's how:
1. Turn the laptop on. When the Windows logo first appears, press the F1 key or Dell key repeatedly until you see the BIOS setup screen appear.
2. Press the F5 key ( Setup defaults). In some other PCs depending on the manufacturer the BIOS at start-up will have one of the default options that have names such as - ‘Load Fail-Safe Defaults’ and ‘Load Optimised Defaults’.You will have to choose ‘Load Optimised Defaults’
3. Select Yes or OK, then press the Enter key on your keyboard.
4. Press the F10 key, then select Yes or OK to save the default settings. Press Enter.
5. Exit the BIOS and restart your system checking for sound.
( For most system's entering the BIOS will be the same but if it differs for your system, consult the operating manual for instructions on entering the BIOS.)
If this doesn’t work go to step 2
Step 2 . Configuring on-board sound in the BIOS:
The on-board sound setting in the BIOS should be Enabled. To enter the BIOS, turn on the laptop and when the first screen appears, press the F1 key /Dell key repeatedly until the BIOS Setup screen opens. Use the LEFT and RIGHT ARROW keys to select the Advanced tab. Press the DOWN ARROW key to select Onboard Audio Options and press ENTER. If Onboard Audio Options is not available, select I/O Device Configuration and press ENTER. If Audio Codec is listed, select it and press ENTER. Select either Enabled or Disabled depending on your configuration and press ENTER. Press the F10 key and then press ENTER to save and exit Start Windows and check for sound. If there is still no sound, continue to the next Step.
Step 3 . Reload the current sound driver
To do this, follow these steps
1.Click Start, type Device Manager in the Start Search box, and then press ENTER.
2.In the Device Manager dialog box, expand Sound, video, and game controllers.
3.Locate the audio device that was included with the computer.
4.Right-click the device, and then click Properties.
5.Click the Driver tab.
6.Click Uninstall.
7.Make sure that the Delete the Driver Software for this device check box is cleared, and then click OK.
8.In the Device Manager dialog box, click the Action menu, and then click Scan for hardware changes.
You should see a message that a hardware device is being installed. Additionally, the uninstalled audio device is now present in Device Manager.
9.Close the Device Manager dialog box, and then determine whether you can hear sound.
If that doesnt work and you have an installation CD, the audio drivers should be on the disk.
If you don’t have the CD go to your computer manufactures web page to search for updated sound driver software. Read the instructions on the download pages carefully
before installing.
If there are no updated sound drivers available, use Microsoft's Windows Update feature. Connect to the Internet and try the following items until Windows Update opens:
1.Click Start, and then click Windows Update (if it is listed).
2.Click Start, click Settings, and then click Windows Update (if it is listed).
3.Click Start, click All Programs, and then click Windows Update (if it is listed).
4.Go to Microsoft's Web site and click Windows Update from the Downloads menu.
Check if the sound works now….if it still doesn’t work then most likely the sound card might be faulty.
Feb 20, 2010 | Shuttle D10 - SFF - no CPU - RAM 0 MB - no...
V3 fx steering wheel for PS2
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 Here are all of the instructions enjoy. clip_image001.gif
To adjust the V3 Racing Wheel 2's sensitivity follow the instructions below. ( 3 preset sensitivity selections )
1. Press and hold the SET button for about 1 second to enter the "FUNCTION SETUP MODE", the MODE LED indicator will start blinking and two "beeps" will be heard.
2. Press the direction on the digital/analog directional pad and SELECT button that corresponds to the setting you desire. Directional pad UP and SELECT will give you high sensitivity. Directional pad LEFT/RIGHT and SELECT will give you medium sensitivity. Directional pad DOWN and SELECT will give you low sensitivity.
3. After selecting one of the above sensitivity options you will hear 2 "beeps" letting you know that the wheel has been programmed. For Customizable Sensitivity follow the directions below.
2. Rotate (either left or right with the wheel ) and then hold the wheel to the specific angle desired.
3. Press the SET button again, two "beeps" will sound to indicate the completion of the setting
To reset the the V3 Racing Wheel 2 to it's factory default settings press and hold START, L1 and L2 buttons in until you here two "beeps".
To change between Digital and Analog modes follow the directions below.
2. Press the SQUARE and SELECT buttons to set the wheel to DIGITAL, or the O and SELECT buttons for ANALOG. Two beeps will sound and the MODE LED will stop blinking letting you know that the mode has been selected.
By default GRAN TURISMO 3 A-SPEC uses the X and Square button for gas and brake. To reassign these functions to the pedals on your racing wheel:
1. Go to the options menu in Gran Turismo.
2. Select key configuration. (The picture of the Game Pad.)
3. Scroll down to Acceleration
4. Press Right on the D-pad (11x) until Analog Up is selected for the Right Analog Stick
5. Now go down to Brakes
6. Press Right on the D-pad (10x) until Analog Down is selected for the Right Analog Stick.
7. Press the X Button to confirm your changes and then press the Triangle button to return to the main menu
8. The gas and brake functions for the game will now be set to pedals on your wheel.
Sep 10, 2008 | Cables Unlimited InterAct Racing Wheel V3...
Restarting all data on printer
Here is how you reste the printer fo default settings.
The Clear System Data Memory option restores all the user-selectable options to the factory defaults.
  1. Press the [Menu / Exit] button on the Control Panel.
  2. Press the [Up] or [Down] arrow button repeatedly to select [Memory Clear].
  3. Press the [Enter] button.
  4. Press the [Left] or [Right] arrow button to select [Machine Setup].
  5. Press the [Enter] button.
  6. Press the [Left] or [Right] arrow button to select the required option: [Yes] or [No].
  7. Press the [Enter] button.
  8. Press the [Menu / Exit] button to return to the previous menu.
  9. Press the [Stop / Clear] button to return to the Standby mode
Nov 19, 2007 | Xerox FaxCentre F12 Laser Printer
Cyberhome CH-DVD 300 DVD Player Logo
77 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Level 1 Expert
Electro Med Services...
Henry  Thomas
Henry Thomas
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
