My C90 Epson printer ink indicator, next to the power indicator, is always on. it happen when I stopped print a photo. what I must do? thanks a lot wiwitx yogyakarta Indonesia
  • 1,879 Answers
Right-click on it, select the option that says anything about properties to turn it off
Posted on Dec 10, 2008
My epson t13 printer has stopped printing, while on process printing, even it have a lot of ink? what is behind of this problem?
Epson t13 all problem solved EPSON T13 WITHOUT CHIP , INK LEVEL ALWAYS FULL, NO NEED TO RESET INK LEVEL EACH TIME .INK LEVEL AUTO RESET WHEN PRINTER SHUT OFF.INK LEVEL LEVEL ALWAYS SHOW 100 %NO WASTE INK PAD COUNTER MORENO NEED TO WORRY WHILE PRINTING MORE PRINT JOBSnow no more ink cartiledge not recognise problem
Jan 29, 2011 | Epson Stylus Photo R300 InkJet Printer
Brand New Edible ink cartridge not working on brand new Epson C90
Hmmm 4 this problem you can take the cartridge out and reinstall the software and then put the cartridge back
Jan 24, 2010 | Canon PIXMA IP3500 Photo Inkjet Printer
Parts inside your printer are near the end of their service life.
if you put this in google ssc download it and this will reset your printer hope this helps
Feb 26, 2009 | Epson Office Equipment & Supplies
My r220 epson will not prit anything
The ink indicator permanently on indicates an ink cartridge problem, (not that the protection counter needs resetting). The status monitor picture of the ink cartridges should show which cartridge is at fault, it will have a red X on it. The cartridge is empty, faulty, or in the wrong position. Alternatively, you may have an internal fault e.g. with the system board. But change the indicated faulty cartridge first.
Jan 09, 2009 | Epson Stylus Photo R220 InkJet Printer
i have a problem with my printer epson stylus C90. may i know what to do when parts of my printer are near the end of their life service.? how can i fix it?
Dec 07, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson Photo Stylus 950 not functioning
when ever you want to refill ink make sure, that the ink you refill decompressed for about 30min before you fix it into the printer.
Another thing is that you uninstall the software of the printer and reinstall again, and check the power supply of the printer is working perfectly.
Dec 03, 2008 | Epson RX620 All-In-One InkJet Photo...
I dont know how...
Unraqr the c90.rar file and copy the extraction to any folder on your hard disk (for future frequent use).
The following only works after refilling the cartridges or using a continuous ink system.
Note: This is for the Epson C90; there are a lot more printer specific resetters. Mine is Indonesian.
Note: This does NOT work if the system date is NOT set at July 15, 2007 !!
1. Set the system date to July 15, 2007.
2. Go to MY COMPUTER, open local disk C: then delete the ADJUSTMENT PROGRAM FOLDER (if present)
3. Close local disk
4. Click START, RUN, type REGEDIT
4. Open HKEY LOCAL MACHINE
5. Open Software folder
6. Open Epson folder
7. Delete PTSG folder (right click, remove=yes)
8. Open Epson C90 Resetter folder and start adjprog
9. Click ACCEPT button
10. Click SELECT button to go to port menu. Selected designated port number (USB ...)
11. Click the "Particular Adjustment Mode" button
12. Double click the "Waste Ink pad Counter"
13. Click the "Check" button
14. Click the "Initialization" button.
15. Turn of the printer and press "OK"
16. Turn on the printer and wait until the maintenance procedure has finished
17. Close the panels of the Adjustment program
18. Reset the date to the current date.
Note: Print these steps for future use.
Note: With a continuous ink system, make sure that the ink filling cable is not to tight; the print head with the attached ink
cabling must be able to freely move all the way to the left inside the printer. Also make sure that none of the ink tubes is squeezed tight by the black plastic clamps that are used to attach the system to the outside (front) of your C90. Place them so that the transparent cover stays slightly open.
Note: With a continuous ink system, be sure to use the "lock roller" on the ink system to close the ink supply when the printer is not in use; otherwise your ink evaporates.
Note: The continuous ink system is quite erratic in its signalling: when one of the colors is about 1/3 full on the Epson monitor, the printer might stop suddenly and display the cartridge X signal. Sometimes, with 2 colors X-ed, you have to do the procedure twice!
I don't know where you got the C90.rar download. You must have the following files:
AdjProg.exe
Apdadrv.dll
EditText.dat
StrGene.dll
If you don't have them all or miss some, pls e-mail me (hanshufkens@yahoo.com) and I'll sent them to you (attachment is about 2 MB)
Last: The C90 is a **** printer. After 4 months of use the paper adjustment goes to hell, so with printing you never know if printing will start before the paper is properly loaded. Might as well buy a new printer (NOT Epson!).
Jul 23, 2008 | Epson AcuLaser C900 Printer
Waste ink pad counter reset software.
Dear Sir,
My Epson R30 Photo Printer has a problem from Waste Inkpad Full massage and it's not working. I want a free software to download to reset my printer and I tried in SSC Service Utility v4.30 but software don't have R390 model so, please help me to find right software to reset my printer. Thank you.
mallajanak@yahoo.com
Jun 14, 2008 | Office Equipment & Supplies
Stylus Photo R280
Ink carts being not recognized and you say its a brand new printer?
Heres what you may want to try.
1. Turn off the printer and disconnect the usb cable from the printer
2. Press and release the ink button once you see a solid green light and solid red ink light
3. Open up the printer cover and check out where is the ink cart holder positioned
4. It should stop in the middle part of the printer, you should see an arrow or a ink out marker (ink icon with a / with it( indicating which ink cart is out or not recognized or expended. (This is a usual process on all the epson stylus photo series I had)
5. Press and release the ink button again, it should stop to the next ink cart which you are having a problem and if it doesnt then your ready to reclamp the ink carts.
Just follow your manual usually theres an on screen instructions how to manually replace or reseat the ink cartridges. If the issue persist, you may want to contact epson, ask for a warranty procedure or what you can do next for this. (Either a bad set of ink cart or a bad print head) Good luck!
Jun 12, 2008 | Epson Stylus Photo R300 InkJet Printer
Repair manual for epson photo r220
Here is the link for your printers document and manual
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=60202&prodoid=58654761
pls dnt 4get to rate, thanks
Apr 20, 2008 | Epson Stylus Photo R220 InkJet Printer
71 people viewed this question
k24674
jasbo
jasbo
