Question about Xante CL30D Led Printer
CL 30 will not finish initializing stays stuck
Is there a code or reset button somewhere
  • 3 more comments
  • oneprintwork Dec 10, 2008
    It was working ran about 5 jobs on it and went into a imitializing mode and never reset it self. I unpluging the printer, for about a week.
    I dont know how to reset the printer to factory setting, the key pad will not work.
    removed all toner and drums installed new transfer belt and fuser cleaned the machine, plugged it in and still will not reset itself from initializing.
    Drums have no holes for lights. NO go button .
    Menu +Item +value Select
    Online -Item -value Cancel
    or
    0 1 2 3
    4 5 6 7
    I tried the select button (#3), the online button (#4)
    and the Cancel button (#7) . I have a on/off switch on the front operators side.
    Ram Check and initializing
    Sergeant:
  • 237 Answers
There should be a reset button close to or around the power button
Posted on Dec 10, 2008
    President:
  • 2,110 Answers
After you have replaced a fuse with an aid of instruction, the counter will be reset onto "0" zero and your printer's transfer belt wants to run for another full cycle without any trouble.
    Genius:
  • 1,124 Answers
According with the manual of this printer, if after reset to factory setting the error of initializing remains, the printer need to be serviced.
  • 4,806 Answers
Give Technical Support a call
1-800-926-8393 (US and Canada)
here is the manual:
http://www.xante.com/support/cl30/manuals/CL30HSEQRMv2.pdf
regards
  • 65 Answers
What exactly does the screen display?
  • 275 Answers
Reset your printer
With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button 4 times
Do you think this helped you?
  • Alan R
    Alan R Dec 10, 2008
    Try unplugging any network cables, turn printer off and back on and then try again, if it works, connect network cable back
  • 734 Answers
Are you trying to reset it to get all of the ink used?If so, it's a simple trick.
Cover the holes on the side of the drum with electrical tape (the printer shines a light through, if the light goes through there's no toner left, but if it doesn't it acts like there's a full cartridge)
Now use the following sequences on the printer:
1. Open the front cover and leave open while completing the following steps.
2. Turn the printer off.
3. Hold the 'go' button while turning the printer on. All panel lights should be on.
4. Release the 'go' button.
5. Press the 'go' button 2 times.
6. Pause.
7. Press the 'go' button 5 times.
8. The toner light should be off.
9. The paper light should be on or flashing.
10. Close cover. The ready light should be the only light on.
This should reset the drum so that you can get every penny of ink you paid for.
Good Luck.
  • futureloginn
    futureloginn Dec 10, 2008
    Factory Reset InstructionsFor all XANTé Printers except the AW1200
    A factory reset should be performed only after all printer cables and components have been reseated and when all other methods of correcting printing errors have been exhausted.
    Note: Cables and components should be reseated only while printer power is off.
    1. Turn off the printer.
    2. Use the chart below to determine the two-key combination required to perform a factory reset on your printer.
    LaserPress, Accel-a-Writer 812, all other printers except the AW1200
    Front Panel Reset Key Combination ONLINE
    FORM FEED TRAY SELECT
    FORM FEED ONLINE
    TRAY SELECT
    1. Turn on the printer while pressing the two-key combination for your printer.
    2. Wait until "initializing" appears in the printer's front panel window; then, release the keys and a printer start-up page will print.
    One last try...
    Reseat all cable connections.
    Reinitialize the printer.
    Note: This resets all printer settings to the factory defaults.
    Hold down the ONLINE and TRAY SELECT keys and turn on the printer.
    Release the keys after RESET appears in the front panel window.
    Sergeant:
  • 306 Answers
Plz say ur prob briefly
  • AbdulRahiman S Dec 10, 2008
    You can download the User's Manual and latest drivers HERE. The Manual should have instructions for restoring the printer to factory settings.
    for more info check tese links..www.xante.com/support/fm4/manuals/fm4/troubleshooting.pdf
    www.xante.com/support/registration_printers_info.aspx
    Sergeant:
  • 399 Answers
Unplug it from mains for sometime and then remove the toner from it and then reinsert it and then try out.
  • masterexpert Dec 10, 2008
    Turn the printer on whilst holding down Menu button. (Display says user maintenance.)
    Press the menu button three times. (The display will say drum counter reset.)
    Press enter key. The system should go back on line, if not press on-line key.
    You can just put a new fuse on the drum.
    When you insert the drum the machine resets the counter and then blows the fuse. So if the unit is ok and you just wish to run it through another cycle just change the fuse.
    This means you cannot just put a full unit in from another machine as it will not reset the counter until you put a new fuse in it as you found out.
    This applies to drums transfer belt etc.
    Note with regard to refilling the toner, some printers have 2 sections. 1 where you put the fresh toner and an after collection section in the same unit. You must empty the 2nd section if you refill it more than 2 or 3 times
    you open the drum unit on top and look on the side cover the green fuse is there.
    1 - Power ON printer
    while holding both the + & - buttons until “USER” message apear in LCD.
    2) Press + or – button until “ENGINE DIAG MODE” is
    displayed;
    3) Press "ENTER", will be displayed
    "DIAGNOSTIC MODE XX.XX.XX S-MODE"
    4) Press + or – button until “NV-RAM INITIAL” is
    displayed
    5) Press "ENTER" again;
    6) Will appear "TABLE 1" message;
    7) Press "ENTER" until "EXECUTING
    RESET" message appear. the "NV-RAM INITIAL" message will
    BLINK...
    This procedure reset TONER, DRUM, FUSER and
    BELT...
    8) power OFF printer, wait 10 sec, and power ON
    again... =)
    To access Service Mode  power ON printer with 0, 1, 6, 7 at same
    time...
  • Xante Master
  • 13,433 Answers
Hey,
Try unpluging the printer, try again after 5 minutes, how old is the printer is it covered by warranty?
has it worked recently have you dont any changes? try reseting the printer to factory default settings
Thanks,
Ekse
I have a CL blinking in the display. How do I reset?
LG Washer Error Code Cl Fix - ApplianceRepairLesson.com
www.appliancerepairlesson.com/.../cl-error-on-lg-washer-repair-help-lg-t...
Jan 19, 2011 - CL means that your washing machine's CHILD LOCK is ON. You canfind ... CL popped up on my display had no idea what it was because the manual didn't say. ... I have the touch screen panel and it does not have temp or option buttons ... I've had tried to reset but won't do do I press temp and what else
How does Child Lock work on my washing machine?
www.samsung.com/au/support/skp/faq/868833
Samsung ElectronicsOct 23, 2015 - If the Child-Lock function is activated, the Child-Lock icon will blink. ...If 30 seconds have passed after opening the cover when the Child-Lock ... Step 5: To clear "CL" error on the display, close the door of the washer after ...
[PDF]Washing Machine - Home Depot
www.homedepot.com/.../d7064d64-8ea1-487d-9c35-a...
The Home DepotJan 3, 2015 - Warnings and Important Safety Instructions in this manual do not ... Donot wash or dry articles that have been previously cleaned in, washed in, soaked ......the Reset water level, "CL" is displayed on the LED display without.
Jan 19, 2016 | Washing Machines
Help my SMEG dishwasher was stuck in a loop and when resetting it was going through the motions like it was trying to drain itself and then finishing the cycle so all 4 lights on the right were flashing...
completely unplug it for several minutes. if you do not have a plug, turn off the breaker to this unit for about 15 minutes. Then turn it back on and see if this resets it. Check for a reset button somewhere under the unit or on the door panel where the control buttons are if this is easier.
Mar 04, 2015 | Smeg Dishwashers
Why does tire light stay on 2011 Toyota?
Reset the Tire pressure monitoring system light. The reset button is located under the steering side under the finish panel. You have to bend down to see the button.
Operate the tire pressure warning system reset switch only after the inflation pressures of all 4 tires have been adjusted on the vehicle.
To initialize the system, press and hold the tire pressure warning system reset switch for 3 seconds or longer with the power switch turned IG-ON
Jul 23, 2014 | 2011 Toyota Highlander
Is there a Reset button for Bosch shu53 dishwasher?
Press and hold Scrub Wash and Delicate/Econo buttons at the same time for three seconds. This will advance the unit to "CL" (clean), meaning the washing cycle is finished, and will drain the water. Do this if your unit gets stuck on 1 minute left, which is common with this model. (I am told that the control panel melts over time, and that the unit is not designed to last more than 10 years.)
Jun 22, 2014 | Bosch 24 in. SHU53 Built-in Dishwasher
How to clear back to factory setting
Service-mode functions
NVRAM initialization
An NVRAM initialization will return the following device settings to the factory-set defaults:
All menu settings, including the fax header and company name
Fax numbers and names that are associated with one-touch keys and speed-dial codes
Additionally, all faxes stored in memory are cleared.
1. Turn off the product.
2. Press and hold both the down arrow button and the Cancel button, and then turn on the product.
3. Wait until the message Permanent storage init. appears, and then release the buttons.
When the NVRAM initialization process finishes, the product control panel shows the Ready message.
Super NVRAM initialization
The super NVRAM initialization clears all settings affected by a regular NVRAM initialization, and also
clears the product language and country/region settings. Both settings must be reset after a super
NVRAM initialization.
When the process finishes, the product control panel shows the Ready message.
Apr 18, 2013 | HP LaserJet M1522nf Multifunction Printer...
Won't start CL flashes
Hi catherine739,
The CL you are getting means "Child Lock".
Please do the following:
- On the Facial Panel (Where the buttons are located), look for 2 buttons marked together with a line, it should also have a face of a child somewhere on that line.
- Press both these buttons together for 3 - 5 seconds, this should reset the Child Lock.
Kind Regards :-)
Jedemeyer1
*If you found this solution helpful, please rate it
Jun 09, 2011 | Dishwashers
Our dishwasher continuously flashes "CL"
Hi trrhodes,
I believe the CL you are getting means "Child Lock". Under normal circumstances there should be no activity at all on your machine.
Kind Regards :-)
Jacques
May 23, 2011 | Dishwashers
Canon Pixma MP210 will not recognize high yield PG-50 & CL-51 cartridges.
The canon pixma mp 210 uses PG-30, CL-31, PG-40, CL-41
It will not recognized the PG-50 & CL- 51
See if you can return it and exchange it for the PG-40 & CL-41.
If not, the only other way is to transfer the ink into the other ink cartridges.
The cartridge cap can be removed by a sharp tap at the back end of the cover.
You can glue back the cover.
If there is an E 1,6 Error code, Ink has run out after you install your ink cartridges
Press and hold the stop/reset button for about 10 seconds to clear the error code.
Dec 24, 2010 | Canon Office Equipment & Supplies
I WANT A SUPRA TV REMOTE MODEL NO IS ST 21B55FT
Hello
You just buy one [PHILIPS CL 034], universal remote control. Supra is listed in its codes.
Codes are
0002 0809
NB: Switch OFF and ON your TV by its front panel power switch [NOT BY THE REMOTE HANDSET], each time, and wait for about 30 seconds, before try an other code.
Direct Code Entry
1. Press and hold the CODE SEARCH
button until the red indicator stays
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
button (TV, VCR, etc.). The red
indicator blinks, then stays lit.
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
flashes.
4. With your device on, press
CHANNEL UP. If the device
responds, no further programming is
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand.
ok.
Dec 22, 2010 | Televison & Video
Xante CL30D Led Printer Logo
52 people viewed this question
Top Xante Office Equipment & Supplies Experts
Ottoniel
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
