Question about Philips 37PF7320A 37 in. HD-Ready LCD Television
Magnavox 37" widescreen LCD HDTV
My tv will not power on. It went off one night and it will not turn back on. Cable box stayed on and is fine and DVD and VCR power on. I've tried different outlets... nothing.
  • 1 more comment
  • Jeff Carey Mar 02, 2007
    i get no sound. not a click tap pop or anything.
  • Jeff Carey Mar 03, 2007
    Did your monitor work in a different outlet or power supply?
  • sexylocs Feb 14, 2008
    37 inch TV went off by itself. It will not come back on or do anything
  • 138 Answers
If the set has no led light on the front the proble is the power supply. If it has a blinking led please let me know how many times it blink and give me the model number thanks...
Posted on Aug 20, 2008
Elonex xv-s telvision no remote control cant find sourse to connect playstion without it.sky box is picked up automatically when switched on. it on scart connection
37" Elonex Widescreen HD LCD Television (Black) - Aria ...
www.aria.co.uk/.../Televisions/.../37%22+ELX+Widescreen+HD+LCD+T...
Buy 37" Elonex Widescreen HD LCD Television (Black) - HDMI, 1366x768, 1200:1, 8ms Product Name: 37" LCD TV Model No: LT37V1 Main. ... 49~61KHz; FrontControls: Power, Source, Menu, Channel Up, Channel Down, Volume Up, ... Have you tried it with a HDMI connection as I can't seem to get mine to work with my ...Missing: playstion
[PDF]Operator's Manual - SunBriteTV
https://www.sunbritetv.com/media/pdf/...R/3230HD-Op-Manual.pdf
6) Do not install near any heat sources such as radiators, heat registers, stoves, ....Water-Resistant. Wireless Remote. Control. Model 3230HD. TV Installation .... If youcannot achieve that ... to both your DVD player and Composite's S-Video connector ....Connect an HDMI cable to the HDMI output of your Playstation 3.Missing: elonex
Jan 12, 2016 | Televison & Video
Vizio VL470M won't turn on
see this instruction: God bless you
  1. Check if the power cord has been properly connected to the power outlet.
  2. Check if the main power has been switched on.
    (DVD player's power supply transformer could be burned out)
3. test the power outlet wall see the diagram
4. do not use the r.control use the power button directly from TV.
Jul 20, 2013 | Vizio 47"" vl470m 1080p 120hz widescreen...
Tv went off and won' come back on.
Most likely you will have to replace the power supply. It is a very common problem especially in newer electronics. You can test it with voltmeter or multi-tester. They tend to get worn capacitor inside the power supply due to cheaper parts
Aug 24, 2009 | SNK Magnavox 32MD357B_37 32 in. LCD...
NO SOUND ON TV. CABLE REMOTE AND TV REMOTES HAVE THE MUTE OFF. TRIED WATCHING DVD, WORKS FINE WITH SOUND, THEN BACK TO CABLE, NO-SOUND. PLEASE HELP! TV IS SAMSUNG
You have just performed the best way to troubleshoot this kind of problem. Check all cables on the back of the tv and your sources and look for any loose or disconnected cables. Next, Hook your DVD palyer to the SAME input that you are using for the cable box. Now if you have good pix and sound then you have a bad cable box. If not then you have a bad Main bd in the tv.
Jun 30, 2009 | Samsung LN37A530 37 in. LCD HDTV
Significant volume decrease when using Comcast cable box
This low audio problem happened to me suddenly yesterday. I powered off over night - no change. I plugged the A/V cables into a second TV - no change. I called Comcast - problem solved.
Tap these buttons on the remote;
May 16, 2009 | Panasonic Viera TC-L37X1 37 in. LCD HDTV
No video output from Magnavox VCR (MDV560VR)
You need to tune a chanel on your tv to the vcr signal, using an RF cable (aerial cable between vcr and tv). That is if your tv has an analogue tuner.
May 09, 2009 | Philips Magnavox DVD/VCR Dual Player
No Cable Picture
Call the cable co. If your getting the cable setup screen from the tv...Its getting that signal from the box...The tv is fine.
Sep 14, 2008 | Philips Magnavox 52MF437S/37 52 in. LCD TV
Tv will not turn on
your tv needs to be repair again power supply problem or circuit.good luck.
Apr 04, 2007 | Toshiba 37HLX95 37 in. LCD TV/DVD Combo
LASONIC DVD PLAYER NOT WORKING WITH COMCAST BOX OR SOYO TV
you have to plug everything to the tv. only thing them are good for is recording to some other unit. like dvd recorders
Mar 05, 2017 | Lasonic DVDP | DVD-7050 5.1CH
Philips 37PF7320A 37 in. HD-Ready LCD Television Logo
231 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
