Question about Sharp VL-E765U Camcorder
Camcorder When I plug my camera into the tv. I get voice but no picture. I use the cord that came with the camers. and do all my tv, vcr tells me to do. Please help.
0 characters
1 Points
I need the cords to plug into my DCR-TRV260 NTSC Camers to stream or hook to Computor
Go on ebay and look, I have found every kind of conceivable cable on there.
Sep 22, 2016 | Sony Handycam Digital 8 DCR-TRV260...
Someone did my wedding video, it wont finalize, but plays back on the camcorder. She lent me the camcorder, along with usb cord and software. I cannot get the data from the disc to transfer to my...
Unfortunately, only video and/or pictures from your (SD Memory) Card can be transferred (via the USB cable) to your computer. Video/pictures from a disk is not accessible to your computer.
So, you may wish to try to playback the video (on the camcorder) with the output to a DVD recorder (using the AV cables from the camcorder to the DVD recorder or a VCR recorder). This assumes you have a DVD recorder (or VCR recorder) that will take the RGB input from the camcorder. Connect it up just like you're viewing the playback on a TV monitor.
Jan 27, 2011 | Samsung SC-DC173 DVD Camcorder
When I plug in my camcorder to the tv using the AV cable and select the correct tv input, the picture does not display on the tv and there is a trememdous amount of feedback.
I connect my camcorder to the TV with regular RCA plugs (yellow, white, red). The camera RCA plug-in holes are in a separate compartment. I can see what I am recording on the TV if the camera power switch is pushed over to "camera". I do my recording. Rewind. Then I have to push the power switch to "off" then over to "VCR" , and push "play" on the camera in order to see the play back on the TV screen. See if your power switch has several positions. I hope this info. is helpful.
May 17, 2009 | JVC Everio GZ-MG335 HDD Camcorder
Video transfer not working
  1. connect VCR(recorder) to TV, select TV proper channel to get signal from VCR
  2. connect Mini DV to VCR, for example, you are using AV1 input on your VCR
  3. on you VCR, select channel(or input) to AV1, insert a blank tape
  4. turn your Mini DV to play mode and play, press REC on your VCR
you should get picture now.
May 08, 2009 | Panasonic NV-DS60 Mini DV Digital...
No Display On LCD in VP-D351 Samsung camcorder
hi ..had the same problem..had advice from this site two weeks ago..which was spot on..the lcd screen ribon has brocken.. its available from SAMAD9706489A..£11.49.. took me half hour to take camera apart (carefull.y) 10 min to put back togerther.. works brilliantly.. good luck.. Need futher help email me..stefjanet
Aug 15, 2008 | Samsung Compact MiniDV Digital Camcorder
Recording from camera to VCR
1st setup ur VCD with TV and playback it to view on TV. If picture is coming, thats OK.
2nd plug ur camcorder in VCR input and select VCR input according to plug in and monitor the camcorder picture on TV through VCR. If its ok, now u r ready to record the picture from camcorder to VCR.
Jun 07, 2008 | Sony Handycam CCD-TRV308 Camcorder
DXG Model 506V
for those who have the provided USB cords, u should simply be able to plug in the usb and connect it to the computer...the camer will be automatically recognized and windows will automatically pull the software from your camera, if u have windows XP or newer that is....
May 16, 2008 | DXG Technology DXG-506V DV Digital...
Samsung 880x digital zoom scl906 need cord for tv
The cable that goes from the camcorder to the TV or VCR is a simple one to replace. It's got a standard 3.5mm stereo headphone jack at one end and RCA's at the other. So all you need is a cord that is designed to let you play an MP3 player through a home stereo, and Radio Shack sells these, as does Wal Mart. The only thing is that one cable will be red and one white, whereas the original had one yellow and one white. Just plug the red plug into the yellow video-in jack on your TV or VCR.
Apr 26, 2008 | Samsung SC-L906 Camcorder
How to connect cords to camera, vcr and computer
Use the provided cable for your camcorder that includes either a rca (yellow, red, white) end or s-video, component, etc... then plug those into the input of your vcr.  you will need to select the correct setting on your vcr (possibly input 2) to view the camcorder.
Dec 21, 2007 | Sony Handycam DCR-TRV70 Mini DV Digital...
Problem taping on vcr from panasonic nv-gs50
if you are using rca cables let the cam playing something you recorded and try find the channel on vcr(on its tuner).it would be helpfull if you post a picture of your cord
Nov 03, 2007 | Panasonic NV-GS50 Mini DV Digital...
Video Cameras Logo
19 people viewed this question
Top Sharp Video Cameras Experts
abdul rauf
abdul rauf
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
