Question about LG DLE5977 Electric Dryer
Hotpoint TCD970G Silver Tumble Dryer -cutting out
I have a Hotpoint TCD970 which switches itself off after a few minutes for no apparent reason.
  • 686 Answers
Over-heating
Posted on Mar 01, 2009
Where is the reset on hotpoint tvfs83 tumble dryer as good power into machine but no life or lights coming on. machine is 4 weeks old
NORMALLY SIMPLY UNPLUGGING THE CORD FROM OUTLET FOR A FEW MINUTES WILL RESET IT.
I SUSPECT YOU BLEW A THERMAL FUSE OR BAD DOOR SWITCH
CHECK FOR 240 VOLTS POWER TO AND FROM THE OUTLET FIRST
Jan 02, 2017 | Hotpoint Dryers
Oven always switching itself off
Thermal overload has failed. This is a sensor usually with 2-3 wires attached
Oct 19, 2017 | Hotpoint Ovens
Dryer wont heat up
There could be a number of reasons why your dryer is not heating.
1) The element may be faulty
2) A thermostat or thermistor could be faulty or need resetting (if you have one with a reset button) You would need to check your hand book for this info.
3) you could have a wiring fault or lose terminal.
4) If you have a dryer with a revers tumble (one that goes in the opposit direction for a few minutes before continueing) on some models this incorperates a revers timer that works off the main timer and when it is in revers tumble the heater is switched off. If the timer is faulty it would keep the heater permanently switched off.
For more Hotpoint help click on link
Mar 18, 2010 | Roper Dryers
How to fit creda thermostats
It depends on which make and model of tumble dryer you have as to how easy it is to replace the relevant parts. Some tumble dryers have heating elements that are easily accessible by removing the back panel, and can be tested for continuity or checked for obvious burning out or open circuit. Others though have their heating elements inside, which aren't accessible without stripping the dryer down we will try and cover as many as possible in or video tutorials section. Tumble dryer heating elements are always protected by thermal fuses and thermostats which are usually simple devices with 2 wires connected and have a bimetal strip inside them. They can be tested for continuity with a test meter.
The problem is that if a stat (thermostat) or t.o.c. (thermal overload cut-out) has gone open circuit, it may be for a reason. Overheating could have caused it by not being able to vent the air due to a blockage some ware. Blocked filters or even the machine not being allowed its ten minute cooling down period, Overloading can cause it as well. Sometimes they can go for no apparent reason. A blocked or severely kinked vent hosecan also cause overheating.
You-Tube video "ymXmpyVkxIE" placeholder (do not delete)
Jan 02, 2010 | Dryers
The tumble dryer trips out
It sound as though it is overheating.
This may be caused by a reduction of air flowing through the machine.
Check all the filters and the out pipe for blockages that would restrict the air flow.
Dec 14, 2009 | Hotpoint Dryers
My hotpoint aquarius tdc32 condenser tumble dryer is not heating
yes............the 2 round bits are the thermostats.......these need changing in pairs.......not just 1 of them
cheers
May 08, 2017 | Hotpoint Dryers
I have a tumble dryer.
Sounds as if the door switch is the problem. This is normally a safety switch that stops the dryer when the door is opened.
Unplug the dryer.
Remove the door switch and check the switch condition with a continuity meter after removing the wires. Try turning the switch on and off....the meter should read power on and off when you do that.
You may have to remove the front of the dryer to get to the door switch.
Good luck,
I hope this helps
Oct 05, 2009 | Hotpoint Dryers
Hotpoint condenser tumble dryer aquarius cdt00- wont dry
I am not familiar with this particular unit, but I have a condensing dryer (Malber) which pumps out the water by itself. I am guessing that your unit requires you to empty a bin manually. Even if the bin is empty, I think the unit thinks it needs to be emptied and that is why the dryer will not work to give you hot air. If you do have such a bin, it might have a weight switch which the unit uses to detect if the bin needs emptying. See if the weight switch is working. The same weight switch idea is used on dehumidifiers.
Mar 09, 2008 | Dryers
Cutting out after a few minutes
Is the water supply (for supplying cooling water to the condenser) switched on? If not, there's no real mechanism for removing heat from the machine, and it might reasonably be expected to shut itself down. Once you've got water going to the inlet hose, you might check that the solenoid valve which shuts the water off when the machine is turned off hasn't failed, and that the jet through which the water squirts into the condenser (if that's separate in this model) isn't blocked. A.
Feb 16, 2007 | Hotpoint TDC32 Electric Dryer
LG DLE5977 Electric Dryer Logo
424 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
