Question about Ecoquest Fresh Air Living Air Purifier
Display reads "Perform Maintenance"
The unit runs and appears to be functioning fine (curently set on 500Sq Ft.); however, the unit will not resopnd to the remote control or the control panel. I appreciate any advice you have. If I am unable to repair the unit I would like to know were I can send it to have it repaired.
Thank you, Sean Burke
  • 368 Answers
Hi Sean,
If the unit is under-warranty, I'd contact the dealer who sold it to you, or EcoQuest customer service (info follows). Get an RMA# (Returned Merchandise Authorization) and take it from there.
If it's not under warranty, they will still repair it, but will charge you. If the controls aren't working, you'll probably need to decide if it's worth it or if you should consider purchasing a new one. Getting into fixing circuit boards or other electonics gets expensive in a hurry.
Hope this helps.
EcoQuest International,
310 T. Elmer Cox Drive
Greeneville, TN 37743
1-800-989-2299
Posted on Dec 23, 2008
Id like some instruction on how to use ? curently trying to remove odours from a vehicle ? some instructions on how to use the unit would be a great help
Odors from a vehicle takes 2-14 hours on "high". Depends on the odors. Run the AC & heater fan for 20 minutes also when the car is full of ozone and have the unit aimed up on the floor toward the firewall on high. You should not stay in the car while doing this. Mild new odors can be neutralized in 20 minutes to 2 hours. Bigger and older problems take longer.
May 23, 2011 | Ecoquest Breeze AT Living Air Purifier
When the unit is turned on, it works, but the light in the window in front of the unit is wak and there are no readings as usual
Sometimes, for some reason, the lights burn out or don't function correctly. However, you can determine by hearing, smelling, and looking at the fan to see where the machine is set. If the controls still work, and everything seems to be running, just keep using the machine. Since Vollara (EcoQuest new owners) no longer sells nor repairs the machine, your option for repair is just to keep investigating until you find a former dealer or repair person who would look at it.
Feb 17, 2011 | Ecoquest Breeze AT Living Air Purifier
My Ecoquest Fresh Air purifier display reads: NEEDS RCI CELL. I have ordered one online, is it safe to run the unit until I receive and replace the rci? I can already tell a difference in allergy symptoms...
By all means run the unit while you wait for the new RCI cell. The purifier will be less effective in killing germs while the RCI cell is out. It will still work to reduce the allergens in the air. Hope this helps you.
Feb 04, 2011 | Ecoquest Fresh Air Air Purifier
Just cleaned the unit. (Which I have done several times.) When pluging the unit back in I had the lcd display say the unit was in away mode. I pressed the buttons on the front to change the mode to 2500 sq...
Oops. It's possible that the incorrectly inserted plate caused the machine to malfunction. It may need to be sent to the factory so the computerized controls can be recalibrated. Call Vollara (new name for EcoQuest) Customer Service 800-989-2299.
Jan 31, 2011 | Ecoquest Fresh Air Living Air Purifier
Fresh air is reading perform cleaning. exactly what does that mean,I cleaned the filter and the plate but it stii reads perform cleaning.HOW
After you have cleaned the filter and plate, reassemble the purifier. Plug it in, turn it on, when the message perform cleaning reappears, press the Reminder Reset button on the purifier to clear the message. Now you are good to go for another 30 days.
Feb 22, 2010 | Ecoquest Fresh Air Air Purifier
My front control will not function. I have lost my remote. I have serviced, cleaned the unit several times but the unit always comes bak on and tell me it need normal cleaning . I cannot clear the display....
If the front control does not function, you can not clear the perform cleaning message from the display.
Contact the dealer whom you bought the machine he/she should be able to help you. The machine has a 3 year warranty.
Otherwise, contact the manufacturer EcoQuest at 1-800-989-2299 and choose technical assistance from the menu. You will be guided through some trouble shooting and if needed you will get an RMA number so you can send your unit in for repair.
Nov 11, 2009 | Ecoquest Fresh Air Living Air Purifier
MIDI Ionic Breeze quit working
Unit seems to need reset...To do this simply, with unit still plugged in, set to off by selecting on button until there are no high, med, or low lights on. unplug unit from wall for about 15 seconds then plug back into wall socket and select your favorite setting high, med. or low. The order in which you perform this task must be as stated above and the unit must be clean and the door and cleaning rod must be in home position. Hope this helps, mines working fine now but took a couple tries to find right order to reset.
Sep 16, 2009 | Sharper Image Professional Plus Ionic...
Perform cleaning on reading panel dont go away...
On the face of Fresh Air there is a reminder reset. After cleaning unit turn it on and press the reminder reset this message sholud go away
May 23, 2009 | Ecoquest Fresh Air Air Purifier
Time On
There should be a timer button that can be depressed to set the amount of run time desired up to 8 hours.
If you press the timer button 9 times it will return the unit to no timer control function and the display panel should show no time in it's window.
Mar 15, 2008 | Kenmore AC2044-1 Air Purifier
Fan Noise
Your fan motor probably needs additional maintenance, in the way of lubrication.
After removing the unit from power, access the Fan blade and spin with finger. If there is any resistance to note then the spindle running through 2 bearing surfaces needs lubrication.
See the other question/answer to fan removal - motor lube.
If you have any sort of humidity to contend with and have a FreshAir model F1 or earlier different type, they seem to have some corrosion problems after a period of a couple years.
It is just a function of the machine/job that necessitates such maintenance.
Jan 12, 2008 | Ecoquest Fresh Air Air Purifier
Ecoquest Fresh Air Living Air Purifier Logo
98 people viewed this question
Top Ecoquest Air Purifiers Experts
fordexpert
Michael Youngman
Michael Youngman
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
