Question about Yahoo Messenger
I CAN'T INSTALL YAHOO 8
I DELETED MY YAHOO MESSENGER 8 TO INSTALL 9 AND I CAN'T INSTALL 8 BACK
  • Anonymous Dec 20, 2008
    it has error command line
No i cant get cam to work on yahoo
Posted on Dec 19, 2008
My web cam is not working with yahoo massenger kindly help me
Posted on Dec 10, 2008
When i am installing yahoo messenger during installation an error comes d3d9.dll not found reinstall it........now what can i do plz help me.........
ANY Yahoo! Messenger program will not install properly if a former program, or an incomplete install, has not been completely deleted from the computer first. (Don't worry - your Contacts List will be saved into the fresh installation of an updated Messenger!)
Delete all Yahoo Messenger references from the registry.
  • Use the Control Panel > Add/Remove Programs method,
  • Then double-check by going to Start > Search > files and folders > Yahoo! Messenger (notice the exclamation mark in the title).
  • Write down and delete all references manually if necessary. The uninstaller works well for Vista and Win 7, but not for XP - it leaves behind MANY junk files when uninstalling.
  • If you are using Internet Explorer 8 or 9 as your browser, Yahoo Messenger 10 will not work properly without Flash and Java programs installed, and possibly the .NET framework update. (Messenger 11 is still in beta format, so be wary of using it yet.). you'll have to download Flash and Java programs as well.
Last, you could used this link to fix a dll error:
http://fix-all-dll-errors.com/d3d9.dll/
Just click on the link, then click the button "Fix dll errors now." This should fix the issue. Hope this helps. Thank you for using FixYa!
May 20, 2011 | Yahoo Messenger
I can not install yahoo messenger 10
You need the following OS to support Messenger
Windows 2000 / XP / 2003 / Vista / XP64 / Vista64 / Windows7
If that is not an issue read on.
The problem is probably due to a mal-function of the uninstall software.The Yahoo Messenger uninstall software is notorious for leaving files and fragments behind creating conflicts with the incoming software
Close all programs when uninstalling / downloading and uploading.
If you tried to uninstall the old Yahoo Messenger program from the Control Panel and failed to back it up with a visit to the 'C' drive, you may have old software conflicting with the incoming software trying to share the same folder.
If you have Vista the whole Messenger folder should have been removed during the uninstall.
Check
Start > Computer >> Local drive (C) >> Program Files >> Yahoo >> Messenger. - The Messenger folder should have been deleted and not seen. If the Messenger folder is still visible - delete it.
If you have a pre-Vista OS, the Messenger folder remains, and inside, only one sub-folder should be seen. This is the 'Profile' folder and contains all the message history. All other software should have been deleted.
Manually delete any other folders and files before moving on
Download 'ccleaner' and run it through a couple of times,using the factory settings and the 'Run Cleaner' control until 0 bytes are seen to be cleaned following a scan
Run the 'Registry' from the left hand toolbar but 'Save' any changes before repairing
http://www.filehippo.com/download_ccleaner/
Re-start your computer and download Yahoo Messenger from here.
http://www.filehippo.com/download_yahoo_messenger/
Jan 03, 2010 | Yahoo Messenger
I installed yahoo messenger 10 and now whenever I get an IM it closes the messenger. I have uninstalled and reinstalled but it still does this. Any ideas?
Yahoo Messenger 10 full of bugs and still not fixed....I will like to suggest you to remove/uninstall that and download and install the messenger version 8 or 9 ...
For more help please stay connected with fixya...
Thanks and good luck
Dec 28, 2009 | Yahoo Messenger
Crash on start of yahoo messenger, XP all updated.
check your system for viruses with latest definition updates
because yahoo messenger is the weakest link for the internet viruses and worms
Jul 10, 2009 | Yahoo Messenger
Cannot login to Yahoo Messenger 9 - Yahoo Messenger 8 acting up
Download an older version and do an update when you are logged in. This is an error from the new yahoo software.
rate this fixya
Apr 05, 2009 | Yahoo Messenger
Yahoo messenger 9 not opening
download a latest copy yahoo messenger, sometime when your yahoo messenger become old it cant log you in download from here
Click here to Download
install yahoo messenger then log in again
This will help. Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Regards
manish
Yahoo instant messenger
you have to in stall it again to get it back.go to.oldversion .com to download it online.i hope this helps
Nov 28, 2008 | Yahoo Messenger
I cant install yahoo messenger
i cant access yahoo live messanger. i deleted the icons by mistake
Oct 18, 2008 | Yahoo Messenger
Yahoo Messenger 9
yahoo messenger 9.0 was not loading for me....so i tried to re-install it..tht ddnt work...thn i deleted all the files manually and removed the program... but now wen i install it it stops at 99%..i saw somewhr a suggestion...it helps to reach 100%but again the loading prob.. so in short nothing worked out.. i tried several times to install... it stops at 99%.... YAHOOOOOOOOO plzzz help. i use windows XP.
Oct 05, 2008 | Yahoo Messenger
Yahoo Messenger will not load
I have a desktop computer and downloaded ym 9.0 for vista it loaded but will not pull up when i click on it it freezes.
Sep 26, 2008 | Yahoo Messenger
Yahoo Messenger Logo
59 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
