Question about 2wire Wireless-G 802.11g ADSL Gateway
Changing the channel, so it doesnt conflict with micro-cordles ph
My gateway is working fine, but everytime I crank up the micro (which is a new one) or the cordless phone's 2.4Ghz I loose my signal and have to reboot the gateway for my pc(win xp-Pro) to find the wifi again.
I was thinking to change the channel on the gateway might help???
    Sergeant:
  • 366 Answers
No way.
You have to try relocating Wlan Router antenna or add external boosted one.
Move to N protocol Router
Change Cordless to 5 Gig band model.
Check Micro radiation leaks and change it if over allowed limits.
Posted on Dec 26, 2008
I have just received a new Archos vision 43 player which worked fine until I tried to use it wit a 16gb Kingstin SDHC micro memory card and the screen froze, and it would not turn off or change...
hello,
maybe your device doesn't match putting up high memory card, remove that and place back your default micro sd card..
note:you should go back immediately to your previous sd card,before many conflicts occurs
may this was helpful to you,goodluck
Feb 25, 2011 | Audio Players & Recorders
ConflictGlobal ON MULTIIPLAYER GAME WHEN OTHERS JOIN ME THIS MESSEGE IS THIS SESSION IS NO LONGER AVAILABLE HELP ME PLEASW
"Session Is No Longer Available" happens usually for 2 reasons:
1) Change your server name everytime you make new server. Otherwise players will try to join to your old server in server list with the same name and that will not most certainly work since that server is has already been closed. Conflict Global Storm server list does not update too often, that it is wise to use new server name everytime you create new server.
2) Never alt+tab or go to Windows when your server is running. It often kills the connection to your server. You see your server is running, but players just can't get in anymore.
Aug 19, 2010 | Eidos Interactive Conflict: Global Storm
I have quicken 2009 ver 7 on an XP pro PC using a Kodak 5300 printer and now it will crash everytime I try to print checks. It was working with now changes and now it's not.
Software conflicts occur more than you would think.
IMHO, the most stable platform is Linux. Windows XP Pro is the most stable Operating system Micro$oft has put out ever.
The conflict is somewhere in the software.
either Quickbooks or Kodaks printer software.
The most likely cause is the Kodak printer software.
There is a reason why the printer ink is so cheap. Because of the questionable and oft disparaged software that is packaged with it.
I suggest updating your kodak printer drivers and / or completely uninstall and reinstall the drivers.
Jan 23, 2010 | Intuit Quicken Premier 2009 for PC
Direct TV remote quits working - conflict with Samsung LCD?
Turned power saving feature on the TV to low and moved the receiver about four feet away from the TV and the remotes work fine now.
Sep 03, 2009 | Samsung TV Remote Control
Ibought an Identical WGr614 to replace the one I have (which works fine) but cant seem to get the new one to work. It will not connect with the modem (Brighthouse TV) believe they are with RR. I was led to...
If it is identical, it probably has the same IP gateway and is conflicting with the existing router. You need to go into the setup page of the new unit and change the gateway to 192.168.1.1. or 10.10.0.1
The default is 192.168.0.1, which is probably what your original is set to.
Jul 29, 2009 | NetGear WGR614 54Mbps Wireless Router...
Wireless
Your can try changing the channel of the wireless signal by accessing your 2wire Homeportal's interface. try changing it using these recommended channels: 1,5,9 and 11. The channel is usually defaulted to 6 which most of the time conflicts with other high frequency devices.Hope this helps. If you are unsure on how to access your Homeportal's interface you just need to know the default gateway of your device. just go to start>run>type cmd>click on ok>then on the blinking cursor just type ipconfig/all and the number's beside the default gateway is the address of your 2WIRE Homeportal.Just simply open a browser afterwards and access those numbers you found on the cmd prompt. and it should show you the interface of the 2WIRE device.
Mar 25, 2009 | 2wire HomePortal 1000HW DSL Modem and...
Conflict between wireless router and cordless phone
you should try changing your wireless channel in the router setup.
1) log into your router.
2) go to the wireless setup page.
3) change the 'Wireless Channel' from auto to 1-11.
4) re-boot your router and re-connect to it.
5) use your cordless phone and see if the connection drops out.
6) repeat steps until you have a stable channel
good luck :)
Jan 28, 2009 | Linksys WCG200 Wireless Cable Modem 54G...
Connecting wireless xbox to new laptop
IRQ conflict, make sure no other devices are using the same interrupt request channel.
Aug 20, 2008 | Gateway MT3705 Notebook
My cd/dvd player dont work right
If your cd/dvd player doesnt work right after installing a Epson cx4800 model printer on your computer, specifically with the Vista OS, its due to reported issues with the cx4800 printer drivers conflicting with drivers tied to your cd player..supposedly.
Best advice is to uninstall the cx4800 software/drivers and see if your cd/dvd player works right. once confirmed it does, then try to get the windows os to automatically detect and install the cx4800 printer without using the printer drivers that came with the printer.
If after uninstall the printer drivers and your cd/dvd player still doesnt work properly....need likely to reinstall the cd/dvd drivers ..but that can be another ugly problem as for finding the right ones to reinstall.
Dec 02, 2007 | Epson Stylus CX4800 All-In-One InkJet...
Open Questions:
See all 2wire Wireless-G 802.11g ADSL Gateway Questions
2wire Wireless-G 802.11g ADSL Gateway Logo
90 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
