Question about HP DesignJet 500ps InkJet Printer
I keep getting an error (81:01)
My printer keeps giving me an error message. The instructions state as follows: 1) Open Window 2) Switch power off 3) Clear paper path 4)Switch power on 5) Align printheads. I am able to complete tasks 1-4, however, when I attempt to "align printheads" I am continually getting the same error message. What the heck is wrong with my printer? Please HELP!
  • 53 Answers
The problem refers to basically a paper jam. I thing your problem could however be the carrage movment. There is a special oil required for the carrage, but failid this use a very thin oil such as sewing machine oil. The trick is to not use too much oil, only a drop or two over the entire length of the carrage. Also needs to be oiled is UNDER the rail towards the back. Look carefully at the back of the carrage where it has the back slider. This rail needs to be clean and lubricated. Probable easier to clean and lubricate if you remove the encoder strip.
Regards
Dave
Posted on Feb 18, 2009
The yellow and green light flashes and printer error 5200 message displays
Error NO. 5200 is caused by ink absorber almost full so you need to reset your printer.. To solve the problem follow the instruction step by step ;
1. Turn off the printer without pulling the power cords.
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Then Press Resume button 5 times then let BOTH buttons go.
5. You will notice that the Alternate Blinking error is gone, this means that the printer is in Service Mode state. thanks
Aug 28, 2011 | Canon Pixma iP2700 InkJet Photo Printer
Tip
Resetting the Ink Waste Absorber Error Message
Below Works with most Canon Range of printers.
By using this tool you can reset the waste tank counter and can sometimes reset the ink level monitors.I have included two procedures.
Method 1 1. Turn off printer
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Method 2 First you need this tool : http://www.ziddu.com/download/14685220/PCM_servicetool.rar.html
Then the following steps: Step 1: enter in service mode in order to use the resetter:
  • Turn off the printer without pulling the power cords.
  • Hold down Resume button and press Power button.
  • Keep holding down Power button and let Resume button go.
  • Then Press Resume button 5 times then let both buttons go.
  • The Alternate Blinking error is gone: the printer is in Service Mode state.
Step 2:
Extract the resetter and double click "servicetool.exe"
  • Click Reload Button and you will get a new USB port.
  • Load some papers in your printer and press the "Main" Button, wait until it shows "error 001" then press OK.
  • Then press "EEPROM" button and the printer will print some text, after that click OK
  • Then power off the printer (sometimes you have to press twice the power button to turn off) and turn on again.
  • That's done.
I hope this helps anyone who has a issue with the Error codes. You can usually reset it 2 times before it will actually overflow. It can also assist in re-setting error codes
RegardsGM
on Apr 21, 2011 | Office Equipment & Supplies
How can i fix a error like contack your service center
Please follow the instruction step by step....
Aug 27, 2011 | Canon Pixma iP2700 InkJet Photo Printer
How do i reset ink absorber full error on my Canon iP4700
Kindly follow the instruction to reset your printer.....
Aug 19, 2011 | Office Equipment & Supplies
Problem 5800
Hi! Your ink absorver tank is almost full, you need reset your printer. To reset your printer follow this instruction please : 1. Turn off the printer without pulling the power cords.
5. You will notice that the Alternate Blinking error is gone, this means that the printer is in Service Mode state. Now your printer is ready to use.... thanks
Aug 12, 2011 | Canon Pixma iP2700 InkJet Photo Printer
Red paper light keeps flashing. Closed all doors, turn on and off
Close the front cover. If the error is not
cleared even after closing it, open the cover
once and close it again.
The error may occur because of the laser
BD malfunction. The Laser unit may need to be R/R'd
Try cleaning the Scanner Window
When replacing the drum unit or toner cartridge with a new one, be sure to clean the scanner
window.
1) Turn off the power switch and unplug the power cord.
2) Remove the drum unit from the printer.
3) Gently wipe the scanner window with a soft dry
CAUTION:
· Do not touch the scanner window with your fingers.
· Do not wipe the scanner window with cleaning alcohol (isopropyl).
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
cloth.
Feb 10, 2011 | Brother HL-2040 Laser Printer
Improper Shutdown Message
1. Disconnect the power cord from back of printer ( while printer is powered on )
2. wait for 10 seconds
3. hold and press the Power button and connect the Power Cord.
4. Release the Power button after 3 seconds
5. Follow the Instructions on the printer screen.
Later try to shutdown it, it should not give the message again
Jun 16, 2010 | HP Photosmart C6180 All-In-One InkJet...
The printer cartidge carrier keeps jamming. How
Solution
Follow these steps until the error message is resolved.
Step one: Turn the All-in-One off and on again
1. Press the On button ( ) to turn the product off.
2. Press the On button ( ) again to turn the product on.
If the error message is not resolved, continue to the next step.
Step two: Clear any paper jam
1. Turn off the product and unplug the power cord.
2. Turn the product around to access the back of the product.
3. Open the rear access door:
1.Locate the tab on the left side of the door and press it toward the right. The door will shift slightly to the right.
2. As the door shifts to the right, pull the door out slightly to release.
3.When the door is released, gently remove the door by sliding the door out and to the left.
4. From the rear access opening, gently pull the jammed paper out of the rollers.
5. Replace the rear access door:
1.Insert the two posts on the right of the door into the holes on the right side of the opening.
2.Press the tab on the left side of the door toward the right. The door will shift slightly to the right.
3.As the door shifts to the right, push in the left side of the door to lock it into position.
6.Reconnect the power cord and turn the product on.
Step three: Make sure that the print carriage can move freely
Follow these instructions to make sure the print carriage can move freely.
1.With the product turned on, open the print cartridge access door. The print carriage might try to move into the access area. If so, allow it to move to that position.
2.Without turning off the product, unplug the power cord from the back of the product. Unplug the power cord from the power source. The power cord must be unplugged to allow the parts to be moved by hand and to reset the paper feed mechanism, without the risk of an electrical shock.
3. Looking in through either the print cartridge access door or the output paper tray, make sure the print cartridges are locked into the carriage and have not come loose. Also, make sure that there are no obstructions under or around the carriage to block it from moving.
4.Make sure the print carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right. Clear any obstructions found.
You may have to reach through the output paper tray to access the print carriage.
5.Close the print cartridge access door and plug the power cord back to the back of the product. Plug the power cord into the power source.
6.Press the On button to turn on the product.
Step four: Remove the print cartridges
Improper placement or installation of the print cartridges can cause a carriage stall error condition. Follow these instructions to remove the print cartridges.
1.Make sure the printer is turned on.
2.Open the print cartridge access door, and then wait until the print carriage is idle and silent.
3.Press down lightly on the end of each print cartridge to release it.
The tri-color print cartridge is on the left.
The black or photo print cartridge is on the right.
4.Slide both cartridges out and place them on a clean sheet of paper.
5.Disconnect the power cord.
6.Move the carriage all the way to the left with your hand.
7.Close the print cartridge access door.
8.Reconnect the power cord.
9.Turn the product on, if necessary.
If the error message is resolved, the placement of the print cartridges caused the problem. Complete Step five: Reinstall the print cartridges. There is no need to complete any steps after Step five.
If the error message is not resolved, complete Step five: Reinstall the print cartridges, and then continue with the subsequent steps.
Follow these instructions to reinstall the print cartridges.
1. Make sure the product is turned on, and then install the proper print cartridges:
1.Hold the print cartridge so that the nozzles are down and the contacts face toward the printer.
2.Place the cartridge in front of the correct slot.
Tri-color cartridges are marked with a triangle and go into the left carriage slot.
Black cartridges are marked with a square or pentagon and go into the right carriage slot.
3.Push the cartridge firmly into the slot until it snaps into place.
2.Close the print cartridge access door.
3.Align the print cartridges.
1.Press OK at each of the prompts on the control panel to start print cartridge alignment.
2.After the page prints, alignment is complete.
4.Try the print job again to see if this step resolved the issue.
Step six: Make sure the control-panel faceplate is correctly installed
If the front panel faceplate (overlay) is already installed, and your product has been working for some time, do not attempt to re-install the faceplate. Press firmly on the faceplate to make sure it is fully seated, and then continue to Step seven: Plug the product directly into a wall outlet.
If the product has not been set up before, follow these instructions to make sure the front panel faceplate is correctly installed.
1.Position the control panel faceplate above the product.
2.Press down firmly on all edges of the faceplate to secure it.
3.Try the print job again to see if this step resolved the issue.
Step seven: Plug the All-in-One directly into a wall outlet
Follow these instructions to make sure that the product is properly connected to a suitable power source.
1.Make sure that the computer and the product have a three-prong power plug.
2.Unplug the power cable from the back of the product.
3.Unplug the product cable from any power strips or surge suppressors, and plug it directly into a grounded (three-prong) wall outlet.
4.Plug the power cable into the back of the product.
5.Try the print job again to see if this step resolved the issue.
If the error message is resolved, you do not need to continue with the rest of the instructions on this page.
Step eight: Perform a partial reset
Follow these instructions to perform a partial reset of the product.
1.Turn the product off by pressing the On ( ) button.
2.Unplug the power cord from the back of the product.
3.Plug the power cord back into the product.
4.Turn the product on by pressing the On ( ) button.
Step nine: Print a self-test page
Follow these instructions to print a self-test page.
1.Load letter, A4, or legal unused plain white paper into the paper tray.
2.Press the Setup ( ) button until Print Report appears, and then press the OK button. Self-Test Report appears on the control panel display.
3.Press the OK button.
The product prints a self-test report.
Step ten: Service the All-in-One
Jan 26, 2010 | HP PSC 1610 All-In-One InkJet Printer
Waste Ink Tank is full and printer will no longer work. How do I repair this problem?
I wouldn't override that error message. Best bet is to open up the printer and give it a good cleaning. If you're unfamiliar or not comfortable with the procedure, take it to your closest computer repair store to have it serviced.
May 12, 2009 | Canon i9100D (Bundle) Photo Printer
Can't get it to scan
1. Make sure the shipping lock on the scanner is free see- set up sheet. 2. Remove all Epson software relating to this device. 3. ReBoot. 4. make sure you are off line. 5. Fully disable any Anti Virus software Switch off the unit and disconnect the USB cord 7. Now install the software and follow the EPSON steps exactly -take no shortcuts
Jun 08, 2007 | Epson Stylus Photo RX500 Printer
HP DesignJet 500ps InkJet Printer Logo
505 people viewed this question
Ben Johnson
