Question about Toshiba TP50H50 50" Rear Projection Television
Toshiba tp50h50 Lost picture and sound, blinks red on frount pannel. Fuse blowen on pb8102-2 powerbord. If I remove a wire from this powerboard picture and sound return but out of focus. I replaced both stk ic and checked resistors around the ic. Im guessing but voltage from the power supply may be off. Where on the board would be a good spot to measure all the voltage to see if its correct? If you have any ideas please let me know? Thanks
  • 1 more comment
  • Rick Paul Mar 17, 2007
    The fuse on PB8102 at location F850 blows out and tv comes on, and is out of focus. if I remove wire (P807) from this board fuse is ok tv goes on same problem.
    I have also checked fuse f470 and have 125Vdc
    Have made other checks but could use a little help.
    Thanks
  • Rick Paul Mar 18, 2007
    I was checking the main power supply
    and I hope i did it correctly using a digital mulimeter. First I unpluged p807 and replaced fuse850 on PB8102. By unpluging p807 kept the fuse from blowing and tv on.
    D856 & D855 showed 0vdc s/b +36
    D851 showed 0vdc s/b +18
    D854 showed 0vdc s/b -18
    D886 showed 13vdc & D889 20vcd s/b +38
    D891 showed 13vdc & D894 14vdc s/b +12
    D882 showed 20vdc &D884 25vdc s/b +125
    Checked both ends of the diode for differant reading about the same.
    Please let me know what you think?
    Thanks
  • Rick Paul Mar 29, 2007
    I do have a manual there not so great!
    would have like a little input then a brush off!
    President:
  • 3,130 Answers
You really should get a service manual for this set to check the voltages. If you found out what the wire was for that you remove from the board to get the set to come on, you could troubleshoot and narrow down your problem. Without it you would be guessing. Good Luck and let us know how you made out.
Posted on Mar 17, 2007
My toshiba TP50H15 color tv comes on then off and the light blink
The flashing power light on those Toshibas is usually caused by capacitors on the power board having failed solder connections. I have fixed them before by removing the power board and resoldering the capacitors. If you have experience with soldering and electronics it is an easy repair. Most shops will recommend replacing the entire board since their labor to repair it would probably cost more. Toshiba put out a service bulletin on this issue which a good technician should be aware of. (If memory serves the capacitors are C109 and C110.  Since your TV still turns on you probably haven't blown fuse F860 which often blows when these capacitors act up.)
If you would like further help with this please post a comment back here.
Dec 05, 2009 | Toshiba TP50H50 50" Rear Projection...
No Picture, but I have sound!
Your color tube has probably went out that is why you have sound but no picture, you will have to call a tv repair place or where you bought it from to get an estimate on having it repaired
Jul 22, 2009 | Televison & Video
Toshiba hometheater 50" rearprojection
http://www.casiasfamily.com/repairlog/tp50h15.html
see the link.
the problem are the convergence amps. Its a common problem for this model. Google the model # and you'll see several postings about the blinking light.
Dec 06, 2007 | Toshiba TP50H50 50" Rear Projection...
Scrambled Picture/Snow Screen, has sound, can play DVDs through colorstream
I had this with a rca once. Can you hear a crackeling noise coming from the flyback transformer? My problem was just the wire was loose
Sep 27, 2007 | Toshiba TP50H50 50" Rear Projection...
Toshiba TP50H50
Repair or replace the power supply
Sep 03, 2007 | Toshiba TP50H50 50" Rear Projection...
Toshiba 50H50: No picture or sound, red light blinks
On alot of these Toshiba TV sets, there is a fuse called F860 that will blow and the light will flash because of bad solder connections on C 810, and C 809, on the negitave terminal. I have seen many of these boards condemed by non-authorized Toshiba repair shops. Good Luck
Jun 04, 2007 | Toshiba TP50H50 50" Rear Projection...
Toshiba TP 50H50 Blank Screen
IT sounds like you lost your high voltage going to the picture tubes. This could be due either to part of the main power supply going out due to a defective capicator or semiconductor, or something more serious in the High voltage distribution network. With the age of the set, I would be most inclined to replace it with a new HDTV, and Toshiba still are pretty reliable sets. If you can afford it, a Sony KDS-55A20 puts out a beautiful picture for around $2300.
Mar 11, 2007 | Toshiba TP50H50 50" Rear Projection...
Toshiba TP50H50 50" Rear Projection Television Logo
118 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
