Question about Emerson MS3100 3-Disc CD Changer
Emerson MS3110 3-CD changer
When attempting to play a CD the message"TOC Read" is displayed but nothing happens. Cannot advance to cd-2 or cd-3. Radio works fine.
  • 2 more comments
  • limabean2 Jan 01, 2009
    Exactly the same as above.
  • nvhuskers Feb 25, 2009
    Same as others. Won't play CD. Says "TOC". ?????
  • Anonymous May 05, 2009
    deck 2 will not play . Laser blocks seem the same for all three . I swapped the assembly from 1 and 2 (remember to mark which location the deck was in to identify the bad parts later). Now deck 1 is inoperable but did work for a little while . This shows the circuitry may be okay . The laser and/or disc appears to be defective . Does any one know a source for parts ?
  • Deck 2 will not play . Laser blocks seem the same for all three . I swapped the assembly from 1 and 2 (remember to mark which location the deck was in to identify the bad parts later). Now deck 1 is inoperable but did work for a little while . This shows the circuitry may be okay . The laser and/or disc appears to be defective . ANY REPAIR SHOULD BE PERFORMED BY TRAINED PROFESSIONALS , USER OF THIS INFORMATION ASSUMES ANY AND ALL RISK AND OUTCOME . Does any one know a source for parts ?
3 Suggested Answers
SOURCE: TOC READ
I have the same problem... Any solutions?
Posted on Oct 13, 2008
  • 21 Answers
SOURCE: Emerson 3 Compact Disc Player
Hi
If the machine cant read the table of contents of a disc this would suggest either the lens of the optical pick up is dirty or the optical pick up has failed completely or something directly relating to the optical pick up i.e the spindle or stepper motor, if you can easily acess the optical lens you maybe able to clean it using a cotton bud and re-test, just try this with a dry contton bud to begin with if this gives an improvement you may wish to use a cotton bud with a alchol cleaner like I.P.A,
make light circular movements over the lens. If this makes no difference the machine requires repairing, so consult a local service engineer.
regards
TechSupp12
Posted on Dec 11, 2010
Stuck CD in JBL 4 disc CD Changer / Navigation
before you press the cd on button keep holding the eject button while you press power on, I know this works for computers etc.
Feb 13, 2016 | 2013 Toyota Highlander
Cd player is not reading cds what can i do to repair it.
Subject: Radio With Six Disc CD Changer Does Not Recognize Loaded CD And Displays An "INITIALIZING" Message, CD Will Not Play, CD Cannot Be Ejected, Or Disc Icon Does Not Illuminate (Reprogram Radio)
Models:
2005-2006 Chevrolet Avalanche, Suburban, Tahoe
2005-2007 Chevrolet Colorado, Express, Silverado Classic, TrailBlazer
2005-2006 GMC Yukon, Yukon XL
2005-2007 GMC Canyon, Envoy, Savana, Sierra Classic
2005-2006 HUMMER H2 with Six Disc CD Changer Equipped Audio System (RPO UC6)
Condition
Some customers may comment on any of the following conditions:
• The CD loaded in the radio will not play.
• The CD loaded in the radio will not eject.
• The disc icon on the radio will not illuminate.
• The radio displays an "INITIALIZING" message for approximately 30 seconds after vehicle start up.
Important: Do not attempt to play CDs with paper labels on them in this CD player. The labels may warp or wrinkle and jam the CD player mechanism. Refer to the Compact Disc Care and Cleaning procedure (Document ID# 1656123) in SI for more information.
Technicians are to reprogram the radio with new operating software using the following procedure:
1. If the radio has a CD(s)2008 General will be necessary to reset the radio and remove them
before the radio is reprogrammed. Remove and reinstall the radio fuse to reset the radio and then eject the CD(s). If cycling the power to the radio does not allow the CD(s) to be removed, the radio may have another failure that will not be corrected by the reprogramming procedure that follows. Refer to the Diagnostic Starting Point - Entertainment procedure in SI to begin your diagnosis of this failure to eject CDs concern before reprogramming the radio.
2. Reprogram the radio using the Service Programming System (SPS) with the latest software available on TIS2WEB. Refer to the SPS procedures and the Radio Programming and Set procedure in SI for more information. As always make sure your Tech 2® is updated with the latest software version.
3. Verify proper operation of the radio and make sure that all CDs can be ejected.
Hope helps (remember to rate this).
Oct 03, 2010 | 2005 Chevrolet Trailblazer Ext
Emerson 3 disk CD player - CD spins - message
im not sure what toc read means, my cd player says that im guessing it means its loading, any ways take the d player apart an clean the lens wit a cuetip that should work, or the cds may be to scartched to read
Oct 15, 2008 | Audio Players & Recorders
TOC READ
Sep 21, 2008 | Emerson MS3100 3-Disc CD Changer
TOC error message
Unit displays TOC error when I inserted two new cds I purchased.
Nov 05, 2007 | Audio Players & Recorders
Cd changer not working
It sounds like you have the same problem as me, I`ve left a message on Fixya, and someone has informed me that a kit of gears is availabe from http://carradiospares.co.uk/repair-8619001490-p-256.html?osCsid=b7ce3a0b7b492ec864e29579ad046166
I hope this helps you, because I`m going to order the kit ASAP Sincerely Ian C/O Shandy1
Nov 03, 2007 | Blaupunkt IDC-A09 5-Disc CD Changer
Won't play a cd
We have the same problem and are searching all over the web for a solution but no luck. If we find a solution we will come back and post what we found. :)
Oct 15, 2007 | Emerson MS3111M Shelf System
CD's won't play
I know that Panasonic provides chips, optics (laser),etc. to Emerson. I am familiar with the problem you've experienced because I've had a Panasonic CD Player. If the disc doesn't spin (as you said), the problem must be that your shelf system probably has an optical problem (laser problem/pickup problem) and will need to be serviced.
Apr 22, 2007 | Emerson MS3103 Shelf System
Emerson MS3100 3-Disc CD Changer Logo
221 people viewed this question
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
