Question about GE 27958GE1 Cordless Phone
How to open the handset
I can't open the handset for repairing. there are only two screws. I open them but still can not open the phone. need help...
There are two screws in the bottom back of the phone only. when I open them, the bottom side will lift up, but the upper side (anttena and LCD direction) is still sticked.
Posted on Mar 06, 2007
  • 72 Answers
Look for hidden screws under stickers, nameplates, etc. carefully pry open the case at its seam
Posted on Mar 03, 2007
Tip
Mobile Phone Tips & Tricks : Repair A Water Damaged Cell Phone
Learn how to save your cell phone when it gets water-logged. The next time when your get your cell phone soaked in water, tea or coffee, just remember and follow these simple and easy first aid measures. You will be more than happy and surprised to see your priceless mobile phone or ipod in working condition. You won't get frustrated of running around repair centers if you follow these simple tips. <br /> Most people don't know the basic steps to avoid a wet cellular phone from getting damaged. The most important thing is to follow the procedure to avoid damages to the circuit board (PCB) of the cell phone as it is what an engine is to a car. Preventing damage to the PCB should be the main aim as you lose warranty on the handset due to water-logging and in such cases most of the service centers don't provide a new circuit board and it is also not available in the open market. <br /> <b>Steps to repair and fix a water damaged cell-phone:</b> <ul> <li>Remove the battery immediately and don't just switch-off the handset. The removing of the battery is a must. <li>Now dismantle your cell phone carefully. To open your cell phone you need a torx T6 size screw driver and a tweezer. Remember the steps how you opened the phone as you will have to assemble it later! <li>Dry the green coloured circuit board carefully and completely. Use a hair drier or you can also dry it in sunlight or on the top of a TV or a computer monitor. <li>Dry the spare parts and components carefully. Be careful with the LCD as it is very delicate. <li>Clean the circuit board with spirit using a brush. This prevents corrosion on the PCB. </li></ul> <br /> Now re-assemble your phone carefully and if all goes well, your cell phone should switch on without any hassles. If it fails to switch on, charge your handset and try again. If it doesn't switch on now, luck is not on your side. You will have to get your phone repaired at a service center. <br /> <b>Note: If you are scared or not sure how to open your cell phone and follow these steps, don't go ahead to repair the phone yourself. You are more likely to damage the handset further. Just remove the battery and let a professional cell phone repair engineer </b>
on Jan 30, 2011 | Cell Phones
My phones are not working at says out of range.
When a cordless phone says "Out of Range" or "Searching for Signal", there are a number of possible issues (assuming you are close to the base). 1) The handset battery may be low and not taking a charge. If the battery is more than a year old (including time spent in storage), replace the batteries for both handsets.
2) The base may not have power or an incoming telephone line signal. Check that the power adapter is warm (power to the base). Use another phone cord (and a second phone (preferably corded) to check for a dial tone). If a second phone has no dial tone, see below for diagnosing a phone line.
3) The phone base has lost the registration information for the handsets. A way to reset the phone is to unplug the power cord (from both the wall outlet and the phone base) and the phone data line and unplug the batteries from all handsets. Wait several minutes then plug in the base power and data cords and then reconnect the phone batteries. You may want to re-register the handsets. This is done by putting the handset in the main charging base for 20 seconds when the handset is fully charged. (See your phone manual) The phone was made by Thomson Electronics for GE; the manual is available here: http://www.home-electronics.net/USER-GUIDES/25952_DOM_EN_CL_IB.pdf .
4) The phone base or handsets are not transmitting or receiving the signals properly. This means that the phone needs repair or replacement. If it is under warranty, contact the manufacturer. Otherwise decide if the phone is worth the repair costs.
If you have no dial tone at the jack where the base is connected, check another phone jack on that line. If you still have no dial tone, find where the phone service comes in. Then open the service box and if the service is fairly new, plug in the RJ-11 test phone and listen for a dial tone. If you can't plug in the phone cord or there is no dial tone, contact your service provider. They will test and fix any outside problem.
If the problem is inside, inspect the visible wires. If you have a DSL filter as part of the inside wiring, check/replace it. If only one jack has a problem, open the faceplate and fix any loose wires. There are two faceplate designs - screw terminals or keystone jacks. For the screw-type, the conductors must be stripped and secured under the screws. For the keystones, the conductors are not stripped but pressed into the terminals with a punch-down tool. This tool is available at many home improvement stores in the wiring aisle. See http://www.lanshack.com/wire_phone_jack.aspx for a diagram of the wiring.
If the problem is not in a visible part of your wiring, you may want a professional to find and fix the problem. Your telephone provider will be willing to do the work for a fee.
I hope this helps.
Jan 20, 2012 | GE 25952 Cordless Phone
I have sony spp m920. I have had it for long time and it's really great. My problem is that the lcd on the handset is no longer working (it only shows fragments of numbers,etc.) this is the older model...
If the hardware/physical part is ok, then it must be the battery. Are there any screws to open the handset or a small compartment in the back where batteries may be?
kc
Mar 24, 2011 | Sony SPP M920 Cordless Phone
Panasonic KX-TG2356 Cordless Phone key pad
Open the hand set by Removing battery, remove 2 screws under battery, carefully open handset casing by prying open with thin bladed screwdriver, remove pc board by removing 3 retaining screws, on opposite side of pc you will see contacts for handset buttons clean with eraser and reassemble handset.
Jan 24, 2010 | Panasonic KX-TG2356 Cordless Phone
I hav sony ericsson w200i handset.forgot my phone code.
You need to take yr phone to a repair shop. They will help you take backup of the data if necessary and reset the phone.
regards
Sandeep
Oct 25, 2009 | Sony Ericsson W200i Cellular Phone
Openning a panasonic cordless phone handset
Carefully slide a thin bladed jewellers screw driver along the side of the case as you go the catches will release, do not force it !!
Good luck
Jan 11, 2009 | Panasonic KX-TG6021M Cordless Phone
Need to open handset for kx-tc1025 cordless phone. has 2 screws in battery compartment
After taking out the two screws from below the battery compartment, the case will separate slightly on the bottom. Take a screwdriver and carfully pry the case open along both sides, working from the bottom toward the top of the handset. This will free the back of the handset from the primary components. It will simply snap back together when done and then replace the two screws.
Apr 05, 2008 | Panasonic Lands Phones
Open the handset to clean keypad
Hi Sue,
Sometimes there's a screw or 2 inside the battery compartment, other than that they snap together.
Once you get the keypad out, wash it in warm water with a couple drops of dish liquid, rinse and pat dry. The Pc Board the keypad sits on can be cleaned with alchohol and Q-Tip.
Hope that helps.
Geno
Apr 01, 2008 | Panasonic KX-TGA650B Headset Phone
GE 27958GE1 Cordless Phone Logo
359 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
