Question about HP Computers & Internet
Local area connection: 'Local only'
I've been trying to connect to our department's local network. They've already added my Ethernet address in and my machine can detect the network.
But in the 'Network and Sharing Center' it always shows as: 'Access: Local only'. I cannot connect to either the Internet or our department's system. I tryied to 'Diagnose' for a couple of times, but it didn't help at all.
I've disabled my wireless adaptor.
I have successfully connected only once, by chance. I even didn't know how I made it. Later on, even though I tried everything I could think of, it never works again.
  • 3 more comments
  • celeste_cy Dec 11, 2008
    I did everything you mentioned before... exactly as you mentioned. But none of them worked. Thank you all the same.
    It is DHCP. I'm connecting by cable. No problem drivers, I believe. Thank you~~~
    I've just changed a new cable, but it doesn't work.
    BTW, our department's technique support people is trying to help me now. But he cannot figure it our either.
    He said that the machine can get to the DHCP server(? can't remember clearly). It can see the other computers nearby, but it can't connect to them. It can get to the switch, but it can't get through it...
    Do yo think it would be some hardware problem? Though it is a brand new machine. Things like the ethernet adapter/card(?) is a little bit loosen? or anything else? I'm just wondering....
  • celeste_cy Dec 13, 2008
    The order is exactly the same as you wrote.
    The wall jack is fine coz my laptop works very well with it.
  • celeste_cy Dec 15, 2008
    Hey,
    Thank you so much for your help! The problem has just been solved. It has nothing to do with my computer. It is some misconfiguration of the DHCP server... though I don't understand why it works well with all other computers...
    Anyway, thank you soooo much~~~~ I've learned a lot through the conversations with you :)
    Scholar:
  • 68 Answers
Does your department use DHCP? (It will automatically update your computer's settings when connecting)
If so, I would go into your TCP/IP Properties and make sure its set to automatic as well.
If not, you need to go into your TCP/IP Properties and put in the IP Address, Subnet, Gateway, and DNS servers information.
Also try opening command prompt and doing IPCONFIG /RELEASE then do IPCONFIG /RENEW.
Lastly, sometimes you can right click on the connection icon by the clock and do a repair, that will do pretty much the same thing, but sometimes works.
Posted on Dec 10, 2008
  • 2 more comments
  • James Swafford Dec 11, 2008
    What settings does your department use? DHCP or STATIC? Is there a network admin? Are you connecting wirelessly? In device manager, are there any problem drivers?
    Have you tried a new cable? How about plugging into a different wall jack or switch port?
  • James Swafford Dec 12, 2008
    At this point, I would check a number of things.
    I always like to check software first, but we already went through that.
    Then cabling... Unless your desk is in the wiring closet, I would check that another computer (a laptop for example) can connect okay using your wall jack, and your patch cable. If it can, then it has to be your computer. A network card is very inexpensive, and if they are a normal IT dept. they have about 20 in a box somewhere.
    If the other computer cannot connect, then I would check the wall jack, and then the switch.
    Can you tell me the order of devices to get you to the network?
    Typically...
    Internet -> High speed Modem? -> Router -> Switch -> Wall Jack -> Computer
  • James Swafford Dec 15, 2008
    I am glad you figured it out. Have a great day!
D link router connection Hi I have recently bought a D link Dir 615 router and cannot connect to internet on my vista laptop. I have set up wireless on another laptop, PS3 and blackberry phone and they...
Everything looks normal:
Description . . . . . . . . . . . : Atheros AR5007EG Wireless Network Adapter
Physical Address. . . . . . . . . : 00-1D-D9-44-F8-15
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::1c05:824a:4808:dd81%14(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.0.102(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : 21 February 2011 13:48:48
At the command-line prompt, try: ping www.ucla.edu
If it responds, then you *DO* have a good Internet connection.
Feb 21, 2011 | D-Link Computers & Internet
Tip
HOW TO CHANGE IP ADDRESS
To change your network IP address in Windows XP, Vista, or 7:
1. Press the Windows Key and R
2. Type command and press Enter. This loads your DOS prompt
3. Type ipconfig /release then press Enter. This disables your internet connection
4. Go to your desktop, and right-click on something called Network Place or My Network Places (If you're using Windows Vista or 7, look for the Network and Sharing Center through Control Panel)
5. Click Properties. You should now see something called Local Area Connection or something similar
6. Right-click on your connection (titled Local Area Connection if you're using an ethernet cable or Wireless Network Connection if you're on WiFi) and click Properties
7. Under the General tab, double-click on the Internet Protocol (TCP/IP)
8. A new window appears. On its own General tab, click the box beside Use the following IP address
9. Type in ones until you fill the box up (it should read 111.111.111.111)
10. Press Tab. You'll notice the Subnet Mask section automatically fill sup with numbers
11. Click OK
12. Click OK to bring you back to the "Local Area Connection" screen
13. Right-click Local Area Connection and Click on Properties again
14. Again, under the General tab, double-click on the Internet Protocol (TCP/IP)
15. Select Obtain an IP address automatically
16. Click OK
17. Click OK
18. Go back to your DOS prompt, type "ipconfig /renew" and press Enter. This restores your internet connection.
By now, the network should've assigned a new IP address to your computer automatically.
on Jul 22, 2010 | Computers & Internet
How to enable WPA security. i tried to enter the http://www.192.168.0.1 but the page is not showing theres no admin page.help pls
Try http://192.168.0.1 - you don't enter www. in front of an IP. Check that this is actually your routers IP address by doing Start > Run. Type "cmd" without the quotes and press Ok. In the black window that pops up, type "ipconfig" without the quotes. You'll see something like this:
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\root>ipconfig
Windows IP Configuration
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
IP Address. . . . . . . . . . . . : 192.168.0.2
Default Gateway . . . . . . . . . : 192.168.0.1
Ethernet adapter Local Area Connection 2:
Media State . . . . . . . . . . . : Media disconnected
Ethernet adapter Bluetooth Network Connection:
If your Default Gateway Value is 192.168.0.1 then you're good to go, otherwise this value will be what your routers address will probably be.
Mar 01, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Internet Won't Connect
Press Start->Connect To -->Show all connections.
If the Local Area Connection icon is crossed with a red X, right click it and choose (Enable, or Repair).
If there is no Local Area Connection icon, you must create a connection.
In the left panel in Network Connection window click create new connection.
1.The wizard pops up
2.Click Next.
3.Put a (dot)mark in Connect to the Internet .
4.Click Next
5.Choose Set up my connection manually
6.Click Next Choose the type of connection you have with you ISPN (dial up, etc.)
7. Click Next , and follow the instruction from here.
Hope it helps you find your way to a solution
Aug 30, 2009 | E-Machines Computers & Internet
Ethernet on DELL 4550 with TP-link doesn't work
pinging 127.0.0.1 just tells you that your network card is operational and reacheable by your system.
I have a couple of suggestions - check them out and let me know what you found out.
  • Go to Network Connections / Local Area Connection / General Tab / Properties / Internet Protocol (TCPIP) (from the list)/ Properties. Are all settings set to "Obtain automatacally..."?
  • Is your operating system Windows XP Home or Professional (with Service Pack 2 installed)?
  • Have you installed the AirPort Utility software that came on the CD? (Check Start > All Programs > AirPort)
  • You have to have the software installed in order to setup the router.
  • What is your internet connection: Cable or DSL?
  • Take a look at this document "Designing AirPort Networks" which is also on the CD that came with the device. If you don't have it, here is the download (link). Go to page 25 and follow the instructions for PPPoE (if you have DSL service) or DHCP (if you have cable service).
Let me know how that works for you and if you have any more questions, just come back here and leave a comment - I'm happy to look further into that if this did not work for you.
May 27, 2009 | Dell Dimension 4600 PC Desktop
No internet connection
Internet connection solutions
  1. Restart the computer.
  2. Test the jack.
  3. Test the equipment.
    1. Try a different jack that you know works.
    2. Try a different cable that you know works.
  4. Check your computer settings.
  5. Renew your IP Address
    1. [x] Windows Vista
      1. Look for your Ethernet card:
        1. Right-click on My Computer from the Start Menu or on the desktop.
        2. Left-click on Properties.
        3. Click on Device Manager on the left side under "Tasks".
        4. Expand the Network Adapters and look for any yellow exclamation points. Make sure a card is listed.
        5. If there are exclamation points, or if there is no card listed, you need to reinstall the card.
      2. Set your IP address to configure Automatically (through DHCP):
        1. Go to the Control Panel in your computer (in the Start Menu).
        2. Go to Network & Sharing Center.
        3. Under "Network", go to Local Area Connection and select "View Status". In new window, choose Properties at the bottom.
        4. Scroll down "This connection uses the following items" list to Internet Protocol (TCP/IP).
        5. Select Internet Protocol (TCP/IP) and click Properties.
        6. Change to "Obtain an IP address automatically".
        7. After you have changed this, restart computer.
      3. Check to see if your network connection is on:
        1. Go to the Control Panel in your computer.
        2. Go to Network Connections. If you cannot see Network Connections, go to Network and Internet Connections and then go to Network Connections from there.
        3. If there is a red X through the Local Area Connection, or the Local Area Connection is grayed out, double-click on the X to enable.
    2. [x] Windows XP
        2. Left-click on properties.
        3. Go to the Hardware tab and click on Device Manager
        3. Right-click on Local Area Connection and go to Properties.
        4. Scroll down the "This connection uses the following items" list to Internet Protocol (TCP/IP).
        7. After you have changed this, restart the computer.
        3. If there is a red X through the Local Area Connection, or the Local Area Connection is grayed out, click on Local Area Connection and click "Enable."
    3. [x] Macintosh OS X (10.4 or "Tiger")
      1. Look for Network Cards:
        1. Go to the System Preferences panel from the Dock or Apple Menu.
        2. Open Network icon under Internet and Network.
        3. This shows your current network settings. Green lights for each device means it is connected and red mean there is no connection.
        4. Go to Show and then click on Built-in Ethernet.
        5. Under the TCP/IP tab make sure "Using DHCP" is chosen under the top option.
      2. Renew IP address. Hit "Renew DHCP" or change it to a manual address. Then restart and change it back to DHCP to renew the connection.
      3. Set your IP address to "Configure Automatically using DHCP". Under the Ethernet tab make sure that configure is set to "Automatically". Click OK until you are back to the main System Preferences windows.
      4. Check your privacy setting
        1. Go to Sharing under Internet and Network in System Preferences
        2. Under Services everything should be unchecked.
    4. [x] Macintosh OS X (10.5 or "Leopard")
        3. The left menu shows your current network settings. Green lights for each device means it is connected and red mean there is no connection.
        4. Select Ethernet from the left menu. Go to Advanced.....
        5. Under the TCP/IP tab make sure "Using DHCP" is chosen under the top option, "Configure IPv4".
      2. Renew IP address. Hit "Renew DHCP" or change it to a manual address. Click OK.Then restart and change it back to DHCP to renew the connection.
      3. Click OK until you are back to the main System Preferences window.
    // MAIN FUNCTION: new switchcontent("class name", "[optional_element_type_to_scan_for]") REQUIRED // Call Instance.init() at the very end. REQUIRED var bobexample=new switchcontent("switchgroup1", "div") //Limit scanning of switch contents to just "div" elements bobexample.setStatus('[x] ', ' ') bobexample.setColor('#674a80', '#3b5998') bobexample.setPersist(true) bobexample.collapsePrevious(true) //Only one content open at any given time bobexample.init()
  6. Make sure your computer is clear of all viruses, spyware, and adware.
Oct 03, 2008 | Computers & Internet
Wrong ip address
Are you trying to get an IP for your computer, or for your modem? Assuming your using a high-speed connection, possibly a router?
Mar 28, 2008 | Computers & Internet
Computers & Internet Logo
915 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
