Question about Olympus D-535 Zoom / C370 Zoom Digital Camera
Lens Stuck Out/Will Not Go Back In
I was taking pictures with an incredibly low battery and the battery finally gave out and the camera just shut down while the lens was still zoomed out and everything. I put like ten sets of fresh batteries in the camera and it still won't turn on and is just sitting there with the lens out and everything. Help!
  • davis11789 Nov 27, 2007
    My camera worked just fine, an d now when you try to turn it on it just zooms in zooms out and displays a black screen for about 3 seconds and then shuts down with the lens still out!
I had the same problem and tried removing the batteries and closing the cover and then plugging in the USB cable. The camera only started to work when I then put in new batteries whilst the USB cable was still attached.
Posted on Mar 28, 2008
Try using the usb to power it. remove the batteris and close the cover then plug in the usb lead into the camera then the computer.
Posted on Sep 04, 2007
  • 114 Answers
Well u have a problem, and u will need to replace the mainboard. if it´s under warranty send it to the repair centre they will replace mainboard for free
Posted on Mar 01, 2007
Camera shuts down when 'zoom lens' is used.
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine .
Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a
back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec ..
in not done the press both Menu & self time key for 2 - 4 sec.
Jun 10, 2010 | Kodak EasyShare C913 Digital Camera
It just shut off....
it normally indicates a problem with the batteries. Try inserting disposable alkaline battieres in the camera and turn it on.
If the lense is still out at the moment try pressing the play button the back of the camera to view the pictures taken, even with a very low battery this normally close the lense properly and enables you to view the pictures.
Nov 15, 2008 | Kodak EasyShare C613 Digital Camera
Camera shuts off after a few seconds
i had that problem with another camera i toggled with the lens it went in and works like a charm. Dont be to gentile it will go in
Oct 08, 2008 | Samsung S630 Digital Camera
Lens error,restart camera
My Camera: Canon PowerShot SD770 IS Digital Camera
Went to the beach yesterday, by the end of the night my camera gave me this error: "lens error, restart camera". The lens would no longer come out.
I figured sand got stuck within the lens, so I did the following:
1. Turn camera up-side-down (with lens facing down)
2. Gently tap the sides of the camera (to loosen particles in lens)
3. Turn camera on
4. The lens will eventually come out
5. Gently tap the sides of the lens
6. Turn camera off (continue tapping side of lens as it retracts)
I turned the camera on and off a couple of times to ensure I removed all sand particles from the camera.
Now the camera works...thank god.
Aug 31, 2008 | Canon PowerShot SD600 Digital Camera
My nikon says lens error
my camera says lens error. the lens is also stuck in the position as if it where taking pictures. it will not retract.
Jun 16, 2008 | Nikon COOLPIX L5 Digital Camera
Sanyo vpc-503
well if lense stuck in your neighborhood there should be a camera store you should take it in and have your cam. serviced for a clean
the other thing could be memmory card is full
or the camera is on but just not like the light or focus check all above
hope this helped
May 07, 2008 | Sanyo VPC-S500 Digital Camera
Camera keeps shutting off
Have you fully charged the new batteries
Nov 03, 2007 | Fuji FinePix A345 Digital Camera
Camera won't turn on/lens extended
General system failure- Contact Samsung for repair cost.
Aug 30, 2007 | Samsung Digimax S500 Digital Camera
Canon A75 stuck between ON & OFF after uploading photos
My Canon A75 has the EXACT same problem. I have always handled it with care. When I was taking photos with it, the camera suddenly started shutting down without a low battery warning. It just started shutting down, but it stopped with the lens still sticking half way out. Like yours, the top green light flashes when I try pressing the power button. Any ideas?
Dec 16, 2006 | Canon PowerShot A75 Digital Camera
Samsung Digimax V4 Power Consumption
I had similar symptoms as well until it finally died: 1) First started eating batteries like crazy, especially standard AA and rechargeables. The CRV3 seemed to work a bit longer. 2) One day out of nowhere the autofocus stopped working. I replaced the batteries and it worked again for 10 shots. Then the autofocus stopped working and battery died (with the lens stuck open). Pressing power, the LCD backlight flashes on, the LED in the view finder blinks, and the lens motor makes noise. Then nothing just stuck open. 3) Again new batteries and was able to close lens, take a few pictures and dead again with lens stuck open - same problem in 2. 4) Replaced the batteries a couple times and was able to get a shot or two off, and now its complete stuck open, even with brand new batteries - with same problem in 2 it just won't turn on. I finally sent it to Samsung the week of Christmas. I called Friday 1/7/05 to check and had to leave a voicemail. They called back Monday 1/10/05 to let me know they recieved it and that I should call back Thursday to check its status.
Sep 12, 2005 | Samsung Digimax V4 Digital Camera
Olympus D-535 Zoom / C370 Zoom Digital Camera Logo
141 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
