Question about Bosch Classixx WFO 2866 Front Load Washer
Washing machine Rattle coming from drum seems to be wire or nailor small piece of plastic which has worked its way thro the small holes. How can I get it out.
WE have a Bosch WFK 2401 with a similar problem. Will the solution involve the same steps?
Posted on Aug 20, 2007
  • lymp Aug 20, 2007
    I have a Bosch WFK 2401 with a similar problem. Should I follow the same steps for the repair?
    Problem Solver:
  • 6 Answers
There are 2 ways: 1. Tip machine on its back and remove the sump hose from the bottom of the tub, and root around inside. This option doesn't give you much play. 2. Remove the from of the machine and the heater element. 1. remove soap drawer and undo resessed screw 2. remove kick strip and remove screws behind it 3. remove door seal band and front of door seal 4. slide front panel down and towards you to remove. 5. remove heater element to gain access to inner drum. With the sump hose also off you should be able to remove the foreign object. http://www.ransomspares.co.uk/bosch-washing-machine-spares.html
Posted on Mar 01, 2007
I have whirlpool LHW0050PQ4 washer, after connect prower, start light is flash and hear click but no water in and is not working
Hello.
It can be tempting to ignore washing machine noises, especially if the machine is still working. But washing machine noise is not only annoying, it can also be a sign of serious damage. When armed with a few tips, you can determine what problem may be causing your washing machine to rattle, and what you can do to stop it.
1 Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
2 Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. (When the bearings have gone bad, the noise is constant the entire time the drum is spinning.)
3 Look for obvious dents and creases in the drum or look for coins or small objects stuck inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub.
4 Clear the water pump from obstructions like coins or small objects when a noise occurs while the washing machine is emptying water.
5 Remove the sump hose and look for bra wires if you hear a light scraping noise when the drum is turned by hand. You can also check to make sure a wire isn't poking out of one of the holes in the drum. In this case, you can pull the wire out easily with pliers.
6 Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.
Thanks.
Nov 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer makes a rattling noise when spinning
Hi
If its rattling check the drum for anything caught in it.Washing machine noise is not only annoying, it can also be a sign of serious damage. When armed with a few tips, you can determine what problem may be causing your washing machine to rattle, and what you can do to stop it.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 03, 2011 | GE Spacemaker WSLP1100D Top Load Washer
Scraping sound from dryer when running
If the sound seems to come from the front of the drum it's probably the felt guides. The bottom one will wear first and make a grinding, rattle like sound. You can access it by removing the front panel which includes the door. It fits around the drum at the front. Here's a diagram. Some models have a two piece and some a one piece guide. Part 4 on this diagram is one. It's called a seal here.
If the sound comes from the rear, there is a nylon bearing and metal socket at the rear center of the drum.
May 31, 2011 | Kenmore 98702 Stacked Washer/Dryer
Making noise when running
Instructions: 1)Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings. 2)Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. (When the bearings have gone bad, the noise is constant the entire time the drum is spinning.) 3)Look for obvious dents and creases in the drum or look for coins or small objects stuck inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub. 4)Clear the water pump from obstructions like coins or small objects when a noise occurs while the washing machine is emptying water. 5)Remove the sump hose and look for bra wires if you hear a light scraping noise when the drum is turned by hand. You can also check to make sure a wire isn't poking out of one of the holes in the drum. In this case, you can pull the wire out easily with pliers. 6)Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.
Feb 09, 2011 | Washing Machines
LOUD RATTLE ON WASH AND SPIN REMOVED DRUM COVER AND FOUND PIECE METAL COULD HAVE COME OFF ELEMENT BRACKET. ELEMENT NOW CATCHING ON DRUM
You will have to remove front panel of washer , and replace the heater, and heater retaining plate, which is the piece that has come off.
Please rate my solution.
Thanks.
Jul 16, 2009 | Hotpoint WM56 Front Load Washer
Something rolling inside the Drum
The rear half of the outer tub, with bearing is part # 131525500 and it looks like the back "spider" shaft is not available as a separate part from the inner drum. The "spider" shaft is most likely worn or damaged and in need of replacement also.
131618500
Then, there's that strut
134564200
Now, two pain in the back side hours of your labor and you've got your washer back, at more than what a new one would cost! Junk it and get a new larger capacity front loader.
Please don't rate this, as anything but the top rating will lower my score. I'm just giving you my honest opinion, that your machine is not economical to repair. I've owned a LG front loader for over 6 years and think they are the best, but there are other good front loaders out there also.
May 19, 2009 | Frigidaire GSTF1670A Front Load Washer
Debris being released from washing machine
This is from the drum seal or bearing. Check/replace.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Jan 11, 2009 | Washing Machines
Whirlpool Ultimate Care II drum does not spin.
Depending on your washing machine model, the drum and motor are connected by 2 plastice yellow circular pieces, with a black rubber washer in the middle with holes where the pegs or rods go into. The 2 plastic circular pieces have 3 pegs or rods if you will, that connect to the black rubber washer via 3 holes. Sometimes, one or both of the 2 plastic circular piece pegs get broken off or the rubber washer cracks and breaks apart, so that the motor will not turn the drum. If thats the case, you can purchase the 2 circular pieces and black washer piece as a set.
Jan 05, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Ticking noise in spin
Possible. First run your hand around the inside drum...be careful...sometimes there can be an object stuck in the holes and the extra vibration can set it off. common objects are bra wires and hair clips (sorry ladys its the truth) followed very closely by......(you guessed it ladys) Nails
Jan 03, 2008 | Bosch WFMC 3200 Front Load Washer
Hotpoint WMA56 - Puts holes in washing
could well be a bra wire. the easiest way to check is: remove small cover on rear bottom of machine. you will see the heater on rhs. loosen centre nut and prise heater out. shine a torch down the hole and turn the drum slowly and any foreign object should be apparant
Jun 10, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Open Questions:
See all Bosch Classixx WFO 2866 Front Load Washer Questions
Bosch Classixx WFO 2866 Front Load Washer Logo
320 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
