Question about Ryobi 26CC, 22 In. Hedge Trimmer
What is the gas & oil mixture for ryobi 26cc 22in hedge trimmer
If oil is used what type & what is the mixture balance
  • 3 Answers
If it is a 2 stroke engine, a 50:1 ratio should work. That's 50 parts gas to 1 part oil.
Posted on Dec 14, 2008
Gas oil mixture
use a good quality 2 cycle oil at 50:1 thats about 2.6 ounces of oil per gallon if you are using Red Armour or most other high quality oils. I have ran everything that calls for 40:1 at the 50:1 ratio with NO failures using Opti 2 premix.... all modern hand held equipment is usually 50:1
Dec 22, 2013 | Ryobi 26CC, 22 In. Hedge Trimmer
I Have a 26 cc ryobi hedge trimmer. I cannot find any where to oil the thing. I've just been oiling the blades. I know its a 2 cycle but shouldn't there be some where to oil the blades other than dir
check to see if there is any holes in top or bottom of bar to grease or oil, if not there should be screws on bar to remove cover to gain access to blades, also on bottom of engine there is a cover useully with 2-3 screws holding it in. remove cover to grease gear mechanism, do not remove gears inside.
Dec 01, 2011 | Ryobi Factory-Reconditioned 26cc 22" Gas...
Please tell me exactly how I mix the gas and oil for my 22 in gas hedge trimmer Ryobi Model RY39500A HT 26. What type of gas, what type of oil. Also can I buy this premixed?
If you go to your local home center in the lawn care section they will have these little plastic bottle of two cycle engine oil they treat a gallon of gas if this is your only machine that mixes gas and oil you probably will not use a whole gallon in a season and you should not keep the mixture for to long it will not last. So doing some simple math and looking at back of container try to mix the ratio down if a whole gallon is not needed. Good Luck...
Sep 05, 2011 | Ryobi 26CC, 22 In. Hedge Trimmer
I have got 26cc homelite hedge trimmer what type of 2 stroke oil do i need for it, MANY THANKS
You can use any brand of two stroke oil as long as it says on the container that it is suitable for air cooled engines and you need to mix it at a ratio of 25 to 1. Regards Phil
Apr 19, 2011 | Homelite Garden
How much oil goes into the fuel of the homelite 240 chainsaw
please check your manual,some are 25:1,40:1 but get the mixture right as you can damage the machine.
Sep 25, 2010 | Homelite Factory Reconditioned 26cc...
Does a Ryobi trimmer S430 not use a fuel mixture?
the Ryobi S430 is a 4 cycle engine. As such it has an oil reservoir which takes 30 weight oil. It uses straight gasoline in the gas tank.
Sep 03, 2010 | Ryobi Garden
Ryobi 26CC, 22 In. Hedge Trimmer Logo
1,020 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
