Question about D-Link / RangeBooster N 650 / DIR-635 / 300Mbps / 802.11n / 4-Port / Cable/DSL Wireless Router (DIR635)
D-link dir-300 router always rebooting/restarting
I just set up a d-link dir-300 router, but it keeps on restarting every few seconds after i have set it up with the setup disk.
It keeps on restarting, so I can't really go inside the router to tweak settings.
Also note that this is the 2nd router of the same model that i had the problem (i had the first one replaced since i thought i was just defective) but since it happened again with the replacement, it think it must be something with my PC or network.
PS: I'm using a wired PC to do the setup
  • Anonymous Dec 25, 2008
    the problem is exacly like yurs..
    Scholar:
  • 108 Answers
This is the fix from d-link:
Router rebooting itself d-link dir-300 router always rebooting/restarting - print.gif You may be experiencing trouble with a feature known as UPnP(TM). This feature allows Windows XP and Me machines to remotely open necessary ports for Internet Applications. You may try disabling UPnP (on the router AS WELL AS your computers) to see if this cures your reset woes. Log into the web-based configuration, access the Tools page, then the Misc. button. Choose the disabled button next to UPnP. Click Apply. You should no longer experience the frequent resets.Try disabling in XP first to see if that fixes issue.
To manually disable UPnP/SSDP in Windows 2000/XP/Vista:
  • Go to Start Menu-->Run...
  • Type "services.msc" and click OK
  • Find the service named "Universal Plug and Play Device Host" service
  • Click the Stop button to stop the service
  • Under Startup type, select Disabled from the pull-down menu and click OK
  • Find the service named "SSDP Discovery Service" and double-click
Posted on Jan 17, 2009
Had the same "frequent reboot, no reason" problem after 2 years after I bought it.
What helped a little was a factory reset (button on the back of the router), so I could at least access the web-interface without constantly being thrown out again.
The fix was to upgrade to the latest firmware (from 2.20EU to 2.33EUb01) in my case. Now the thing works like a charm again.
Posted on Sep 11, 2010
  • crisbi Sep 11, 2010
    forgot to say: the solution from "XopenX" did not work, unfortunately.
I have a d-link dir-615 password won't work need to reset it.
put the special reset button at the back for a few second with a pin.
When reboot ready,
Step 1: Open your web browser and type in the IP address of the router (192.168.0.1 by default).
Step 2: Enter the username (admin) and password (blank by default), and then click Ok or Log In
Then change settings and passwords.
Jan 01, 2014 | D-Link DP 300 (DP-300) Print Server
How can i reset my d-link router 300 at change the password? pls help me,
With the router on, look at the back of the router. Push in the 'reset' button and hold for a few seconds. This wil restore the router to it's original state.
Hope this helps!
Sep 24, 2011 | D-Link DIR-300 Wireless Router
I have a dlink dir600. My problem is when i turn it on only power light glowing remaing not responding. Try reboot by click and hold the restart button at the back to use restore factory but no use it wont...
First reboot your modem(NOT the router), unplug for ten seconds and plug back in, wait til everything comes on. Now unplug the router, wait ten seconds and plug it back in. If it still does the same thing, reboot by holding the reset button down for 10 seconds and see if it restores to factory settings. If still no luck then there may be an issue with the router.
Aug 06, 2011 | D-Link DIR-615 Wireless Router
How do I reboot my DIR-300 router?
remote reboot:
1) login into router
2) http://$address/sys_cfg_valid.xgi?&exeshell=submit%20REBOOT
where $address is IP address:port of your router
Apr 13, 2011 | D-Link DIR-300 Wireless Router
Dir-300 dlink router asking to reset to factory after installatio
there's an easy way to reset your router back to its factory setting... inspect the physical appearance of your router... there should be s small hole.... inside that small hole is a reset button
How to reset? ..... while the router is on...Using a small pointing object, much better if you use a paper clip..... insert the paper clip to the hole... press and hold the reset button for 10 seconds...
That's it your router will restart itself and the settings is back to its factory settings...
Hope that help you..
Much appreciated if you rate this help... thanks
May 22, 2010 | D-Link DIR-300 Wireless Router
Cannot rest dlink 300
Have you tried getting a slim object like a pen nib and poking the reset button, hold it for about 10 seconds and then release, it will take about 30 seconds to 1 min to reboot, this will do a hard reset and it will deleete all of your settings. that should reset it. Guy
Dec 30, 2009 | D-Link DIR-300 Wireless Router
Hi i have tried many times to get my ntl modem to work with a new dir-300...it all goes well til the save settings screen comes up then it says ethernet cable not conected or unable to detect modem..etc...
After you click 'SAVE', the router will restart itself.
While it is restarting, it briefly disables its Ethernet ports,
and your computer will report "not connected".
Wait 60 seconds, while the router finishes its restart,
and those Ethernet ports will be re-enabled,
and the pop-up balloon on your computer will close itself.
Dec 29, 2009 | D-Link DIR-300 Wireless Router
D Link DIR-300 - Connection was Reset - Unable to set up router
press reset button for 10 seconds then all settings are defaults.
you can access your router witrh following link
http://192.168.0.1 or
http://192.168.1.1
Jul 14, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Computers & Internet Logo
2,646 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
