Question about HP PSC 1315 All-In-One InkJet Printer
1015v Hp all in one printer, paper jams
My printer takes in the paper but gets stuck everytime halfway through. If I open up the front sometimes it will come out on its own and sometimes I have to pull it through but it doesn't print because of the jam. Can you help?
  • 3 Answers
I think your paper to use a sub-20...
Posted on Dec 10, 2008
My new printer shows it has a paper jam but does not how do I fix this problem
paper may be jammed in lower tray pull the paper if stuck there,may be at registration *** open the front door take out the tooner & pull out the paper,if it stuck in o/p bin then open the rear door & pull out if altough it shows paper jaamed then blow the air by blower your problem will be resolved
Sep 03, 2010 | HP P2035N LaserJet Monochrome Printer
Tip
Paper Jam Error on HP Printer
Paper Jam is the most common issue in all the HP Printers ( Officjet, Photosmart, Deskjet Printers )
What Causes a Paper Jam ?
  • Paper thickness.
  • Room temperature OR due to Dust in atmosphere or the room.
  • Paper pulled out in a hurry and paper pieces stuck in Rollers or Carriage
  • Could be Hardware Failure
NEVER PULL THE PAPER STUCK IN THE PRINTER FROM FRONT SIDE OF THE PRINTER ( unless the paper is 3/4th visible in front view if you open the printer front panel door )
Follow the instructions below to resolve Paper Jam issue.
  1. Turn off the printer.
  2. Open the rear access door ( or duplexer )
  3. Check for any bits of paper stuck, if so, remove them.
  4. Open the front access door where you see the cartridges.
  5. Check for any paper pieces, if so, remove them.
  6. Take a lint free cloth. Little bit Damp ( use water )
  7. Clean the Rear rollers pushing it upwards and close the door.
  8. Close the front access door.
  9. Connect the power cord and power on the printer.
  10. It should be ready to print/copy/scan/fax.
To clean the duplexer ( 2 - sided printing device ) remove the duplexer and clean the rollers you find inside.
If the above steps do not solve your problem, you printer needs repair. Contact HP. ( 1-800-474-6836 )
If the printer is In-Warranty please contact HP for replacement. HP may charge for repair for Out of Warranty printer.
Find the Video below for paper jam cleaning
Regards,
Ron
Your rating will help us improve the service we provide
on May 20, 2011 | Office Equipment & Supplies
Paper jam message no paper jam cartridge gets stuck HP 6310 all in one
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Jan 11, 2010 | HP Officejet 6310 All-In-One InkJet...
Frequent paper jams on a Dell 1600n AIO, sometimes doesn't grab the paper from the tray (not really a jam, just need to open and close tray), sometimes gets caught halfway through the path -- need to open...
This could be caused from the papers you use at times(weight). Call on a Dell representative to check it out for you if you bought it from a Dell shop.
Thanks
Aug 19, 2009 | Dell 1600n All-In-One Laser Printer
HP LaserJet 1320 folds over top left corner of every page printed
I see this problem alot after a paper jam occurs and someone has pulled the stuck paper out. There is probably a piece of paper stuck in the printer somwhere. If you open the front toner door and take the cartridge out, you will see a roller at the bottom front. DON"T touch the roller but take it out. You may find the paper there!
May 24, 2009 | HP LaserJet 1320 Printer
Konica minolta pagepro 1400w paper jam
have you tear the paper when removing? there is a small paper left still inside the paper path. open the back side and the top part and check for small paper. I hope that will solve your problem and if think the problem still there the problem is one of the paper sensor actuator is broken or out of place.
Feb 04, 2009 | Konica Minolta PagePro 1350W Laser Printer
Paper Jam HP 1350 All-In-One
The back of the HP psc 1350 DOES open! I got a 4x6 photo paper stuck too. After finding no help in the HP software manual, I accidently noticed that if you look closely at the back that grey area that looks like it should come off does! If you look closely you will see an arrow to the left of the gray panel. You can push right and pull toward you at the same time and the panel comes off where you can easily take out the stuck photo paper.
Nov 06, 2008 | HP PSC 1350 All-In-One Thermal Printer
Paper feed problems hp PSC 1510
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Oct 17, 2008 | HP PSC 1510 All-In-One InkJet Printer
HP PSC 1610 All-in-One paper jam
ur printer paper feeder gears r jammed or misaligned. kindly get ur printer serviced from a good technician.dont worry its a normal problem.wish u success
Mar 11, 2008 | HP PSC 1610 All-in-One Printer, Scanner,...
HP PSC 1315 All-In-One InkJet Printer Logo
42 people viewed this question
Seeker5211
Seeker5211
