Receiving picture in gost sections.green,red, problem comes and go's.my modle is mitsubishi ws65819
    Genius:
  • 1,199 Answers
Sounds like a bad capaciter!
Posted on Dec 10, 2008
Mitsubishi ws65819 rear projection tv looses green color after 2-3 minutes
Check all the voltages at the other pins to its crt base socket. Check the video output transistor's solder terminal. Check the voltage that comes to green drive transistors' base. Refer its circuit diagram for more details. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
May 07, 2014 | Televison & Video
Check the CRT base card to green CRT for any loose solder terminals. Re-solder all the suspected solder terminals by applying a little more solder to each terminals. Check the solder terminals of the CRT base connection socket too. The fault is with some loose solder terminal itself at the green video output stage circuit. Gopakumar Gopalan Google
I have a Mitsubishi vs-4543 tv that when powered
check the power supply section.. probably the electronic component got problem.
Jun 04, 2009 | Mitsubishi VS-4544 45" TV
Mitsubishi WT-42413 Blue Green and Red Line
there is a section in the tv working just to keep the screen fitting top to down (vertical section) some capacitors are dry now in that area. this one has not to be a expensive job in the workshop. Try estimates
Apr 14, 2009 | Mitsubishi WT-42413 42" Rear Projection...
VS-4543 Mitsubishi 45" TV
Replace red convergence IC,both IC's for solid fix
Jan 12, 2008 | Mitsubishi VS-4543 45" TV
Red convergence wont move
if the red line is blurry and you have adjusted the screen focus control and does not work then you prob have a bad red CRT or bad red CRT fluid.........
convergence STK have nothing to do with the red being blurry
Dec 09, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Is this a calibration, convergence, or lens focusing issue?
Did you Change out the Ground Resistors,220 Ohm,3.3Ohm Even if they look Good Change Them
Jul 20, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
