Question about Printronix Line Matrix P5210 Printer
Paper stuck in hp2600n. half torn off other cant see it to remove
Padmon@eircom.net
Printer paper stuck and red light flashing .how can i restart it?
You can't restart until the jammed paper has been removed. If the paper is out and none torn or still stuck in the printer try turning the printer off and then back on. That should reset it.
Oct 17, 2017 | Light Office Equipment & Supplies
CASH REGISTER ONLY PRINTING HALF SIDE OF INFORMATION. WHAT IS THE SOLUTION? HAVE CHANGED NEW ROLL, BATTERY, ETC. THANX. PCR-T275
Might need a new printhead or its not pressing evenly on the platten so its not making full contact across paper. You could also possibly have a torn piece of paper stuck down in the printer. Most likely the printhead is bad
Jan 08, 2011 | Casio Parts Cash Register PC Desktop
My printer is only printing half the picture, one half comes out great and the other half has nothing
  1. Remove the power cable from the printer.
  2. Remove the paper tray from the printer.
  3. Remove the paper from the paper tray.
  4. Verify that the paper you're using has KODAK XTRALIFE Paper
  5. Insert the paper tray into the printer.
  6. Open the color cartridge door, then remove the color cartridge.
  7. If the color cartridge ribbon is torn or damaged, replace it with a new cartridge.
  8. Install the color cartridge, and verify that it is fully engaged.
  9. Close the color cartridge door.
  10. Connect the power cable to the printer.
  11. Wait for the printer to initialize (the paper may eject automatically).
    NOTE: For the Photo Printer 500 and the G600 or G610 Printer Docks only, press the power button in addition to plugging in the power cable.
The printer's lights turn on. And after a few seconds, most or all of the printer's lights turn off. The printer will make noises while cycling. If a paper is stuck in the printer, while the printer is making the noises, pull gently on the paper to try and remove it.
If the problem persists cal 1800 2356325 > for a repair
Oct 26, 2009 | Kodak EASYSHARE CD33 & Printer Dock Series...
Paper jam I tried to print some labels and the label paper is stuck in printer
1.When ever you place papers in the paper tray use fine papers which are not having any folds.
2.Keeps the papers correctly in the tray.
To Remove the stuck paper press the "START" button and hold it for some time. The torn paper will come out automatically. If the paper has not come out completely give the printer for service and get the paper removed completely.
Aug 31, 2009 | Office Equipment & Supplies
Paper jam
Try taking out the toner cartridge and seeing if you see any more bits of paper. Also open up the back panel and see if you see anything there.
Jun 12, 2009 | HP LaserJet 4250n Printer
Paper tears when printing
Helllo sir; I would say 99 % you have paper chip stuck in the paper path , ckeck the fusing unit,
Apr 14, 2009 | HP Color LaserJet 2600n Printer
Ink casette error
If you just put new cartridges in the printer, check to make sure you removed all of the protective plastic wrap that may be required to remove prior to printing.
Also, check the cartridges by removing and replacing each one. make sure there is no obstruction, or torn papers, that may cause a jam or other problems.
Also, after verifying all that. Use the printer utilities to run a test. Hopefully that should fix or clarify if there is any other problem.
Hope that helps..
~enov8
Mar 07, 2009 | Canon SELPHY CP760 PHOTO Thermal PRINTER
Epson Stylus CX8400 Paper Jam Error
I have the same exact problem of paper half torn removed but I can not see the other half anywhere. The printer has hardly worked for at the most six pages and now showing paper jam error. How do I fix it?
Dec 22, 2007 | Epson Stylus Photo R1800 InkJet Printer
Paper jam in 1120 hp printer
Hi there, Try printing again using heavier paper. Board types will likely push the torn papers out. Hope this solves your problem.
Sep 17, 2007 | HP DeskJet 1120cse InkJet Printer
Paper-stuck errors
1. turn printer off and back on, maybe it can solve problem itself. if it gives you a specific error code, check manual for its meaning. 2. turn printer off 3. remove paper trays, check for any wrinkled or torn papers in there. 4. open all entrances to achieve reaching ways for all parts. 5. if needed, remove tuner. put it in a sealed bad to prevent damage. 6. if you see a stuck piece of paper, pull it strong, with both hands. your goal is to keep it from tearing to pieces. 7. if it gets torn, spin the wheels manually to release it, do not use force. 8. return the tuner, close all entrances. 9. if it happens again, dismantle it again and follow the paper route.
Feb 22, 2006 | Citizen Impact PR Matrix Printer
Printronix Line Matrix P5210 Printer Logo
27 people viewed this question
Top Printronix Office Equipment & Supplies Experts
Chinmay Joshi
Chinmay Joshi
Cliff
Are you a Printronix Office Equipment and Supply Expert? Answer questions, earn points and help others
