SOURCE: ipod keeps disconnecting
what it can sync but you cant select songs manually? if that is so check if utoo sync is on. if using the new itunes 7.1 u will see it in the display of the ipod
SOURCE: Canon PowerShot S45 Digital Camera
Maybe this fuse is blown:
http://www.hit-karlsruhe.de/aol2mime/images/S45_S50_PowerFuse.jpg
Short it or replace it.
See also http://www.hit-karlsruhe.de/aol2mime/canon_powershot.htm
SOURCE: Camera will not turn on...charged battery but the charge light blinks instead of staying solid
If battries still blinking , chances are that the battries are buggred...try new battries after fully charging...this is cheaper option to try before trying to open the camera..
SOURCE: K850i charging problems and red light flashing at on/off key
Your battery is either not charged or the battery cell is completely gone.
I'll advice that you get another battery and give it a trial, also look out for the charging port. Check if it is not rust in any way because, if the charging port is rust, it will be difficult for the charger to contact the charging port.
I believe what's wrong with your phone is a minor fault, just do a thorough check and you will find a solution to the problem.
Best wishes.
1. Connect Navman
GPS to PC via mini-USB cable.
2. Go to
'Start'
3. Go to
'My Computer'
4. Open the
Navman Unit
5. Open the
'Navman' folder
6. Open the
'Database' folder
7. Delete the
following file only - 'dababase.db'
8. Close the folders
9. Disconnect the
mini-USB cable then restart the Navman GPS by sliding the switch to
'Restart' then back to 'On' after 10 seconds.
The database.db file will be generated automatically once the folder is closed.
