Question about VisionTek RADEON X1300 , Graphic Card
Need to connect 2 displays to Vision Tek RADEON X1300256 card
A VTX1300256SFF was purchased so that a user could use dual monitors. However, there is no Y-cable type dongle included to split the DVI connector. Is there one available to buy? If not, how do I split the output from the card to two monitors?
Thanks
    Scholar:
  • 86 Answers
You probably should have gotten a card that had Dual DVI because it will be two separate outputs instead of one... I would take it back and get the correct Graphics Card.
Posted on Dec 11, 2008
I have a compaq presario pc. Motherboard is Asus P5LP-LE : Lithium UL8E. I have 3 Gig of RAM installed, a 400w PSU. I have just purchased a new graphics card - Radeon HD5570. My MoBo has 1 PCI-E x16 and 3...
I think you have not connected power connector to your Radeon HD5570 .
This graphics card have 6pin power connector .
You need a 6pin power connector cable that comes with the graphics card box.
1.First connect your 6pin power connector to Graphics card.
2. Then connect other part of the cable to PSU.
Hope it will work for you.
Thanks for using FixYa.
May 14, 2011 | Computers & Internet
Need to connect 3 monitors. Want to use either a Nvidia 290 or ATI Radeon 9250 plus the VGA port. Installing the dual-video card disables the VGA port, cannot get it back. Help!!!
Use your AGP dual-video card for two and using a PCI VGA card for the third. It is best if the same manufacturer video driver is used for both cards, as two different ones could be problematic.
Jun 25, 2010 | HP Compaq Business dc7600 PC Desktop
I have a vision tek radeon x1300 xge 8x/4x graphic card that was working fine the last time i used my computer. now when i turn on computer i get a message saying no signal on monitor and then screen goes...
Hi there. Try connecting it to a diffrent monitor to see if the same thing happens. If it does, open the case, take out the card, and then put it back in. Now turn it on and try again.
Let me know how it goes.
Tim
Apr 17, 2009 | VisionTek RADEON X1300, (512 MB) AGP...
Graphic card problem
You MUST disable the onboard video in the BIOS and enable the other Card (AGP or PCIE) as the primary display this is also done in the BIOS
Apr 13, 2009 | Dell Inspiron 530 Desktop Computer
I purchased recently at best buy a visiontek radeon hd 2400 pro hd graphics card. when i opened the box the card inside was a visiontek 2600 pro card. when i attempted to return the product i was refused...
You have every right to return that item at bestbuy.  Unless you have damaged it or too much time has passed since you purchased it.  Demand to see a manager. Don't leave until they sort it out.
Apr 02, 2009 | ATI RADEON HD 2400 PRO Graphic Card
System does not see new video card
Confirm the card works in another system to eliminate it as a suspect. Try a beefier power supply in the machine (sometimes these 300 to 350 watt supplies just cant hang when an addon card is installed). Check the BIOS settings and make sure that the PCI Express slot resources are active for the card. If the card uses a power connector, make sure it is connected. Keep us posted.
Mar 21, 2009 | Gateway GM4019E PC Desktop
Duel Monitor Problem
first thing first ensure that you have the latest ATI radeon X1600 pro driver and software installed else you won't be able to get the desired options for dual display under settings coz it will be working with generic drivers.
To download the latest driver and software click here
Then please click the following link :
ATI Radeon X1600 PRO How to
On this link click on the option
  • "Guides, Walkthroughs and "How to's"
Then opt for
  • "How do I use dual displays or TV/HDTV out? "
Just follow the instructions.
Feb 19, 2009 | ATI RADEON X1650 Pro, (512 MB) PCI...
Radeon R9600/XT GRAPHICS CARD
Yes, they both will act independently if you choose to use it that way or they will show the same picture, one is a DVI output and the other is VGA. Use the ATI’s CATALYST software suite provides the ultimate software required to enjoy the full acceleration of your ATI Graphics Accelerator card. You can use it to separate your Primary video from your Secondary video.
Jan 03, 2009 | Abit R9600XT-VIO RADEON 9600 XT, (256 Mb)...
Added a new video card, now my monitor stays in sleep mode
If the computer originally had integrated video, have you tried reconnecting the monitor to that output? Most system boards will automatically detect when you install a separate video card, but on some you need to disable the built-in video in the BIOS before the new card will work. Also, have you considered the chance you just got a lemon of a new card? It happens sometimes (it's happened to me!).
Nov 18, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Dual monitors
You'll need a dual-monitor video card in your computer. The GVLM1928 is basically two monitors on a shared stand. Each side of the monitor has a separate video connection.
Feb 26, 2008 | Computers & Internet
VisionTek RADEON X1300 , Graphic Card Logo
96 people viewed this question
Top VisionTek Computers & Internet Experts
rafnix
rafnix
Computer Links
J John
Are you a VisionTek Computer and Internet Expert? Answer questions, earn points and help others
