Question about Pioneer Televison & Video
Pioneer Pro1150HD Plasma TV will not power up. The red power led blinks 8 times and repeats sequence until unplugged. Uppon plugging in after a 2 minute period, red lid is on steady but when pressing the power on button on button, the blue led lights up momentarily and the plazma panel lights to black level and then the plazma shuts down and the red power blinks out the sequence of 8 blinks and repeats the sequence until the plaza is unplugged.
2 Suggested Answers
ginko
  • 19396 Answers
SOURCE: KDF70XBR950 red power light belinks 6 times repeatedly
Hi.
You have a power board error, and TV is in protect mode. This had been caused by the power surges.
Try leaving the TV disconnected from power (unplug cord) for several hours, or overnight.
This will allow PSU capacitors full discharge and can fix PSU fault after power surge. If it does not correct the problem , then there is a faulty component.
In that case the TV must be tested and repaired by a technician.
Regards.
Posted on Oct 21, 2009
Testimonial: "Unplugging overnight did not work. But thanks for the suggestion. Looks like thisis going to be a service call."
I have a pioneer PRO110-FD plasma tv with a 2 blink error code. What does the 2 blink error message mean
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Jan 04, 2015 | Pioneer PRO-110FD 50 in. HDTV Plasma TV
Find activation code for pioneer
My pioneer 5020FD Kuro tv. when I plug power to the unit, a blue light blinks 8 times pause 2 sec. and blink 8 times repeating this and if i press power button it clicks red light and makes a clicking sound and goes back to the blue light blinking again, it did this once before and the picture came on fine until i turned it off and now it just blink the blue code.
Dec 10, 2014 | Pioneer PDP-5020FD 50 in. Plasma HDTV
How to perform factory reset procedure pro1150hd
Factory Reset Procedure
1 With TV off/in standby....press home menu.
2 Within 3 sec turn TV on , Integrated Menu will appear.
3 Hold Display button until Final Setup appears in the top menu.
4 Arrow leftor right until yes appears in lower menu.
5 Hold enter until menu disappears.
6 Wait 1 min.
7 Power TV off and unplug from the wall for 5 or more min.
You can also try this:
Home Menu, select Picture, select "Reset", then ENTER, then select "Yes" and press ENTER.
May 09, 2014 | Televison & Video
Power Surge
charlie the proble has something to do with the tv guide here is a response from an older post Un plug the power to the Plasma Screen and also to the Media Receiver for ten minutes. Disconnect the off the air antennas both A and B. After ten minutes plug in the plasma screen then the media receiver and turn on wi the remote control. You should now be back in operation. I was. Also It may not be a bad digital tuner. The TV Guide feature is active even when the zip code is set to all 0s so if you have an over the air antenna attached the TV will look for the TV Guide info and if it can not find it because of a weak signal or the chanel it is tuned to does not carry that information the TV thinks that tuner does not work which triggers the 12 flashes. Also on power up the gray box with the waring message "Plasma Display Starting Up, Please Wait" appears and the screen is blank.
Aug 05, 2012 | Pioneer PDP-6010FD 60 in. Plasma HDTV
I have to unplug wait for the power light to stop flashing red multiple times before it will come on
When the TV does this, the RED LED on the front will blink. For digits 1-10 it will blink pause then repeat. For numbers with 2 digits it will blink the first digit slow and then second digit fast. So 25 would be 2 slow blinks followed by 5 fast blinks.
Error Description Error/Prot Detected by Device Defective module Result
1 I2C1
2 I2C2
3 I2C3
4 I2C4
5 VIPER
6 5V supply
7 8V6 supply
8 1.2V DC/DC
11 3.3V DC/DC
12 12V supply
14 Supply Class D amplifiers
14 Supply Audio part SSB
17 MPIF1 audio supply
18 MPIF1 ref freq
25 Supply fault
27 Phoenix
28 MOP
29 AVIP1
31 AVIP2
32 MPIF1
34 Tuner1
37 Channel decoder
39 POD Interface
43 Hi Rate Front End
44 Main NVM
45 Columbus
53 VIPER
63 PDP Display
Dec 06, 2009 | Philips 50PF7320A 50 in. Plasma HDTV
PIONEER PDP-R06U / PRO-R06U MEDIA RECEIVER SERVICE
Hey,
This may be too late...
I got it from the field manual.
Trap Switch Reset Procedure
G-4, G-5, G-6, G-7, G-8
• Replace media receiver, plasma panel cover, or tape down HDCP trap switch.
If the model in question has the TV Guide option, the TV Guide
option must be turned off before proceeding.
• Using the customer’s remote control enter “service mode” by pressing the
following key sequence:
1. Press the “display” button then release the “display” button.
2. Wait between 3 and 7 seconds
3. Press and release the “<”, “^”, “<”, “>”, and “power” buttons in sequence.
• Panel will now turn on in “service mode”.
4. Press “muting” button 3, 4 or 5 times depending on model you are working on.
Until the display shows the “initialize” page.
5. Press and hold the “display” button until the error indicator (red LED) on
either the panel or the media receiver goes out.
6. Exit service mode by pressing the “power” button on the remote.
I had to try it a couple of times before I got it to work. I.m not too sure how to turn off the tv guide mode. I just held it in for a couple of sec,s.
Good luck
Dec 05, 2009 | Pioneer Audio Players & Recorders
TV will not power up. red LED blinking 5 times
I always found the problem to be either a combo of the x-sus printed circuit board and the y-sus printed circuit board. It is also very worth checking out your poer supply circuitry as well. Good Luck.
Aug 27, 2009 | Pioneer PureVision Pro-1000HD 50 in....
5071HD switch, power supply problem??
Pioneer recommended a firmware upgrade for the repeating twelve blue led blinking and remote issue you specifed.
Feb 29, 2008 | Pioneer PDP-5071HD 50 in. Plasma HDTV
Televison & Video Logo
63 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
