Question about Nokia 1100
Antenna Disconnected My husband's LG AX355's antenna has come loose. It can be totally removed now from the phone.
  • prayinghands May 11, 2010
    It's not a Nokia 1100. It's an LG AX355. Sorry about that!
    Brigadier General:
  • 7,752 Answers
Take the phone to a mobile service center and have them fix it for you...
Posted on Dec 27, 2008
Poor signal with lg vx8500
LG VX8500 Signal Boosters and Antennas. Keep your cell phone signal strong with these LG VX8500 Antennas for use in your car, office, home, or boat. Get even more from your LG VX8500 cell phone with an external antenna and 3 Watt Signal Booster. Don't get stuck without cell service at a time when you really need it. Add an antenna and booster compatible with your LG VX8500 cell phone.
Nov 26, 2013 | LG VX8550 Cellular Phone
Hi. This Sansui 40 inch was working fine with an antenna. The Boy hooked up his playstation 3 and now it doesn't get any channels. Checked all the connections, disconnected the PS3, Tried doing th
You likely need to add an antenna amplifier. The PS3 should have been hooked up to one of the other source inputs other than the antenna. If it was attached via the antenna, a solder connection may have come loose or the coax got kinked.
Feb 20, 2012 | Radio Communications
My Garmin Quest has stopped working. It is trying to acquire satellites and also 'drawing' appears on the screen. I have re-booted the unit and it still does not work. Any ideas?
If the screen is otherwise "normal" and it is just not able to acquire satellites, I am guessing you have a problem with the antenna. One way to determine that is if you got an external "patch" antenna, plugged it in and it started working as it should, that is definitely an antenna issue. I have run into several of the "flip up" antennas recently that have exhibited this problem. What happens is, the connector from the antenna breaks loose from the solder joint inside the antenna. If you have a small soldering iron, you can CAREFULLY pry the antenna case apart to access the connector and it is a simple matter to solder it back in place. You will need a very small screwdriver to pry the two outer sections of the antenna case apart. Wedge the screwdriver blade in between the two sections of the antenna covering. Pry the larger part (the part that would face the sky with the antenna at 90 degrees), and with CARE you can get it apart. The small gold connector solders to some circuit traces on the antenna board. To get the antenna off the GPS, place the GPS face down with the hinge part of the antenna away from you. With a small jewelers screwdriver, remove the right two screws on the back of the GPS on the right end. There is a small plastic retaining piece that holds the antenna in place. CAREFULLY lift it up and off the GPS. Be VERY CAREFUL at this point because there is a small spring loaded plastic piece that fits against the retainer piece you just removed. It is very easy to lose the spring and plastic piece if you are not careful. Gently pull the antenna to your right, away from the GPS. The antenna should pop out. If the connector has completely disconnected from the antenna circuit board, you may need some small pliers to get it off the GPS side of the antenna connection. Once you have the antenna removed, separate the antenna case as I described and resolder the connector back on the board.
Oct 16, 2010 | Garmin Quest GPS Receiver
Losse antena
Did you purchase this unit new? If not, someone may have taken the unit apart and lost a small spring out of the antenna assembly. If you place the unit, display side down, with the antenna hinge away from you, there are two small phillips head screws on the right side. If you remove these screws, a small plastic endcap for the antenna assembly will come loose and the antenna can be removed. Where the endcap and the antenna are hinged together, there should be a small spring that puts tension on the antenna. If the spring is missing, the antenna will not remain in position.
Oct 04, 2009 | Garmin Quest GPS Receiver
Lg vx8350 Using external antenna port. Phone now refuses to switch back to internal antenna when external antenna is unplugged. No signal now without external antenna. Plug external antenna back in, full...
The Wilson adapter damaged your internal antenna. I talked to Wilson today to get a part number to buy the adapter and the told me they did not recommend using it as it has damaged a number of phones. They also said that LG might have corrected the problem in the newest production models.
Oct 13, 2008 | Lands Phones
Lg chocolate
uh.....does it even have an antenna? I have a chocolate lg, and I had no idea it had an antenna! .....where?
Jun 10, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Cell antenna for LG CU500
There is a small round rubber plug on the back of the phone above the battery, below and to the left of the camera lens that I believe is an antenna jack.
May 28, 2008 | LG CU500 Cellular Phone
Lg ax355 cell phone not receiving incoming calls
Have you tried rebooting the phone as I experienced a similar issue
Oct 20, 2007 | Nokia 1100
Replacement Antenna for LG VX5300
well.. few old mobile phone antenna was easy to remover i remmber old day when my father use to own Erricson moble phone you can can the antenna and plug it out simply up wards but new phone i heard that we must unscrew them to replace the problem . better get it to the repair guy . i am sure he won't charge you much for this
Sep 03, 2007 | LG VX5300 Cellular Phone
Nokia 1100 Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
