Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Older Ceramatop GM Frigidaire oven stopped working-stovetop works
Hello there! I have an older model Ceramatop GM Frigidaire electric oven (maybe 8+ yrs). I don't see a model/serial # anywhere (the oven is against the wall and between two counters). It has older turn-knob controls, stovetop works, inside oven light works, but the oven no longer works. The outside oven-on indicator light does not turn on when trying to turn the oven on, and the oven does not get hot. The very last time I used it before it totally stopped working, it did get warm (where I could touch the cookware without getting burnt), but not hot and the outside oven light indicating it was on was working. Now they both do not work. Any ideas? Something simple and replaceable? We;re on an extremely tight budget, so if it's possible to fix easily, we're definitely into doing that! Thanks for being a blessing!
  • Frigidaire Master
  • 3,463 Answers
If it has a timer of any description, make sure it is set to manual, refer to your instruction book.
Posted on Dec 12, 2008
Why has our oven stopped working whilst cooking - nothing electrical seems to be working?
Did you check your electrical breakers? Maybe it tripped. Reset it by first switching it fully to the off position, then switch it to on.
Feb 29, 2016 | Ovens
Moved Kenmore electric oven (2 yrs old) and now neither the oven or stovetop heat up. The clock is set.
This may sound silly, but go check your circuit breaker and flip it completely off and then back on. Sometimes it does not completely trip and your clock only needs 120 volts to work which you have, but the heating coils need 240 volts. If you have an older house that has a fuse panel instead of circuit breakers you could have a blown fuse.
Feb 12, 2014 | Kenmore Ovens
Frigidaire oven wont heat up but stovetop and digital all works
Hello angeleyez82 - The EOC (electronic oven control/control board) basically sends power to both the broil and bake elements. As long as the power supply to the range (240VAC) and wiring between the elements is correct, then typically only the element(s) or EOC could prevent the unit from heating. I hope this information helps to some degree.
Jun 25, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Older Frigidaire electyri-clean range Model REG 533 * HD
I wish I had a solution for you...unfortunately I don't. However, if you know anywhere I might find a thermostat knob for this model I would be eternally grateful. I've been searching for 2 years for my mother. It's the knob with 5 settings (off, bake, broil, time-bake and clean).
Jun 08, 2010 | Frigidaire Ovens
My Oven and broiler won't heat but stovetop burners work
I have a Frigidaire Model Number GLGF377ASF. The stovetop burners work just fine but the oven and broiler do not work.
Dec 08, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
MAJIC CHEF DOUBLE OVEN NOT WORKING
I just had a model 976-4CX put in...I have no manual...I'm trying to find one. I thought I had a problem with the element, dial or thermostat. The bottom worked, but the top stopped working. There are 2 timers with dials next to the clock labeled Start and Stop, and Push for Manual. Come to find out my problem was solved by adjusting the Start and Stop dials and/or pushing in for manual!?!
If I had a manual I'd know how these timers worked.
Nov 29, 2008 | Magic Chef 9522 Electric Double Oven
Frigidaire non-digital (old) Caprice top electric oven not working
Check the clock knobs the older style you had to push in to auto time them make sure the times are on the same time (stop&start) and the buttons are popped out to engage the upper oven if so post the complete Model # and i will get the manual for you
Jan 21, 2008 | Frigidaire 27 in. Electric Double...
Oven electric
i have a frigidaire elite convection oven,older, the elements work but the convection oven will not turn on - what should i check?
Jan 13, 2008 | Frigidaire FEB27S5A Electric Single Oven
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
343 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
