Question about Linksys Wireless-G Broadband Router
Unable to access set up page for router
I am unable to access set up page for my linksys router. I followed the directions but it doesn't let me on the page. It comes up unauthorized.
  • 52 Answers
May be the password are changed try to reset it, but be careful this will remove all the settings, otherwise you have to contact the one how programmed it for the first time.
to reset push the bottom for more than 8 seconds until the power led blinks.
Posted on Dec 10, 2008
Linksys sd208 reset
The reset button is usually at the back of the router. If you are unable to locate it you can reset it using a web based set-up page. Make sure you connect your router to a PC using wired connection and perform the following steps:
Step 1:
Launch a web browser like Internet Explorer.
Step 2:
In the Address bar, enter "192.168.1.1" as the router's default IP address then press [Enter]. If this doesn't work or if the IP address of your router has been changed, enter it instead.
Step 3:
Enter "admin" in the Password field then leave the User name blank. If you have set up a User name and Password for your Linksys router before, enter your personalized credentials instead.
QUICK TIP: For Linksys Smart Wi-Fi Routers, you can enter "http://myrouter.local" on the Address bar to access its web-based setup page.
The router's web-based setup page should now appear from here you can reset the router.
for more info browse this link: http://kb.linksys.com/Linksys/ukp.aspx?pid=80&vw=1&articleid=3676
Sep 19, 2013 | Computers & Internet
I have perfect internet access but my wii wont let me play my netflix movies. it says unable to find an access point my signal strengh is perfect.error code 51030 i would really like to speak to someone...
Hi There,
Playing a movie over a wifi network not only stresses your router, it's choppy and useless if you've got anything less than a wireless N 300mb/s connection.
However, I looked up your error code and Nintendo seems to think that your router needs to be power cycled, and if that doesn't work, delete your connection settings from your wii and create a new one.
If that doesn't help, I'd recommend upgrading to a linksys N router or using a good old fashioned 10/100mbit cable :)
May 11, 2011 | Computers & Internet
Unable to connect to the internet with my linksys wrt120n router through my at&T modem. The AT&T router works fine by itself. But will not communicate with the Linksys router
If you connect the computer directly to the AT&T modem , it work. That means the modem is working properly.
AT&T is DSL connection type. the DSL connection works on 2 different modes. 1) DHCP 2) PPPOE.
Now you will need to connect the modem and the computer to the router. open the set up page of the rotuer.
The set up page is the page where you can change the settings of the router.
According to the type of internet connection you can change the settings of the router
Click Here for step by step by instructions
Feb 16, 2010 | Linksys WRT120N Router
Unable to write network settings to device - windows cannot save your network settings to the selected device? Not sure what we have done wrong
Which network settings are you trying to write? In general, try getting Network Magic. It's a free download and trial and can help with some Linksys/Cisco problems.
Also, you may try getting into the firmware itself. Use any web browser and enter the following IP address as your URL: 192.168.1.1. At that point you're directly accessing the settings on the router and should be able to make any changes you need. By the way, this only works if you're connected directly to the router via Ethernet cable.
Oct 04, 2009 | Linksys WRT54G2 Wireless Router
Unable to connect wireless
Since you are unable to go via wireless, follow these steps:
1) Access your router configuration pages by typing in 192.168.1.1 into your web browser.
2) Click the tab that says Wireless.
3) Make sure the wireless broadcast option is enabled. If it isn't, enable it and select save settings.
4) Set up the wireless network through your Vista PC by going to Start > Network.
5) At the top of the window, select add a wireless device. Follow the onscreen instructions to add your Linksys Wireless Access Point.
6) Once added, right click on Wireless-G Router (name varies) and select configure. Follow the onscreen instructions to configure your router. (You can find your router pin by following steps 1-2 and selecting Wi-Fi Protected Set up.)
7) Once completed, attempt to connect to the internet via wireless router.
Dec 15, 2008 | Linksys Wireless-G Broadband Router
WRT54G, unable to install router
  • Since you have Internet connectivity through the router using a direct connection to the router, then you just need to access the router's setup page and re-configure wireless.
  • But first, check if the wireless light is on in the router.
  • Then, using a computer that is wired to the router, launch IE and type 192.168.1.1 on the address field.
  • It will then ask for the password. By default it is admin. Just click ok and it will lead you to the setup page of the router.
  • Then, on the menu click Wireless. Look for wireless network name or SSID. That is the name of your wireless network. By default it is set to "linksys". You may change it to a uniqune name and then save the settings.
  • Then, if you want to enable security in your Wireless network, click on Wireless Security.
  • Set security mode to WPA Personal and create your network key. It should be atleast 8 characters.
Hope this helps!
Dec 03, 2008 | Computers & Internet
Re-installing my linksys
Before you can use your linksys router again, you must configure first your AT&T modem under bridge mode. If the AT&T modem is already set to you may connect the devices (modem router and PC) must be switched OFF first.
after the devices had been connected,...
1) turn ON the AT&T modem first, wait for the DSL light to stay solid
2) turn ON linksys router,wait for the lights to stay solid
3) turn ON computer,wait for your desktop screen
4) try to access Internet Explorer
Nov 13, 2008 | Linksys Wireless-G WRT54GS Router...
Linksys wireless-G router
Try first to reset the router by pressing the reset button for 20 seconds then after that try to access the 192.168.1.1 from the address bar using the computer that is wired directly to the router , if still wont access the page after the reset power off the router for 10 seconds then try it again....if still the same better contact linksys using this number so they can walk you through with the process the number is 800-3267114.....
Oct 31, 2008 | Linksys Wireless-G Broadband Router
Remote pc cannot access wireless
You can do a reset on your router. All computers must be must be getting its connection from your router. Your wired computer must be getting an ip address from the router(example is 192.168.1.x). You can then access the router page using your browser by typing the default gateway(example 192.168.x.1). This will take you to the router configuration page. You can set up the wireless network and your wireless network can now support more than 2 wireless computers.
Mar 14, 2008 | Computers & Internet
Linksys Wireless-G Broadband Router Logo
37 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
