Question about Beko 24 in. D3421F Free-standing Dishwasher
My Beko D3422FW is stopping mid-cycle
It does begin to wash but then sticks in one certain spot. I have to move the clock on to the end but it then has missed out some of the cycle.
  • carriej168 Jan 09, 2009
    i have a Beko D3442FC and it is stopping mid-cycle. Is this expensive to fix ?
SOURCE: beko washing machine wma1512w
When i turn it on, it doesn't start turning
Posted on Jun 18, 2008
  • 82 Answers
SOURCE: I need to Know how
Hello antheafrankl, I am not familiar with this model of dishwasher, but did you try unplugging it for 10 seconds? On some models one can press and hold the on/off switch, press and hold the program select button. or somtimes there is a combination of buttons that need to be pushed at the same time which I wouldn't be familiar with in this model. By the way what is it doing that you think it needs to be reset?
Posted on Dec 01, 2008
  • 26 Answers
SOURCE: How do i re-set my dishwasher
If by reset you mean cancel the programme, then you need to press and hold the start/pause button for about 10 seconds until the drain pump starts to run.
This will continue for about 2 minutes.When it stops, turn off the appliance. When you turn on again all should be well
Posted on Dec 03, 2008
SOURCE: BEKO D3422FW Dishwaser stays on the pump out cycle.
I can confirm Solution #2.
This usually happens whe you have a blockage in the waste pipe. For some reason, once you've cleared the blockage, the dishwasher doesn't detect that water has now passed through the system, even if you send through more water via filling the base (I did this about 4 times totalling 24litres of water and it still didn't reset).
Tilt the dishwasher back (I only had to tilt it about 30 degrees), this resets whatever switch it is that turns the pump off and allows it to fill with water.
Posted on May 06, 2009
  • 3247 Answers
SOURCE: beko 4310 stopped mid wash
I am assuming it is a beko dwd4310 dishwasher.
If the display has totally blanked off then the control board has packed up.
You can find the part at this site.
Posted on Nov 07, 2010
Beko WMB714422 .... washing cycle stops after 5 mins of the cycle and shows 'end'. Cant get it to do a full cycle. Any ideas ?
This is most likely an issue with the motor, causing confusion to the electronics, sometimes you can replace the motor and remedy the issue but I have had a couple of occasions with Beko machines where the motor fault caused damage to the control board
Jun 12, 2016 | Beko Washing Machines
Forty cycle takes some water in then stops
Beko WM5100W Washing machine wash/spin problem ...
? 3:59
https://www.youtube.com/watch?v=rih6H1cpu9Q
Jun 12, 2012 - Uploaded by ilona ilona
problem in washing cycle. fast spin for few seconds and cut off .... I have same machine, it starts up fills half way with water then stops :'.
Washing machine stops mid cycle - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jan 10, 2016 | Beko Wm & Wma Models Washing Machine Motor...
Doesn't work. Why does it stop mid-cycle?
washing machine stopped mid cycle, won't drain : DIY - Reddit
https://www.reddit.com/.../washing_machine_stopped_mid_cycle_...
RedditSep 3, 2014 - helpwashing machine stopped mid cycle, won't drain (self.DIY). submitted 1 ... I get home. Any ideas on how I can just drain the water out of it?
Troubleshoot - washer stops mid cycle, won't drain or spin ...
? 1:58
https://www.youtube.com/watch?v=6Gc0ZgLD6a4
Jun 20, 2012 - Uploaded by searspartsdirect
Troubleshoot - washer stops mid cycle, won't drain or spin .... I agree, this was not helpful, and did not address the no spin issue. like thanks. ... how to fix a Kenmore / whirlpool washing machine that wont drain agitate or spin ...
Sep 9, 2013 - Possible causes when washing machine stops mid cycle by a ... If thewashing machine can't drain the water out then it will stick on the rinses, ...
Why does my washer stop half way through cycle - Ken
Dec 18, 2015 | Washing Machines
My washing machine was switched off mid cycle. Now the start/pause, ready, wash & spin/end buttons are lit up. I have switched it on and off from the mains. No change. It is a beko wm6123w. Please help
Try looking in the troubleshooting section of the products user guide/instruction manual, if you have lost this, you can normally download a copy from the manufacturers (beko) website, this is normally located in the support section of the websites.
have you tried pressing the start/stop button as the cycle maybe simply paused.
WM6123 Washing Machines Beko
Jul 04, 2014 | Washing Machines
I can't open my washing machine please help
It locks during certain cycles. Try turning the selector switch to end of cycle and try opening. If it's stopped mid cycle, try unplugging it for a minute or two and plug it back in.
Nov 19, 2012 | Washing Machines
My beko washing machine is stuck on the end spin cycle and stops and starts a spin in short bursts.it has water in it and wont move on from this.
Hi jennyandeddy,
Most likely your washing machine is trying to drain, but cannot, and as such cannot start to spin.
Please follow my Tip below, for detailed directions on how to access, drain & clean your Drain Pump Filter (Please Note: Your Filter compartment is located at the Bottom Right):
DRAIN PUMP FILTER
Hope this helps :-)
JEDEMEYER1
* If you found this solution helpful, please rate it
Jul 13, 2011 | Washing Machines
Will not discharge water or go into spin cylcle.
I would have to guess you have a dead spot in the timer. If it stops moving, it would still tick like a clock but the internals of it are not catching to send it into discharge and spin.
Apr 03, 2009 | Washing Machines
Beko WMA 1715S
try unplugging and let it reset itself
Apr 03, 2008 | Washing Machines
Beko 24 in. D3421F Free-standing Dishwasher Logo
49 people viewed this question
Top Beko Dishwashers Experts
Shekar Avadhani
Eric Taylor
Are you a Beko Dishwasher Expert? Answer questions, earn points and help others
