Question about Protron PLTV-37 37 in. LCD Television
No picture When I turn on the TV, I get the blue screen with the NO SIGNAL sign then it goes black. No picture or sound.
  • Dustin Dauncey
    Dustin Dauncey May 11, 2010
    Is there a source of audio and video for the TV? Is it hooked up to the correct components? Is your TV input selected to your source feed? If it was working before, what has changed?
  • 60 Answers
Check the antena cable because there is no input signal , try to put other imput signal to see if work like DVD or other if yes then chech your cable or call your cable sender
Posted on Dec 10, 2008
How do I get Amazon Fire TV resolution set so I get more than a blue screen?
Select the input channel for your Fire TV - Turn on your TV and select the input channel for the HDMI port you used to connect your Fire TV. You should then see a loading screen with the Amazon Fire TV logo 4.
Jul 04, 2017 | TV Box Televison & Video
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
When I turn off my tv for an hour or more then turn it back on I get the blue hdmi signal then screen goes black but I can still hear sound but no picture. after turning off and on several times I finally...
Likely you have a heat related issue in the tuner. The picture cutting out is related to the tuner board over heating and signalling the power board to switch it off. The solution is to get better heat control on your TV. Try using a fan to see of this improves anything, and get a better ventilation to your tuner.
Jun 01, 2014 | Sanyo DP32648 32 in. LCD TV
After setup there is no picture just the sound plays
Tries unplug the tv and the cable box about an hour,replug both back in.The cable box,will upgraded it software and the tv will reset itself back to factory setting.Every things should work now.Not,than the tv Tuner board,it dead,that board,that take in the incommimg broscasting signal cable to the tv.
Aug 02, 2010 | Optoma PD50 50 in. HD-Ready Plasma...
47in Phillips-tv picture goes black still has
Could be the signal board has a bad cap, in this case it sounds like you are getting intermitten power to the inverters....when the tv goes down and of course you have audio....Shine a flashlight on to screen and see if you have a picture...look carefully. If this is the case..you have the above problem!
Nov 23, 2009 | Televison & Video
TV Screen goes black
all tv has built in tuner inside,search for variables for inner tuner.when the signal is not fix naturally it goes black and white or destorted/blurred.
Oct 17, 2008 | Akai Televison & Video
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
No picture but has sound
My LG TV
switch on no picture but short period of sound then nothing
Jan 20, 2008 | Sony KP-51HW40 51" Rear Projection...
Sanyo DS32920 Blue Screen
My panasonic Tv pic suddenly turned into a blue color I can't see the pic any more just can hear the audio.....any solutions????
Mar 19, 2006 | Sanyo DS32920 32" TV
Protron PLTV-37 37 in. LCD Television Logo
155 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
