Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Have picture but color overlaps and is not sharp or crisp.
Lamp has been replaced...board controlling picture viewing has been replaced (poped caps) now the color is bad...,looks blotchy...overlaps.
  • dikster Dec 15, 2008
    The power board was do you copy the light engine data to the chassis to sync the color wheel?
  • 179 Answers
Depending onwhat board you replace you may have to copy the light engine data to the chassis to sync the color wheel.
Posted on Dec 14, 2008
  • ken black Dec 15, 2008
    if the powe board was replaced that is not the problem. could you post a picture?
How do i fix a non responsive tv set?
Do the ballast first. That should get the picture back. The main board controls everything else.
Oct 08, 2016 | Televison & Video
I bot a used zeinth C32v-23-8 Hd tv and when I pluged it in it makes a poping sound and you can see a light flashing inside and has sound but no picture
Sounds like a High Voltage lead in the set is arcing--What I also remember from this set is there is a tiny blue cap (with back off and looking from rear) to the extreme right side of the main board that burns to a crisp.
That is fairly easy to fix.
Let me know what you find.
Apr 02, 2012 | Televison & Video
My Sony KP-65WS500 is flashing blue screen and horozontal lines and now has a black box about 1ft x 1ft box in screen. It will do this for about five to 30 seconds and then cuts off. I can see the picture...
Remove the front cover or the back. You need to look for the color gun it will look like a small box with 3 screws. Slightly turn the screws to adjust the color in your case in and out blue and arching lines.. Now the box sounds like a picture in picture function.. Would have to see it. Now it it cuts off power after 5-30 seconds after doing this you could have a bad capacitor on the power supply board which is sending the set into fault protection. A Bad cap with be poped at the top (X) -Top view of a cap should be flat. NOt rasied or poped.
Best Regards and Semper Fi
Aug 03, 2010 | Sony KP-65WS500 65" Rear Projection...
HCL4715W 47 in. Rear Projection Television: My tv has an overlapping picture and the colors ar...
You have a bad convergence board. Replace two of the STK 392-040 ICs. And check all the resistors that are next to these ICs. Rplace the resistors as neccessary. This will repair your TV. Thanks for asking...sorry it took so long to find you!
May 17, 2010 | Samsung HCL4715W 47" Rear Projection...
The colors seem to be overlapping the red is further off than the other two
Hi, you might be experimenting a color wheel problem.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.The other thing that it could be is the DMD board.This is how it works: Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Here's a video that will help you find where the DMd chip is located : Have a blessed one!
Mar 24, 2010 | Samsung HLN5065W 50" Rear Projection...
TV will not power on.
I guess your TV is DLP.
Please notice the follow symthoms:
When you on TV, did you hear some strange noise from the back of the TV. If yes, the color wheel needs replacing.
If no, check the lamp. Take a look to bottom of lamp, you will see white pot or sometime a pop up there due to lamp cycle is going to end. When changing lamp, check the ballast and power sup, too. If you see caps are poping up. Pull out those board and replace the poped caps.
Aug 13, 2009 | Televison & Video
Picture is curved and wording is overlaping on my Sony 65'' hd pro
convergece ic's are bad also check low value resistors on convergence board. not an easy repair. you need expert soldering experience.
Feb 25, 2009 | Televison & Video
Blue (actual) lamp out of focus. Picture is washed out and milky.
I found a local tv repair guy who sold me the the CRT fluid for $80 and I gave it a go. It wasn't easy, but it worked. If you are really interested I'll tell you how I did it.
Aug 11, 2007 | Philips Magnavox 9P6034C 60" Rear...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
131 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
