Question about Acer Aspire 5100 Notebook
No sound Its a 5920 Aspire but it isn't listed, so, this question posted here. Suddenly my speakers quit working. All common, obvious checks tried (mute, control area, etc etce) no luck. "Test" areas os Windows on the sounds produces tones but all other sounds are non existent. H E L P !
  • 395 Answers
The software for the laptop can be found on the acer web site at
ftp://ftp.work.acer-euro.com/notebook/aspire_5920/
Posted on Dec 10, 2008
Acer 5920 Sound Problems
You need to download and install the latest RealTek drivers for you laptop... Go to Acer site and get the correct version
http://us.acer.com/acer/service.do?LanguageISOCtxParam=en&miu10einu24.current.attN2B2F2EEF=3750&sp=page15e&ctx2.c2att1=25&miu10ekcond13.attN2B2F2EEF=3750&CountryISOCtxParam=US&ctx1g.c2att92=453&ctx1.att21k=1&CRC=2054404012
Feb 17, 2010 | Acer Aspire 5920-6335 Laptop
Aspire 5920 after capacitor fix, doesnt work from battery
I'm pleased to hear the this fix worked out for you. The 5920 is also prone to quite a few battery charging circuit issues. The most common of which is the inability to run off of the battery. You can power the machine, boot to windows, and check the batter power meter. It could read 100% and the second you unplug the AC adapter the unit immediatly turns off. This is due to a blown fuse in the circuit preventing battery power from reaching the system board. I have included the best picture I could find. Its a little small but i have circled the defective component. You should try to replace it. This may be difficult becuase you would want to replace it with the exact same fuse. For a short term fix you can simple bridge the connection once the fuse has been removed to allow power through. This will solve your problem but may be dangerous to use without a fuse in that location.2c490f1.jpg
Nov 08, 2009 | Acer Aspire 5920-6727 Notebook
Screen wont work. laptop powers up, fan turns on and lights are on. Yet there is no screen activity whatsoever. I have tried the fn esc technique also checked the backlight settings to no avail
Quite common for the cable to come loose between the motherboard/video card and the screen itself.
You would have to open it up to check the connections at either end i'm afraid.
Other causes could be the video card / driver.
Hope this is of help.
Iain
Oct 16, 2009 | Acer Aspire 5920-6727 Notebook
Acer Aspire 5920 will not boot at all...
The power button may not work, that is most common in laptops, or you have a short.
Aug 23, 2009 | Acer Aspire 5920-6727 Notebook
Problem in external speaker when connected to acer 5738Z LAPTOP
The audio jack on the laptop is for headphones and most likely cannot it cannot deliver sufficient power to drive unpowered speakers.
Check the audio jack with headphones, if the volume setting is high and you still can't get sounds from the headphone and the mute switch is not selected then the audio amp in the laptop is faulty.
Jul 07, 2009 | Acer Aspire 5920-6727 Notebook
Acer aspire 5920G will not turn on
It seem issue with the memory card, try reinstalling the memory card and then try booting.
Feb 27, 2009 | Acer Aspire 5920-6727 Notebook
Acer 5920 external speakers problem
Did you buy the speakers for computer using?
If not buy a USB audio output interface to drive the speakers.
Nov 18, 2008 | Acer Aspire 5920-6727 Notebook
Sound problem - Acer Aspire 5920
I assume you are using Windows Vista as ships with Aspire 5920's. Try the following to make sure that Windows is using the correct output options:
  1. Click on the Start Menu and go to Control Panel
  2. From Control Panel click on Hardware and Sound
  3. Click on the heading Sound and the sound configuration box will appear.
  4. The first tab is called Playback and allows you to select a playback device.  You should find your external speakers and internal speakers listed.
  5. Click the external speakers and then click on the "set default" button to make sure that the sound is played back through those instead of your internals.
Nov 06, 2008 | Computers & Internet
I have an acer aspire 5920 I have two problems - firstly the symbols on the keyboard seem to be mixed up - e.g. the @ appears when I hit the shift " button Secondly, when i'm typing text the...
this is quite common, right click on my computer>properties>hardware tab>device manager, then look down the list to KEYBOARD, click the '+' sign and the keyboard will be listed, right click, select uninstal.
Restart pc and your keyboard will reinstall and should work as normal.
Aug 18, 2008 | Acer Computers & Internet
Acer Aspire 5100 Notebook Logo
57 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
