Question about Logitech LX 700 9674180101
As though space bar held down continuously
Lx 700. Was working fine. Thought I'd move USB receiver to a different port so I could plug something else in. Win XP PC re-setup mouse like first time install. Now I get endless spaces until I unplug device.
Tried putting back in orig USB port
Tried a PC reboot.
SOURCE: Wireless Mouse gets stuck
Take a eraser and use it to rub the contact points on your batteries clean. This seems to be the issue where your sensiativity will change by it self the the mouse has a 20 - 30 pause to reset it's self as if you just stuck a different battery in it.
Posted on Jan 13, 2008
IrishDruid
  • 2712 Answers
SOURCE: keyboard
Hello ARRG,
It looks like the problem is with the keyboard, and not the mouse. To verify, try the k/b on a different computer. If the issue occurs there as well, it means the k/b is defective and you may have to replace it.
If however, it functions well on the other PC, then it could be a problem with either the port or the driver, or the keyboard itself.
First try the k/b on another free port, if available. If it works OK, then the original port is damaged and you will need to take the PC to a competent technician to get it fixed.
Next, try to download the latest drive for your keyboard and install that after uninstalling the older version. If this does not work as well, consider buying a new keyboard....I always recommend the corded variety, as they are more reliable.
Should you have any further questions, please feel free to post them here.
P.S. Before you assign a rating, please make sure that the issue is resolved or you are satisfied. If not, please post back as to what you did, and/or any other questions you may have, and I will try to assist you as best I can. Please do not assign an ‘Inappropriate’ or ‘Thanks for trying’ rating if your issue is not resolved after the first response itself, as sometimes a bit of to and fro dialogue may be necessary before we can find a fix or an answer to your query.
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! or Helpful rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
"Discover How to Achieve Your WILDEST DREAMS"...Free Download
FREE SOFTWARE GIVEAWAY
Windows Utilities - Software Street
Posted on Apr 23, 2008
IrishDruid
  • 2712 Answers
SOURCE: Logitech M-BJ58 USB optical mouse win xp issue
Hello dcipher,
This is due to a missing Windows file called input.inf. The solution is as follows:
In Windows XP, you can use the MSCONFIG utility as described in the following steps:
  1. Click Start->Run.
  2. Type msconfig in the Open field, and then click OK.
  3. Click the Expand File button.
  4. Type input.inf in the File to restore box.
  5. Type the path of the Windows XP .cab file where you want to restore the file from in the Restore from box. If you don't know the patch, click the Browse From button to locate the Windows XP .cab file.
    Note: The Windows XP .cab files are stored in the I386 folder on the Windows XP CD.
  6. Type C:\windows\inf\ in the Save file in box. This assumes that Windows XP was installed to the default directory. If Windows was not installed to the default directory, you will need to adjust the path to point to the correct directory.
  7. Click the Expand button.
  8. Click OK. If you are prompted to restart the computer, click Restart.
After extracting the file and restarting, try installing the mouse software again. You should no longer see this error message.
Cheers!
IrishDruid
Enjoy free holidays, meals, shopping and more, with mystery shopping!! USA / UK
Windows Utilities
Posted on Apr 25, 2008
SOURCE: logitrch lx 700 mouse acting crazy
Purchased new MX 5500
Posted on May 30, 2008
  • 38 Answers
SOURCE: logitech V220 cordless mouse won't work
The V220 is a quite nice rodent, my favorite. Check 3 things.
1) Is the battery facing the right way? Minus end goes in first. Green LED should turn on for a few seconds after the battery is installed.
2) Is the mouse ON? The switch under the mouse is supposed to turn on automatically when the receiver is removed. This does not always work.
3) Unplug the USB Receiver. Connect it to a different USB port. Run the Logitech Connect utility.
If the mouse still does not work, uninstall the Setpoint software and reboot. It is possible that the driver did not install correctly. After reboot, try Step 3 again.
Setpoint software is only needed if you want to use the wheel click or horizonal scroll features.
If all else fails, try installing your V220 on a different computer.
Posted on Jun 01, 2009
I purchased an emachines a few years ago but continued to use the keyboard that I was familiar with. It is now worn. I have installed the new emachines keyboard and nothing happens...no lights come...
Did the old keyboard plug into a PS2 keyboard socket (round purple connector) or into a USB port (flat rectangular connector)? Similarly, what type of connector is the new keyboard?
If it is the round PS2 connector you may have connected into the green PS2 mouse socket instead of the purple keyboard socket. Although the sockets are similar, they work differently.
If it is USB, then try moving it to a different USB port.
Try the keyboard on another PC.
If you cannot get it to work then replacement keyboards are very cheap.
Feb 16, 2011 | E-Machines eMachines Desktop PC
Chick and wheel works but mouse won't move pointer
  1. Try to connect the Mouse receiver to a different USB port. Then, check the behavior of the device.
    Also, try to connect the receiver to a USB port on the back of the computer. The ports that are located on the back of the computer typically have more power available. Note Bypass any port replicators, USB hubs, KVM switches, and so on. Connect the receiver directly to the port.
  2. Replace the batteries, and determine whether this resolves the issue. Make sure that you have inserted both the required batteries into the wireless pointing device and that they are positioned in the correct direction. After replacing the batteries, press the reset, or resync button on the mouse or on the receiver.
  3. If the issue continues to occur, test the mouse on a different computer in a different environment. If you can replicate the problem in a different environment, you may have a defective device.
  4. If the mouse buttons are recognized, and the pointer won't move, you may have a defective device. However, the best way to determine whether the device is defective or damaged is to try the device on a different computer.
Jul 12, 2010 | Logitech V550 Nano Mouse
Wireless Logitech mouse with NO connect button on it. Only buttons on it are Power and Reset (and one to open battery case). Cannot figure out how to connect to receiver. Was previously connected, but I...
Ok, try this in the steps ordered
1 remove the receiver from the USB port
2 remove the battery from the mouse
3 turn on the pc
4 after everything is loaded on the pc, plug the mouse receiver into the USB port
5 put the battery back in to the mouse and let it "find" the receiver.
If these steps don't work, try doing the steps and use a different USB port. If that doesn't work try a different battery in the mouse.
If none of this works and the receiver hasn't been bent (happens allot in laptops), then it sounds like your mouse took a dump.
Mar 18, 2010 | Logitech Cordless Mouse
My cordless mouse was working fine, but now the computer does not recognize it, so I went out and bought another cordless mouse and it still doesn't work..... why? Thanks
If you're running XP or newer, your system should autodetect the wireless receiver plugged into your USB port which will then autodetect the signal from the mouse. Some wireless mice have a small button on the bottom that must be pushed and held for a few seconds each time the battery is installed.
By the way, the receiver that goes into the USB port may be different for each mouse. Use the one that came with the mouse.
Nov 12, 2009 | Dell Inspiron 6000 Notebook
Fairly new mouse (new batteries also)not working. Solid blue light when plugged into USB port but cursor will not move at all when click mouse buttons or scroll bar. Rebooting system nor unplugging USB...
First make sure your mouse is installed properly. Go to Device Manager and see if it lists the mouse and has no conflicts. Also, try a different USB port, especially if it doesn't show up. If your receiver and mouse have reset or connect buttons on them you'll need to push those also. try alternate batteries. if none of these suggestions can solve your problem you may be looking at a defective mouse.
Nov 05, 2009 | GE Optical Mini Wireless Mouse 98793
I had music on my sansa cant find it and now it said memeroy is full and i know it not
hi its because of virus in ur system so try 2 formate ur card for better result else install anti virus in ur system
Aug 24, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
My key board spaces four or five spaces at once
it can be different sources:
1- check there is no source of interferrence (cordless,...)
2- change the usb receiver port
3- try to update the drivers
good luck
feed back plz
Apr 04, 2009 | Logitech Cordless Desktop MX3200...
Dynex wireless mouse DX-PWLMSE won't work
The mouse should be Plug and Play. Did you install the drivers before plugging the mouse's receiver in? The PC has to have the drivers first in order to take advantage of the Plug and Play capability. If you plugged the mouse's receiver in before installing the drivers, unplug the mouse receiver, uninstall the driver, reboot your PC, reinstall the driver, then plug the receiver in and you should be fine.
Otherwise, press the Connect button on the receiver first, and then the Connect button on the mouse, and that should establish the connection. You don't need to disable your touch pad in order to use the mouse.
Jan 22, 2009 | Dynex Wireless Keyboard/Optical Mouse...
Microsoft wireless notebook optical mouse 3000 Doesnt seem to work?
Okay, a coworker had this problem and it was a fairly easy fix, first, plug the USB reciever into a direct USB port, then pess the connect button on the underside of the mouse, when the red light starts blinking let go and then press it and hold, and at the SAME TIME press and hold the connect button on the receiver until both the receiver light and the mouse light turn on steadily, and voila!
Aug 04, 2008 | Microsoft Wireless Notebook Optical Mouse...
Logitech LX5 Cordless Mouse
Try
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Nov 22, 2007 | Computers & Internet
Logitech LX 700 9674180101 Logo
312 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
