Turntable stops intermittant while playing
I have a Philips Electronics 242 TT. The problem is it stops intermittantly. If I press the Start button , it resumes playing. Please help.
The belt on the player is gone and has to be replaced. I have the same problem with the same model and I'm looking for belt myself. All the best.
Posted on Dec 02, 2009
Turntable running faster after changing the belts
I have found a link to give more information on speed control and new belts
May 07, 2014 | Philips 100 ft. 16 ga. Speaker Wire -...
My Technics turntable slqdd22 cue and stop buttons not working
Hi, with the tone arm sitting on its mount rotate the platter manually approx. 12 times. That should reset all the auto functions. Cheers john.
Nov 21, 2013 | Audio Players & Recorders
Turntable won't stop spining
If it is a turnatable that starts spining when the arm is moved to the record, then more than likely the start/stop switch inside the turnable is broken and is fixed in the on position. Or the leaver mechanism has become detached from the arm when the record was playing and left the other part pressing on the same switch that turns the motor on or off.
Removing the bottom of the turntable should should show the trouble.
Apr 03, 2012 | Philips WMM142211 Turntable
Very little volumn no groun d on stereo - do i
I can't find a reference to the TT-01, but if it's an old school turntable you need to run it through a Phono preamp.
It would help to know what electronics you're using as THAT is where the volume comes from.
The TT should be connected to a specific PHONO input as it includes special preamplification for a Phono cartridge and frequency shaping for the way LP's are recorded (Google RIAA). I imagine it may sound pretty tinny as you have it now.
Aug 17, 2010 | Philips gemini TT-01 Turntable
I have the Uniden 6.0 Dect 1580-3 but there was ...
43
43
h
e
s
t
e
m
Recording a Personal Greeting
Your.answering.system.comes.with.a.pre-recorded.outgoing.message.or.greeting.that.plays.when.you.receive.a.
call:.“Hello,.no.one.is.available.to.take.your.call..Please.leave.a.message.after.the.tone.”.You.can.record.your.own.
personal.outgoing.greeting..Your.recorded.greeting.must.be.between.two.seconds.and.thirty.seconds.long.
1).Press. /MUTE..The.system.announces.the.number.of.new.and.old.messages,.then.starts.to.play.the.
messages.unless.it.has.no.messages..
2).Press.5.to.stop.the.announcements.or.message.playback..You.will.hear.intermittent.beeps.indicating.that.the.
system.is.in.the.command.waiting.mode.
3).Press.8.to.start.the.recording..The.system.announces,.“Record.greeting.”.Begin.recording.after.the.
announcement..
4).When.you.finish.recording,.press.8.again.or.press.5..You.will.hear.a.confirmation.tone,.and.your.recorded.
greeting.plays.back.for.you.
Selecting a Greeting
Once.you.have.recorded.a.personal.greeting,.the.phone.automatically.switches.to.your.personal.greeting..You.can.
also.switch.back.and.forth.between.the.pre-recorded.greeting.and.your.own.greeting.at.any.time.
3).Press.6..The.system.plays.the.current.greeting.
S
e
tt
in
g
U
p
t
h
e
A
n
sw
e
r
in
g
S
y
s
te
m 4).To keep this greeting:. Do.nothing.
To switch to the other greeting:.Press.6.while.the.system.is.playing.the.current.greeting.
5).Each.time.you.press.6,.the.system.switches.between.the.pre-recorded.and.the.personal.greeting..The.last.
greeting.you.hear.is.used.as.the.current.greeting.
Deleting Your Personal Greeting
You.can.delete.your.personal.greeting.from.the.base..You.cannot.delete.the.pre-recorded.greeting.
3).Press.6..The.system.plays.the.current.greeting..Switch.to.your.personal.greeting.if.necessary..(See.the.previous.
section.to.switch.the.greeting.)
4).While.the.personal.greeting.is.playing,.press.4.
5).The.system.announces.“Greeting.has.been.deleted,”.and.switches.back.to.the.pre-recorded.greeting.
May 21, 2010 | Uniden DECT 6.0 Cordless Phone ID
Turntable turns intermittently so unit will not operate
The turntable fan and light all share the same feed, first check wiring for loose connections the problem though is most likely with the controller
Dec 28, 2009 | Viking DMOC205SS Microwave Oven
The left channel tends not to work intermittently. I have tested the pre-amp and it appears it is from the turntable. One day it might work and the next it will not.
There will be a pre-amp in the turntable too, presumable you have checked the cartridge, and the everything on the turntable for bad connections?
If yes take the base off and check the pre-amp.
Dec 02, 2009 | Marantz Reference TT-15S1 Turntable
I have no clue how to play a cd there... I mean, the radio is no problem, i can turn it off and on, can search for a prog, no big deal. but how do i start the turntable? maybe someone even has a manual for...
to start a turntable press Start button and put an arm with a needle across record, if there is no start button, just put arm across record - it should auto-start; to play cd put it in and press play (play button shoud be near the cd slot, together with stop, skip and others)
Oct 14, 2009 | Crosley CR711-BK AutoRama Retro Turntable...
TT 02 doesn't spin - Help!
i don't know if these are belt driven or not but i would check to see if the belt fell off, if motor driven then i would suspect a bad motor.
Dec 31, 2007 | Philips gemini TT-02 Turntable
64 people viewed this question
 Grubhead
Grubhead
