Question about Symbol MC9090 Barcode Scanner
Cant activate PCCARD-PHOTON1 in Symbol MC9090
Cant activate PCCARD-PHOTON1 in Symbol MC9090. The tarjet is disabled and no detect Wifi
  • Anonymous Apr 29, 2009
    the same question in the MC3000
  • Stuart Pilkington-Way
    Stuart Pilkington-Way May 11, 2010
    Can you supply teh full part number so we can check the hardware configuration.
    Novelist:
  • 75 Answers
First thing is to run the wireless utility.
Start >> Programs >> Fusion >> WCLAUNCH
Once thats running an icon will apear in the task bar.
Click the icon and select "Enable Radio"
If you need any more help then please do not hesitate to contact us:-
helpdesk@biastechnology.com or TEL 01202 620955
http://www.biastechnology.com/
Posted on Dec 15, 2009
When the DataWedge 2.0 is launched, an Error "cannot set scan parameters 00000000" appears and scanner does not function. Was running just fine. MC7094. Scanning is working fine in another...
If the scanner is not working, you can try to go to this site to check the information on how to reset the device. Here is the link that you can try.
Thank you for sing Fixya.
Aug 09, 2011 | Symbol MC9090 Barcode Scanner
How do i update the firmware on a Symbol MC9090?
You can do it by SD Card or by Active Sync connection. The instructions are included in the Update package provided on support.symbol.com
May 11, 2010 | Symbol MC9090 Barcode Scanner
I cannot set the static IP for my MC9090. I went into Network Connections and have tried to Specify a valid IP address, Subnet and Gateway. I press ok. Then when I run cmd, I then type ipconfig and it...
Hi Jim,
I remember having the exact same problem when I first used the MC9090. It works on such other devices like the Datalogic Viper, but not the MC9090.
The IP is set within the wireless profile.
On the radio icon in the task bar select Wireless Profiles. This box then holds all your wireless profiles, including the default Motorola "out of box". Hold down the stylus on the screen and select "Add New" follow the prompts. When you get to IP Address from the pull down menu select static and then next this will take you to another screen where you can add your details.
Now you want to make them persist through either a cold boot or when the terminal has been left without a battery for a substantial amount of time.
This can be done 2 ways. When the profile has been set up highlight it by holding down the stylus on it and from the menu select export. This saves the registry key to the Application folder; a folder which persist through a cold boot. When it does cold boot it takes all the registry keys from the Application folder and builds 1 complete key.
The other way is to close the WLAN profile and selection options, from the pull down menu select export and save all profiles.
Hope this helps.
or TEL 01202 620955
Jan 14, 2010 | Symbol MC9090 Barcode Scanner
Hello, I have symbol MC9090-K. I am trying to connect it to the WIFI. The device shows the access point but unable to get an IP address i check the status in IPv4 it shows 0.0.0.0 or it renews for few...
It appears you device can not gain access to you DHCP server to obtain an IP address.
Simple solution would be to assign a static IP and then test.
Do the intermec scanners obtain there IP address's vias DHCP?
If you need any further assistance then please contact us
Aug 15, 2009 | Symbol MC9090-K Portable Data Collector...
Hi, I'm writing a php page to be used on the MC9090 and I want the laser to be activated when focus is on a specific input box. Seeing as I'm new to the MC9090 scanner I don't have a clue where to start....
I'm not sure if you can trigger the scanner based on a web field but you can just enable the Data wedge software which will allow the scan to input anywhere you have the cursor. The scanner will be "active" all the time but won't actually scan until you pull the trigger. You can download the datawedge software from www.symbol.com.
May 19, 2009 | Symbol MC9090 Barcode Scanner
Symbol MC9090 scanner disabled
You may need to reflash the OS. you can normally download it from symbol webpage. you will need a cradle and an SD card.
Mar 25, 2009 | Zebra Symbol Technologies MC909X-G Series...
How can enable Barcode Scanner ??
You have to use a program which will activate the scanner.
You can use DataWedge, which will send the scanner input to whatever has focus: https://docs.symbol.com/KanisaPlatform/Publishing/968/KB100417_f.html
Sep 30, 2008 | Symbol MC9090 Barcode Scanner
Is there a way to disable the Bluetooth and WiFi at an administrative level?
install a program called symbol appcenter and you can keep people from accessing anything you do not want them to access, I have it installed on mine for an inventory system and all my employees can access is the inventory system. As the administartor I have the password if I need to access anything else in the scanner to ake changes, but nobody else can.
Sep 24, 2008 | Symbol MC9060-G
SYMBOL MC9090 - LASER READER NOT WORKING
You may need to replace the scan engine - I can help you out with this (or any other issues you may be having).
Contact me if you need anything:
Ian
DC Solutions
ianv@dcsolutionsonline.com
Aug 11, 2008 | Symbol MC9090 Barcode Scanner
Active Sync for connecting MC9090 with PC
Hi - You can download the software from the link underlined in blue below:
Symbol
Select your model from the page that opens.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Jul 28, 2008 | Symbol MC9090 Barcode Scanner
Symbol MC9090 Barcode Scanner Logo
2,432 people viewed this question
Top Symbol Computers & Internet Experts
Michael
Oloyede Monsuru
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
